文档首页 > > 用户指南> 混合云备份> VMware备份> 配置eBackup> 配置备份服务器
配置备份服务器
更新时间: 2019/10/29 GMT+08:00
将一台安装了eBackup备份软件的服务器初始化为备份服务器,并配置相关参数。
前提条件
  • 安装前准备请提前规划备份服务器的相关网络平面参数。
  • 已准备跨平台远程访问工具如“PuTTY”。
  • 已获取eBackup服务器“root”帐号的登录密码。
  1. “root”帐号登录待配置的eBackup服务器。
    “root”帐号初始密码为“Cloud12#$”
    使用跨平台访问工具登录,或在VMware vSphere Client工具中的控制台登录。
  2. 执行cd 备份软件安装包所在目录命令进入初始配置脚本目录。
    备份软件安装包所在目录为/opt/eBackup_8.0.0-LHC01/action。
  3. 执行sh ebackup_utilities.sh config命令,开始进行初始化配置。
    回显如下信息。
    Please select network type for this machine:
     1.ipv4
     2.ipv6
  4. 输入“1”,按“Enter”。
    Please select a role for this machine:
     1.Backup Server
     2.Backup Proxy
     3.Backup Manager
     4.Backup Workflow Server
  5. 输入“1”,按“Enter”。
    Note:
    In the following steps you will be required to configure four network planes for eBackup.
    The definition of each network plane is as follows:
    Backup management plane: the communication plane for eBackup to provide external services.
    Internal communication plane: the communication plane between backup server and backup proxy.
    Production management plane: the communication plane between eBackup and the management plane of the production end.
    Storage plane: the communication plane between eBackup and the storage plane of the production end and communication plane between eBackup and backup storage.
    Set network adapter for 'Backup management' network plane:
    [1] bond1 MAC=28:6E:D4:88:C6:F2 IP=10.158.199.79 MASK=255.255.254.0
    [2] bond2 MAC=28:6E:D4:88:C6:F3 IP=172.16.199.79 MASK=255.255.254.0
    [3] bond3 MAC=28:6E:D4:88:C6:F4 IP=192.168.0.111 MASK=255.255.254.0
    Which network adapter from the above list would you like to bind to the 'Backup management' network plane?
  1. 配置备份服务器网络平面。
    为确保eBackup备份软件正常且安全的运行,需要且必须配置以下五个网络平面。
    1. 选择备份管理平面需要绑定的网卡,按“Enter”。
      如果选择bond1作为备份管理平面需要绑定的网卡,请输入“1”。
      Set network adapter for 'Internal communication' network plane:
      Which network adapter from the above list would you like to bind to the 'Internal communication' network plane?
    2. 选择内部通信平面需要绑定的网卡,按“Enter”。
      Set network adapter for 'Production management' network plane:
      Which network adapter from the above list would you like to bind to the 'Production management' network plane?
    3. 选择生产管理平面需要绑定的网卡,按“Enter”。
      Set network adapter for 'Production Storage' network plane:
      Which network adapter from the above list would you like to bind to the 'Production Storage' network plane?
    4. 选择生产存储平面需要绑定的网卡,按“Enter”。
      2
      Set network adapter for 'Backup Storage' network plane:
      Which network adapter from the above list would you like to bind to the 'Backup Storage' network plane?
    5. 选择备份存储平面需要绑定的网卡,按“Enter”。
      3
      Enter a floating IP address that is in the same network segment as the internal communication plane.
    6. 设置浮动IP地址。
      浮动IP地址为内部通信平面浮动IP地址。请确保浮动IP地址跟内部通信平面IP地址在同一网段中,且未被使用。
      回显如下信息,表示配置成功。
      10.158.199.85
      Configuration succeeded.
      grep: this version of PCRE is compiled without UTF support
      The ebk_accelerator agent of OceanStor BCManager eBackup was started successfully.
      Start:ebk_accelerator service succeeded.
      start reload gaussdb
      The ebk_backup agent of OceanStor BCManager eBackup was started successfully.
      Start:ebk_backup service succeeded.
      The ebk_copy agent of OceanStor BCManager eBackup was started successfully.
      Start:ebk_copy service succeeded.
      The ebk_delete agent of OceanStor BCManager eBackup was started successfully.
      Start:ebk_delete service succeeded.
      The ebk_mgr agent of OceanStor BCManager eBackup was started successfully.
      Start:ebk_mgr service succeeded.
      The ebk_restore agent of OceanStor BCManager eBackup was started successfully.
      Start:ebk_restore service succeeded.
      The ebk_vmware agent of OceanStor BCManager eBackup was started successfully.
      Start:ebk_vmware service succeeded.
      service hcp start:completed
      You can access the eBackup UI using the following link.
       https://10.158.199.79:8088 or 10.158.199.79
      Alternatively, you can access the eBackup CLI through SSH session.
  2. 依次执行以下命令进行安全加固。
    加固后禁止使用“root”帐号直接登录,请使用“hcp”帐号登录,“hcp”帐号的初始密码为“PXU9@ctuNov17!”
    cd /opt/huawei-data-protection/ebackup/bin/StandardHardening
    echo -e "yes\nyes\n"|./StandardSuseHardening.sh
    执行该命令会重启eBackup服务器,如需登录eBackup服务器请您稍后重试。
分享:
    相关产品
文档是否有解决您的问题?
提交成功!
非常感谢您的反馈,我们会继续努力做到更好!
反馈提交失败,请稍后再试!
*必选
请至少选择或填写一项反馈信息
字符长度不能超过200
提交反馈 取消
跳转到云社区
