# 数据类型兼容列表
本章节介绍数据加密系统插件（Application-Plugin）模式与代理（Proxy）模式√的数据类型**。**
#### MySQL
| 字段类型             | 加密   | 解密   | 完整性 | sdk新增入库密文 | sdk查询展示明文+脱敏 | sdk编辑 | sdk模糊查询 | 代理新增入库密文 | 代理查询展示明文+脱敏 | 代理编辑 | 代理模糊查询 |
| varchar           | √  | √ | √   | √     | √          | √    | √      | √    | √           | √       | √    |
| tinytext        | ×    | ×   | ×   | ×         | ×           | ×       | ×      | ×      | ×           | ×       | ×   |
| text              | √  | √  | √    | √      | √         | √      | √       | √       | √           | √      | √     |
| mediumtext         | ×    | ×    | ×  | ×         | ×          | ×      | ×      | ×        | ×          | ×     | ×     |
| longtext           | ×  | ×  | ×   | ×         | ×           | ×    | ×     | ×        | ×             | ×     | ×       |
| json             | ×    | ×    | ×    | ×      | ×          | ×    | ×       | ×      | ×           | ×      | ×   |
| decimal         | ×   | ×  | ×    | ×       | ×            | ×     | ×      | ×       | ×          | ×      | ×      |
| double            | ×  | ×  | ×    | ×         | ×          | ×   | ×       | ×       | ×            | ×       | ×   |
| float             | × | ×  | ×     | ×       | ×            | ×    | ×      | ×      | ×           | ×       | ×    |
| int             | ×   | ×   | ×   | ×       | ×            | ×     | ×        | ×       | ×            | ×       | ×      |
| int unsigned    | ×   | ×   | ×    | ×         | ×          | ×     | ×         | ×        | ×           | ×        | ×      |
| integer            | ×  | ×     | ×  | ×      | ×             | ×      | ×       | ×      | ×           | ×      | ×     |
| integer unsigned   | ×   | ×    | ×   | ×          | ×           | ×      | ×      | ×       | ×             | ×       | ×    |
| bigint             | ×  | ×  | ×  | ×         | ×             | ×      | ×        | ×         | ×          | ×       | ×     |
| bigint unsigned | × | ×  | ×    | ×        | ×          | ×     | ×      | ×      | ×          | ×     | ×      |
| smallint           | × | ×  | ×    | ×         | ×           | ×       | ×        | ×       | ×           | ×       | ×     |
| smallint unsigned | ×    | ×    | ×    | ×       | ×         | ×    | ×      | ×       | ×          | ×       | ×   |
| bit              | ×    | × | ×   | ×        | ×          | ×    | ×        | ×      | ×            | ×     | ×       |
| binary             | ×   | ×    | ×   | ×       | ×         | ×   | ×       | ×      | ×          | ×       | ×      |
| varbinary          | ×   | ×    | ×   | ×        | ×          | ×      | ×     | ×        | ×           | ×     | ×       |
| tinyblob          | ×   | ×  | ×  | ×        | ×           | ×     | ×        | ×        | ×          | ×      | ×    |
| mediumblob         | ×    | ×    | ×    | ×        | ×            | ×     | ×        | ×       | ×            | ×      | ×     |
| longblob          | ×   | × | ×  | ×        | ×           | ×     | ×         | ×       | ×         | ×     | ×      |
![](https://support.huaweicloud.com/usermanual-dbss/public_sys-resources/note_3.0-zh-cn.png)
主键不支持配置密钥，也不支持加密。
#### MariaDB
主键不支持配置密钥，也不支持加密。
#### Oracle
| CHAR      | √   | √   | ×    | √          | √             | √      | √       |
| VARCHAR | √ | √    | ×  | √        | √           | √     | √         |
| NCHAR     | × | ×   | ×   | ×         | ×             | ×    | ×         |
| VARCHAR2 | √    | √    | ×    | √          | √            | √    | √         |
| NVARCHAR2 | ×   | ×   | ×     | ×         | ×             | ×     | ×          |
| CLOB      | ×   | ×     | ×   | ×         | ×             | ×     | ×      |
| NCLOB    | ×   | ×    | ×     | ×          | ×          | ×     | ×         |
| LONG      | ×  | ×    | ×    | ×          | ×            | ×     | ×       |
| NUMBER   | ×  | ×     | ×   | ×         | ×           | ×     | ×        |
| FLOAT     | ×  | ×    | ×    | ×        | ×            | ×     | ×        |
- 不需要设置逻辑主键就可以加解密。
- CLOB、NCLOB类型，在插件中查询数据可以解密，如果查询条件中带CLOB、NCLOB类型只能Like，其他方式不支持。
#### MS SQL Server
| text（varchar-max） | √   | √ | √    | √          | √            | √    | √         | √      | √           | √  | √      |
| nchar            | ×    | ×     | ×    | ×       | ×           | ×     | ×       | ×        | ×           | ×   | ×      |
| nvarchar         | ×     | × | ×     | ×        | ×             | ×    | ×        | ×       | ×          | × | ×       |
| nvarchar（max）    | ×   | ×  | ×   | ×         | ×              | ×     | ×       | ×       | ×         | ×  | ×       |
| image             | ×     | ×  | ×    | ×      | ×            | ×      | ×       | ×        | ×         | ×    | ×      |
| money            | ×   | ×   | ×     | ×         | ×              | ×     | ×        | ×         | ×         | ×  | ×       |
| ntext             | ×   | ×  | ×    | ×       | ×            | ×    | ×        | ×        | ×         | ×    | ×     |
| numeric          | ×    | ×   | ×       | ×         | ×               | ×      | ×           | ×       | ×            | ×   | ×       |
| varbinary（max）    | ×      | ×   | ×      | ×          | ×               | ×       | ×        | ×       | ×          | ×     | ×        |
| real             | ×   | ×   | ×     | ×        | ×               | ×      | ×         | ×       | ×           | ×   | ×       |
| smallmoney       | ×    | ×   | ×      | ×         | ×              | ×       | ×        | ×       | ×         | ×     | ×       |
| tinyint          | ×  | ×    | ×    | ×           | ×               | ×        | ×          | ×         | ×            | ×     | ×      |
| datetime         | ×     | ×    | ×      | ×          | ×              | ×     | ×         | ×         | ×           | ×    | ×      |
| int identity     | ×    | ×    | ×    | ×         | ×             | ×     | ×          | ×         | ×           | ×   | ×     |
| xml              | ×    | × | ×      | ×         | ×            | ×       | ×           | ×        | ×            | ×   | ×       |
- 勾选字段保存成逻辑主键后可支持加密和解密。
- SQL Server主键、索引不支持加密，不支持设置密钥。
#### PostgresSQL
| int2                | ×  | ×    | × | ×       | ×             | ×    | ×        | ×          | ×             | ×    | ×     |
| int4              | ×  | × | ×  | ×       | ×              | ×    | ×         | ×          | ×            | ×      | ×      |
| int8              | ×  | ×   | ×   | ×         | ×              | ×   | ×       | ×        | ×            | ×       | ×    |
| float4             | ×  | ×    | ×  | ×        | ×            | ×    | ×         | ×         | ×             | ×        | ×      |
| double precision   | ×   | ×   | ×   | ×       | ×             | ×     | ×       | ×           | ×          | ×     | ×    |
| float8             | ×   | ×  | ×   | ×        | ×             | ×   | ×         | ×         | ×           | ×       | ×     |
| bpchar              | ×   | ×  | ×    | ×       | ×            | ×    | ×       | ×        | ×             | ×       | ×       |
| character         | × | ×   | ×    | ×       | ×            | ×   | ×       | ×         | ×         | ×      | ×     |
| character varying | ×  | ×   | × | ×         | ×            | ×    | ×       | ×         | ×           | ×       | ×      |
| bytea              | ×  | × | ×   | ×         | ×            | ×     | ×       | ×         | ×           | ×      | ×      |
#### Greemplum
| varchar            | √   | √    | √   | ×       | ×          | ×   | ×         | √       | √           | √        | √       |
| char             | √  | √     | √  | ×       | ×          | ×    | ×       | √     | √            | √     | ×       |
| text             | √  | √   | √   | ×     | ×           | ×    | ×        | √       | √           | √      | √      |
- 主键不支持配置密钥，也不支持加密。
- char和bpchar字段不支持模糊匹配。
#### 达梦
| varchar           | √ | √  | √     | √           | √              | √      | √     | √      | √            | √    | ×       |
| text              | √   | √    | √    | √          | √            | √      | √    | √      | √             | √     | ×      |
主键不支持配置密钥，也不支持加密。
#### DB2
| text               | √   | √    | √    | ×        | ×            | ×     | ×       | ×      | ×            | ×  | ×      |
- 主键不支持配置密钥，也不支持加密。
- DB2没有text类型，char类型在DB2中是定长的，会自动补充空格，所以不支持模糊匹配。
#### 人大金仓（MySQL模式）
| text     | √   | ×   | √   | √          | √            | √     | √      | √         | √             | √   | √    |
| jsonb     | ×  | ×   | ×  | ×            | ×           | ×      | ×        | ×        | ×           | ×    | ×       |
| json       | √   | √   | √  | ×           | ×           | ×      | ×      | ×         | ×            | ×     | ×      |
#### DWS_GAUSSDB
| varchar               | √  | √   | √   | √       | select\*不支持，select具体字段支持 | √   | √     | √       | √         | √ | √    |
| char                | √ | √  | √ | √     | select\*不支持，select具体字段支持   | √  | √     | √         | √        | √  | × |
| text                | √ | √   | √ | √      | select\*不支持，select具体字段支持 | √  | √       | √     | √         | √ | √   |
- 主键不支持配置密钥，也不支持加密。
#### GaussDB
| bpchar            | √   | √ | √    | √        | √           | √      | √      | √       | √        | √    | √     |
| character          | √   | √   | √   | √         | √         | √     | √     | √      | √         | √   | √        |
| character varying  | √    | √  | √ | √         | √         | √      | √    | √       | √           | √   | √     |
#### openGauss
| char             | √    | √     | √     | √         | select\*不支持，select具体字段支持 | √      | √       | √          | √          | √    | 左匹配×     |
主键不支持配置密钥，也不支持加密。
#### RDS for MySQL
| varchar            | ×  | ×  | ×   | √      | √            | √     | √       | √    | √          | √   | √    |
| text               | × | × | × | √       | √           | √      | √      | √    | √         | √  | √     |
主键不支持配置密钥，也不支持加密。
#### RDS for PostgreSQL
#### RDS for MariaDB
主键不支持配置密钥，也不支持加密。
#### RDS for SQL Sever
| char              | √ | √   | √   | √        | √             | √     | √     | ×       | ×           | ×     | ×     |
| varchar         | √  | √   | √  | √         | √           | √    | √      | ×         | ×              | ×     | ×      |
| text             | √   | √   | √ | √        | √            | √   | √        | ×        | ×            | ×    | ×    |
#### RDS for TaurusDB
主键不支持配置密钥，也不支持加密。
