# x-apigateway-backend-policies
**含义**：API网关定义的API后端策略。
**作用域** ：[Operation Object(2.0)](https://github.com/OAI/OpenAPI-Specification/blob/master/versions/2.0.md#operation-object)/[Operation Object(3.0)](https://github.com/OAI/OpenAPI-Specification/blob/main/versions/3.0.0.md#operation-object)
**示例**：
paths:
  '/users/{userId}':
    get:
      produces:
        - "application/json"
      responses:
        default:
          description: "default response"
      x-apigateway-request-type: "public"
      x-apigateway-backend:
        type: "backend endpoint type"
      x-apigateway-backend-policies:
        - type: "backend endpoint type"
          name: "backend policy name"
          conditions:
            - type: "equal/enum/pattern",
              value: "string",
              origin: "source/request_parameter",
              parameter_name: "string"
表1参数说明
| 参数                            | 是否必选 | 类型        | 说明        |
| x-apigateway-backend-policies | 否    | x-apigateway-backend-policies        | 策略后端。        |
| type                          | 是    | String        | 后端服务类型，支持HTTP、HTTP-VPC、FUNCTION、MOCK、HTTP-VPC-MEMBER-GROUP。        |
| name                          | 是    | String        | 后端策略名称。        |
| parameters                    | 否    | [x-apigateway-backend.parameters](https://support.huaweicloud.com/usermanual-apig/apig_03_0091.html)                  | 后端参数定义。        |
| httpEndpoints                 | 否    | [x-apigateway-backend.httpEndpoints](https://support.huaweicloud.com/usermanual-apig/apig_03_0092.html)               | HTTP类型服务定义。        |
| httpVpcEndpoints              | 否    | [x-apigateway-backend.httpVpcEndpoints](https://support.huaweicloud.com/usermanual-apig/apig_03_0093.html)            | HTTP-VPC类型服务定义。        |
| functionEndpoints             | 否    | [x-apigateway-backend.functionEndpoints](https://support.huaweicloud.com/usermanual-apig/apig_03_0094.html)           | FUNCTION类型服务定义。        |
| mockEndpoints                 | 否    | [x-apigateway-backend.mockEndpoints](https://support.huaweicloud.com/usermanual-apig/apig_03_0095.html)               | MOCK类型服务定义。        |
| conditions                    | 是    | [x-apigateway-backend-policies.conditions](https://support.huaweicloud.com/usermanual-apig/apig_03_0097.html)         | 策略条件数组。        |
| httpVpcMemberGroupEndpoints   | 否    | [x-apigateway-backend.httpVpcMemberGroupEndpoints](https://support.huaweicloud.com/usermanual-apig/apig_03_0093.html) | HTTP-VPC-MEMBER-GROUP类型后端服务定义。 httpVpcMemberGroupEndpoints参数受限使用，如需使用，请[提交工单](https://support.huaweicloud.com/usermanual-ticket/zh-cn_topic_0127038618.html)开通。 |
