# 附录
#### 数据源原始类型与系统类型映射
![](https://support.huaweicloud.com/usermanual-dataartsplatform/public_sys-resources/note_3.0-zh-cn.png)
- 数组类型映射规则：PostgreSQL、OpenGauss、DWS的数组类型按 ARRAY\<元素映射类型\> 映射；Doris数组类型暂映射为 STRING，后续将支持原生数组映射。
- DECIMAL类型精度说明：系统最高支持精度为38，对于未明确指定精度或精度大于38的原始类型将映射为STRING类型。
 表1数据源原始类型与系统类型映射
| 序号     | 数据源类型        | 数据源原始字段类型         | 映射系统类型               |
| 1       | MySQL          | BIT                  | STRING              |
| 2       | MySQL        | TINYINT              | BYTE              |
| 3      | MySQL       | SMALLINT            | SHORT             |
| 4        | MySQL       | MEDIUMINT         | INTEGER            |
| 5     | MySQL      | INT                 | INTEGER             |
| 6       | MySQL        | INTEGER             | INTEGER            |
| 7       | MySQL          | BIGINT               | BIGINT              |
| 8      | MySQL      | FLOAT              | FLOAT               |
| 9      | MySQL       | DOUBLE              | DOUBLE            |
| 10       | MySQL         | DECIMAL           | DECIMAL/STRING     |
| 11    | MySQL       | DATE                 | DATE               |
| 12      | MySQL        | DATETIME             | TIMESTAMP         |
| 13       | MySQL        | TIMESTAMP            | TIMESTAMP        |
| 14       | MySQL      | TIME                | STRING             |
| 15       | MySQL       | YEAR                  | STRING             |
| 16     | MySQL          | CHAR               | STRING             |
| 17       | MySQL        | VARCHAR             | STRING            |
| 18       | MySQL       | BINARY               | BINARY              |
| 19     | MySQL      | VARBINARY             | STRING             |
| 20     | MySQL        | TINYBLOB            | STRING             |
| 21       | MySQL        | BLOB                  | STRING             |
| 22    | MySQL        | MEDIUMBLOB        | STRING             |
| 23       | MySQL       | LONGBLOB            | STRING            |
| 24      | MySQL         | TINYTEXT            | STRING             |
| 25      | MySQL        | TEXT                | STRING           |
| 26      | MySQL         | MEDIUMTEXT         | STRING              |
| 27     | MySQL        | LONGTEXT            | STRING             |
| 28       | MySQL         | JSON                | STRING             |
| 29      | MySQL       | BOOLEAN              | BOOLEAN           |
| 30      | MySQL        | BOOL                 | BOOLEAN           |
| 31        | MySQL       | ENUM                 | STRING            |
| 32      | MySQL        | SET                  | STRING             |
| 33       | PostgreSQL    | BIT                  | STRING              |
| 34      | PostgreSQL    | SMALLINT            | SHORT               |
| 35       | PostgreSQL  | INTEGER             | INTEGER           |
| 36       | PostgreSQL     | BIGINT             | BIGINT               |
| 37       | PostgreSQL   | DECIMAL             | DECIMAL/STRING     |
| 38       | PostgreSQL   | NUMERIC             | DECIMAL/STRING   |
| 39     | PostgreSQL   | REAL               | DOUBLE            |
| 40       | PostgreSQL    | DOUBLE PRECISION    | DOUBLE             |
| 41      | PostgreSQL  | SMALLSERIAL         | SHORT                |
| 42     | PostgreSQL   | SERIAL             | INTEGER             |
| 43       | PostgreSQL  | BIGSERIAL           | BIGINT             |
| 44     | PostgreSQL    | OID               | BIGINT              |
| 45     | PostgreSQL    | INT2                 | SHORT               |
| 46       | PostgreSQL  | INT4               | INTEGER            |
| 47       | PostgreSQL   | INT8                 | BIGINT            |
| 48     | PostgreSQL    | FLOAT4                | FLOAT              |
| 49     | PostgreSQL  | FLOAT8              | DOUBLE              |
| 50      | PostgreSQL    | SERIAL2             | SHORT              |
| 51      | PostgreSQL    | SERIAL4              | INTEGER           |
| 52     | PostgreSQL    | SERIAL8              | BIGINT              |
| 53     | PostgreSQL  | CHARACTER            | STRING            |
| 54        | PostgreSQL  | CHARACTER VARYING  | STRING            |
| 55    | PostgreSQL   | CHAR                 | STRING            |
| 56     | PostgreSQL  | VARCHAR              | STRING               |
| 57       | PostgreSQL  | TEXT                | STRING             |
| 58       | PostgreSQL    | UUID                | STRING              |
| 59      | PostgreSQL    | TIMESTAMP            | TIMESTAMP         |
| 60      | PostgreSQL    | TIMESTAMPTZ        | TIMESTAMP           |
| 61     | PostgreSQL | DATE                | DATE              |
| 62      | PostgreSQL | TIME                | STRING            |
| 63      | PostgreSQL   | TIMETZ              | STRING            |
| 64      | PostgreSQL   | INTERVAL             | STRING             |
| 65      | PostgreSQL  | BOOLEAN             | BOOLEAN          |
| 66    | PostgreSQL | BOOL                | BOOLEAN            |
| 67      | PostgreSQL    | JSON                | STRING            |
| 68     | PostgreSQL | JSONB                | STRING             |
| 69      | PostgreSQL   | BYTEA                | BINARY             |
| 70     | PostgreSQL   | MONEY                | STRING            |
| 71      | PostgreSQL   | BPCHAR             | STRING              |
| 72      | PostgreSQL  | NAME               | STRING             |
| 73      | PostgreSQL    | POINT              | STRING             |
| 74       | PostgreSQL   | LSEG                 | STRING            |
| 75       | PostgreSQL | BOX               | STRING               |
| 76     | PostgreSQL  | PATH                | STRING             |
| 77      | PostgreSQL    | POLYGON             | STRING              |
| 78      | PostgreSQL   | CIRCLE               | STRING             |
| 79       | PostgreSQL  | CIDR               | STRING            |
| 80     | PostgreSQL   | INET                | STRING              |
| 81        | PostgreSQL | MACADDR             | STRING             |
| 82       | PostgreSQL   | RELTIME            | STRING             |
| 83     | OpenGauss    | TINYINT             | SHORT              |
| 84      | OpenGauss    | SMALLINT           | SHORT              |
| 85       | OpenGauss    | INTEGER             | INTEGER           |
| 86    | OpenGauss   | BINARY_INTEGER     | INTEGER            |
| 87      | OpenGauss   | BIGINT              | BIGINT             |
| 88       | OpenGauss      | INT1                 | SHORT              |
| 89       | OpenGauss      | INT2               | SHORT               |
| 90      | OpenGauss    | INT4                  | INTEGER             |
| 91     | OpenGauss    | INT8                 | BIGINT            |
| 92     | OpenGauss     | NUMERIC            | DECIMAL/STRING    |
| 93      | OpenGauss   | DECIMAL              | DECIMAL/STRING    |
| 94       | OpenGauss    | NUMBER               | DECIMAL/STRING     |
| 95       | OpenGauss    | DEC                | DECIMAL/STRING    |
| 96       | OpenGauss     | SMALLSERIAL         | SHORT             |
| 97       | OpenGauss   | SERIAL              | INTEGER            |
| 98       | OpenGauss    | BIGSERIAL          | BIGINT            |
| 99       | OpenGauss    | OID                  | BIGINT              |
| 100      | OpenGauss    | REAL               | FLOAT               |
| 101       | OpenGauss    | FLOAT                | DOUBLE            |
| 102    | OpenGauss   | FLOAT4             | FLOAT             |
| 103     | OpenGauss    | FLOAT8             | DOUBLE              |
| 104     | OpenGauss    | DOUBLE PRECISION    | DOUBLE              |
| 105    | OpenGauss  | BINARY_DOUBLE      | DOUBLE             |
| 106    | OpenGauss    | MONEY                | STRING            |
| 107      | OpenGauss    | BOOLEAN               | BOOLEAN          |
| 108      | OpenGauss     | BOOL               | BOOLEAN           |
| 109      | OpenGauss     | CHAR                 | STRING              |
| 110     | OpenGauss    | CHARACTER          | STRING             |
| 111     | OpenGauss     | NCHAR                 | STRING              |
| 112    | OpenGauss   | VARCHAR            | STRING              |
| 113    | OpenGauss   | CHARACTER VARYING | STRING             |
| 114      | OpenGauss   | VARCHAR2            | STRING           |
| 115     | OpenGauss    | NVARCHAR2           | STRING            |
| 116     | OpenGauss      | BPCHAR              | STRING             |
| 117     | OpenGauss      | UUID                | STRING            |
| 118    | OpenGauss      | CLOB               | STRING              |
| 119     | OpenGauss   | TEXT               | STRING               |
| 120     | OpenGauss    | NAME                  | STRING            |
| 121    | OpenGauss    | DATE              | DATE                |
| 122    | OpenGauss     | TIME                 | STRING             |
| 123     | OpenGauss      | TIMETZ               | STRING            |
| 124      | OpenGauss      | TIMESTAMP           | TIMESTAMP          |
| 125      | OpenGauss     | TIMESTAMPTZ         | TIMESTAMP         |
| 126    | OpenGauss    | SMALLDATETIME       | TIMESTAMP          |
| 127       | OpenGauss     | BIT                | STRING              |
| 128   | OpenGauss    | BIT VARYING          | STRING             |
| 129    | OpenGauss    | VARBIT             | STRING             |
| 130      | OpenGauss    | JSON               | STRING            |
| 131     | OpenGauss   | JSONB               | STRING             |
| 132  | DWS      | BIT              | STRING          |
| 133  | DWS         | SMALLINT          | SHORT            |
| 134  | DWS        | INTEGER         | INTEGER           |
| 135  | DWS         | TINYINT          | SHORT             |
| 136   | DWS         | BIGINT           | BIGINT           |
| 137  | DWS         | DECIMAL            | DECIMAL/STRING  |
| 138   | DWS       | NUMERIC           | DECIMAL/STRING   |
| 139    | DWS       | REAL                | DOUBLE           |
| 140   | DWS       | DOUBLE PRECISION   | DOUBLE           |
| 141   | DWS       | SMALLSERIAL        | SHORT            |
| 142   | DWS        | SERIAL             | INTEGER           |
| 143  | DWS         | BIGSERIAL         | BIGINT            |
| 144    | DWS        | OID               | BIGINT           |
| 145   | DWS         | INT2             | SHORT          |
| 146  | DWS         | INT4              | INTEGER          |
| 147  | DWS        | INT8             | BIGINT            |
| 148    | DWS        | FLOAT4            | FLOAT             |
| 149   | DWS       | FLOAT8            | DOUBLE          |
| 150    | DWS       | SERIAL2          | SHORT            |
| 151  | DWS       | SERIAL4           | INTEGER           |
| 152    | DWS       | SERIAL8           | BIGINT            |
| 153    | DWS        | CHARACTER        | STRING           |
| 154 | DWS        | CHARACTER VARYING  | STRING           |
| 155  | DWS         | CHAR              | STRING          |
| 156   | DWS        | VARCHAR             | STRING          |
| 157 | DWS        | NVARCHAR2          | STRING          |
| 158    | DWS       | TEXT             | STRING           |
| 159    | DWS       | UUID              | STRING          |
| 160    | DWS        | TIMESTAMP         | TIMESTAMP       |
| 161  | DWS       | TIMESTAMPTZ       | TIMESTAMP         |
| 162   | DWS       | DATE               | DATE             |
| 163    | DWS       | TIME             | STRING           |
| 164    | DWS       | TIMETZ           | STRING           |
| 165    | DWS       | INTERVAL         | STRING           |
| 166    | DWS      | BOOLEAN          | BOOLEAN          |
| 167   | DWS         | BOOL                | BOOLEAN          |
| 168  | DWS        | JSON              | STRING           |
| 169  | DWS        | JSONB              | STRING            |
| 170     | DWS      | BYTEA             | BINARY            |
| 171    | DWS        | MONEY            | STRING             |
| 172   | DWS         | BPCHAR            | STRING          |
| 173 | DWS         | NAME             | STRING           |
| 174   | DWS       | POINT              | STRING             |
| 175   | DWS       | LSEG              | STRING            |
| 176   | DWS         | BOX             | STRING           |
| 177 | DWS        | PATH             | STRING           |
| 178  | DWS        | POLYGON           | STRING            |
| 179  | DWS        | CIRCLE            | STRING           |
| 180   | DWS        | CIDR              | STRING         |
| 181   | DWS        | INET             | STRING           |
| 182    | DWS        | MACADDR           | STRING           |
| 183   | DWS          | RELTIME          | STRING           |
| 184   | Doris      | BIGINT            | BIGINT           |
| 185    | Doris    | BOOLEAN          | BOOLEAN            |
| 186   | Doris      | CHAR              | STRING          |
| 187  | Doris      | DATE                | DATE              |
| 188    | Doris     | DATEV2            | DATE           |
| 189    | Doris        | DATETIME         | TIMESTAMP       |
| 190    | Doris       | DATETIMEV2        | TIMESTAMP        |
| 191    | Doris      | DECIMALV2         | DECIMAL/STRING   |
| 192    | Doris      | DECIMAL32         | DECIMAL/STRING |
| 193  | Doris    | DECIMAL64          | DECIMAL/STRING    |
| 194  | Doris      | DECIMAL128       | DECIMAL/STRING   |
| 195  | Doris      | DOUBLE           | DOUBLE          |
| 196   | Doris      | FLOAT             | FLOAT           |
| 197   | Doris     | INT             | INTEGER         |
| 198    | Doris       | LARGEINT           | DECIMAL         |
| 199    | Doris     | SMALLINT         | SHORT             |
| 200   | Doris        | STRING            | STRING           |
| 201    | Doris     | TINYINT           | BYTE           |
| 202   | Doris     | VARCHAR             | STRING           |
| 203    | Doris      | JSON              | STRING           |
| 204   | Doris      | AGG_STATE        | STRING         |
| 205 | Doris      | BITMAP            | STRING           |
| 206 | Doris        | HLL                | STRING           |
| 207   | Doris      | QUANTILE_STATE   | STRING         |
| 208   | Doris     | MAP                | STRING           |
#### 系统类型及其可选类型说明
- 向下转型说明：由高精度数值转型为低精度数值或由文本转为数值等情况视为向下转型，向下转型可能存在数据不一致或数据丢失情况，请谨慎使用。
- 默认转换类型：前端自动选取正常转型列表中首个类型作为默认转换类型（DECIMAL 类型除外，需手动选择）。若与业务不匹配，请按需修改。
- 地理位置类型说明：支持将json格式字符串写入本体"geo_point"或"geo_shape"类型，源数据需满足以下格式要求。
  - **geo_point**：json字符串，格式为{"lon": 22,"lat": 30}，其中lon表示经度，取值范围\[-180, 180\]，lat表示纬度，取值范围\[-90, 90\]。
  - **geo_shape**：json字符串，满足标准GeoJSON格式，如：{"type":"LineString","coordinates":\[\[100,0\],\[101,1\],\[102,2\]\]}。当前支持的type范围为Point、LineString、Polygon。
表2系统类型及其可选类型说明
| 序号   | 系统类型     | 可选本体类型        | 正常转型                                                   | 向下转型        |
| 1    | BYTE   | byte, short, int, long, float, double, boolean,string                       | byte, short, int, long, float, double, string           | boolean                                                              |
| 2     | SHORT  | short, byte, int, long, float, double, boolean, string                      | short, int, long, float, double, string                | boolean,byte                                                          |
| 3     | INTEGER | int, byte, short, long, float, double, boolean, string                       | int, long, float, double, string                       | boolean, byte, short                                                  |
| 4    | BIGINT  | long, int, byte, short, float, double, boolean, string, date, date_time     | long, float, double, date, date_time, string           | boolean, byte, short, int                                            |
| 5   | FLOAT  | float, double, long, int, byte, short, boolean, string, date, date_time      | float, double, string                                | boolean, byte, short, int, long, date, date_time                       |
| 6    | DOUBLE | double, float, long, int, byte, short, boolean, string, date, date_time       | double, string                                       | boolean, byte, short, int, long, float, date, date_time              |
| 7    | DECIMAL  | double, float, long, int, byte, short, boolean, string                      | string                                                 | boolean, byte, short, int, long, float, double                        |
| 8    | STRING   | string, byte, short, int, long, float, double, boolean, geo_point, geo_shape | string                                               | boolean, byte, short, int, long, float, double, geo_point, geo_shape |
| 9    | DATE  | date_time, date, long, string                                               | date, date_time, long, string                        | /        |
| 10   | TIMESTAMP | date_time, date, long, string                                              | date_time, date, long, string                          | /        |
| 11   | BOOLEAN | boolean, byte, short, int, long, float, double, string                     | boolean, byte, short, int, long, float, double, string | /        |
| 12 | BINARY   | string        | string                                                | /        |
| 13   | ARRAY   | array, set, string                                                           | array, set, string                                    | /        |
