# 导航菜单快捷键
在CodeArts IDE编辑器界面，在**导航(N)**菜单下，可以使用如下快捷键。如下图所示：
图1导航菜单快捷键
![](https://support.huaweicloud.com/usermanual-codeartside/zh-cn_image_0000002337002218.png "点击放大")
表1导航菜单快捷键
| 命令                   | 键（CodeArts IDE键盘映射）        | 键（IDEA键盘映射）        | 命令ID                                   |
| 显示所有符号               | Ctrl+T        | Ctrl+T        | workbench.action.showAllSymbols        |
| 前往线路                 | Ctrl+G        | Ctrl+G        | workbench.action.gotoLine              |
| 转到文件，快速打开            | Ctrl+E Ctrl+P                                                           | Ctrl+Shift+N        | workbench.action.quickOpen             |
| 转到符号                 | Ctrl+Shift+O        | Ctrl+Shift+O        | workbench.action.gotoSymbol            |
| 转到定义                 | F12 Ctrl+F12                                                           | F12 Ctrl+F12        | editor.action.revealDefinition         |
| 前往声明                 | --        | Alt+F11 F4 Ctrl+Enter Ctrl+B | editor.action.goToDeclaration          |
| 转到类型                 | Shift+Alt+T Ctrl+Shift+O Ctrl+T | Ctrl+N Ctrl+Shift+Alt+N        | workbench.action.smartSearchTypes      |
| 查找用法                 | Shift+Alt+F12        | Alt+F7 Ctrl+Shift+G        | references-view.findReferences         |
| 显示问题                 | Ctrl+Shift+M        | Shift+Escape Alt+0        | workbench.actions.view.problems        |
| 转到下一个错误或警告           | Alt+F8        | Ctrl+\` F2        | editor.action.marker.next              |
| 转到上一个错误或警告           | Shift+Alt+F8        | Shift+F2        | editor.action.marker.prev              |
| 显示所有命令               | Ctrl+Shift+P Ctrl Ctrl                                                 | Ctrl+Shift+P Ctrl Ctrl        | omnisearch.open.command                |
| 回退                   | Alt+Left        | Ctrl+Alt+Left        | workbench.action.navigateBack          |
| 前进                   | Alt+Right        | Ctrl+Alt+Right        | workbench.action.navigateForward       |
| 打开Settings           | Ctrl+,        | Ctrl+,        | workbench.action.openSettings          |
| 打开Keyboard Shortcuts | Ctrl+K Ctrl+S        | Ctrl+K Ctrl+S        | workbench.action.openGlobalKeybindings |
| 选择Color Theme        | Ctrl+K Ctrl+T        | Ctrl+\`        | workbench.action.selectTheme           |
