# 查看菜单快捷键
在CodeArts IDE编辑器界面，在**查看(V)**菜单下，可以使用如下快捷键。如下图所示：
图1查看菜单快捷键
![](https://support.huaweicloud.com/usermanual-codeartside/zh-cn_image_0000002337001210.png "点击放大")
表1**查看** 菜单快捷键
| 命令    | 键（CodeArts IDE键盘映射）        | 键（IDEA键盘映射）        | 命令ID                                     |
| 工程    | Ctrl+Shift+E        | Alt+1        | workbench.view.explorer                  |
| 源代码管理 | Ctrl+Shift+G        | Alt+9        | workbench.view.scm                       |
| 扩展    | Ctrl+Shift+X        | Ctrl+Shift+X        | workbench.view.extensions                |
| 问题    | Ctrl+Shift+M        | Shift+Escape Alt+0        | workbench.actions.view.problems          |
| 输出    | Ctrl+Shift+U        | Ctrl+Shift+U        | workbench.action.output.toggleOutput     |
| 调试控制台 | Ctrl+Shift+Y        | Shift+Escape        | workbench.debug.action.toggleRepl        |
| 运行    | Ctrl+Shift+D        | Shift+Alt+F9 Ctrl+Shift+F8 Alt+5        | workbench.view.debug                     |
| 终端    | Ctrl+\`        | Shift+Escape Alt+F12        | workbench.action.terminal.toggleTerminal |
| 自动换行  | Alt+Z        | Alt+Z        | editor.action.toggleWordWrap             |
| 全屏    | F11        | Ctrl+Alt+F        | workbench.action.toggleFullScreen        |
| 禅模式   | Ctrl+K Z        | Ctrl+K Z        | workbench.action.toggleZenMode           |
| 显示右侧栏 | Ctrl+Alt+B        | Ctrl+Alt+B        | workbench.action.toggleAuxiliaryBar      |
| 显示左侧栏 | Ctrl+B        | Shift+Escape Alt+1 Alt+3 Ctrl+Shift+F8 Alt+9 | workbench.action.toggleSidebarVisibility |
| 放大    | Ctrl+Numpad+ Ctrl+Shift+= Ctrl+=  | Ctrl+Numpad+ Ctrl+Shift+= Ctrl+=        | workbench.action.zoomIn                  |
| 缩小    | Ctrl+Numpad- Ctrl+Shift+- Ctrl+- | Ctrl+Numpad- Ctrl+Shift+- Ctrl+-        | workbench.action.zoomOut                 |
| 重置缩放  | Ctrl+Numpad0        | Ctrl+Numpad0        | workbench.action.zoomReset               |
