# 价格预估
进入创建成功的执行计划页面，会在界面上看到"查看费用明细"按钮，如[图1] ，单击后服务会进行价格预估并展示价格预估结果，如[图2]
图1查看费用明细
![](https://support.huaweicloud.com/usermanual-aos/figure/zh-cn_image_0000001515275437.png)
图2费用明细
![](https://support.huaweicloud.com/usermanual-aos/figure/zh-cn_image_0000001464675618.png)
费用明细页面分包年/包月，如[图3]，按需计费如[图4]，待支持如[图5]三个类别展示资源价格。
包年/包月类、按需计费类展示按照包年/包月，按需计费方式购买的资源，待支持类展示暂不支持预估价格资源的列表，
目前支持预估价格的资源列表如[表1]。
图3包年包月
![](https://support.huaweicloud.com/usermanual-aos/figure/zh-cn_image_0000001467982209.png)
图4按需计费
![](https://support.huaweicloud.com/usermanual-aos/figure/zh-cn_image_0000001514875529.png)
图5待支持
![](https://support.huaweicloud.com/usermanual-aos/figure/zh-cn_image_0000001631506512.png)
 表1已支持预估价格的云服务资源与计费方式
| 云服务        | 资源类型        | 计费方式   |
| EVS（Elastic Volume Service）云硬盘        | [huaweicloud_evs_volume](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/evs_volume#region)                                  | 包周期和按需 |
| NAT（Network Address Translation）网关                                                             | [huaweicloud_nat_gateway](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/nat_gateway)                                       | 按需     |
| ELB（Elastic Load Balance）弹性负载均衡           | [huaweicloud_elb_loadbalancer](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/elb_loadbalancer)                             | 按需     |
| ELB（Elastic Load Balance）弹性负载均衡           | [huaweicloud_lb_loadbalancer](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/data-sources/lb_loadbalancer)                            | 包周期和按需 |
| ELB（Elastic Load Balance）弹性负载均衡           | [huaweicloud_elb_listener](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/elb_listener)                                     | 免费     |
| ELB（Elastic Load Balance）弹性负载均衡           | [huaweicloud_elb_monitor](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/elb_monitor)                                       | 免费     |
| ELB（Elastic Load Balance）弹性负载均衡           | [huaweicloud_elb_pool](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/elb_pool)                                             | 免费     |
| ELB（Elastic Load Balance）弹性负载均衡           | [huaweicloud_elb_member](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/elb_member)                                         | 免费     |
| ECS（Elastic Cloud Server）弹性云服务器        | [huaweicloud_compute_instance](https://registry.terraform.io/providers/huaweicloud/huaweicloud/1.78.4/docs/resources/compute_instance)                             | 包周期和按需 |
| CCE（Cloud Container Engine）云容器引擎          | [huaweicloud_cce_cluster](https://registry.terraform.io/providers/huaweicloud/huaweicloud/1.78.4/docs/resources/cce_cluster)                                       | 包周期和按需 |
| CCE（Cloud Container Engine）云容器引擎          | [huaweicloud_cce_node](https://registry.terraform.io/providers/huaweicloud/huaweicloud/1.78.4/docs/resources/cce_node)                                             | 包周期和按需 |
| GaussDB 云数据库                       | [huaweicloud_gaussdb_mysql_instance](https://registry.terraform.io/providers/huaweicloud/huaweicloud/1.78.4/docs/resources/gaussdb_mysql_instance)                 | 包周期和按需 |
| GaussDB 云数据库                       | [huaweicloud_gaussdb_opengauss_instance](https://registry.terraform.io/providers/huaweicloud/huaweicloud/1.78.4/docs/resources/gaussdb_opengauss_instance)         | 包周期和按需 |
| GaussDB 云数据库                       | [huaweicloud_gaussdb_redis_instance](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/gaussdb_redis_instance)                 | 包周期和按需 |
| RDS（Relational Database Service）云数据库     | [huaweicloud_rds_instance](https://registry.terraform.io/providers/huaweicloud/huaweicloud/1.78.4/docs/resources/rds_instance)                                     | 包周期和按需 |
| RDS（Relational Database Service）云数据库     | [huaweicloud_rds_read_replica_instance](https://registry.terraform.io/providers/huaweicloud/huaweicloud/1.78.4/docs/resources/rds_read_replica_instance)           | 包周期和按需 |
| CSS（Cloud Search Service）云搜索服务        | [huaweicloud_css_cluster](https://registry.terraform.io/providers/huaweicloud/huaweicloud/1.78.4/docs/resources/css_cluster)                                       | 按需     |
| EIP（Elastic IP）弹性公网IP                    | [huaweicloud_vpc_eip](https://registry.terraform.io/providers/huaweicloud/huaweicloud/1.78.4/docs/resources/vpc_eip)                                               | 包周期和按需 |
| EIP（Elastic IP）弹性公网IP                    | [huaweicloud_vpc_bandwidth](https://registry.terraform.io/providers/huaweicloud/huaweicloud/1.78.4/docs/resources/vpc_bandwidth)                                   | 包周期和按需 |
| VPC（Virtual Private Cloud）虚拟私有云          | [huaweicloud_vpc](https://registry.terraform.io/providers/huaweicloud/huaweicloud/1.78.4/docs/resources/vpc)                                                       | 免费     |
| VPC（Virtual Private Cloud）虚拟私有云          | [huaweicloud_vpc_subnet](https://registry.terraform.io/providers/huaweicloud/huaweicloud/1.78.4/docs/resources/vpc_subnet)                                         | 免费     |
| VPC（Virtual Private Cloud）虚拟私有云          | [huaweicloud_networking_secgroup](https://registry.terraform.io/providers/huaweicloud/huaweicloud/1.78.4/docs/resources/networking_secgroup)                       | 免费     |
| SFS（Scalable File Service）弹性文件服务                                                               | [huaweicloud_sfs_turbo](https://registry.terraform.io/providers/huaweicloud/huaweicloud/1.78.4/docs/resources/sfs_turbo)                                           | 按需     |
| DMS（Distributed Message Service）分布式消息服务   | [huaweicloud_dms_kafka_instance](https://registry.terraform.io/providers/huaweicloud/huaweicloud/1.78.4/docs/resources/dms_kafka_instance)                         | 按需     |
| DMS（Distributed Message Service）分布式消息服务   | [huaweicloud_dms_rabbitmq_instance](https://registry.terraform.io/providers/huaweicloud/huaweicloud/1.78.4/docs/resources/dms_rabbitmq_instance)                   | 包周期和按需 |
| DMS（Distributed Message Service）分布式消息服务   | [huaweicloud_dms_rocketmq_instance](https://registry.terraform.io/providers/huaweicloud/huaweicloud/1.78.4/docs/resources/dms_rocketmq_instance)                   | 包周期和按需 |
| DCS（Distributed Cache Service）分布式缓存服务                                                          | [huaweicloud_dcs_instance](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/dcs_instance)                                     | 包周期和按需 |
| DRS（Data Replication Service）数据复制服务                                                            | [huaweicloud_drs_job](https://registry.terraform.io/providers/huaweicloud/huaweicloud/1.78.4/docs/resources/drs_job)                                               | 按需     |
| OBS（Object Storage Service）对象存储服务        | [huaweicloud_obs_bucket](https://registry.terraform.io/providers/huaweicloud/huaweicloud/1.78.4/docs/resources/obs_bucket)                                         | 免费     |
| OBS（Object Storage Service）对象存储服务        | [huaweicloud_obs_bucket_replication](https://registry.terraform.io/providers/huaweicloud/huaweicloud/1.78.4/docs/resources/obs_bucket_replication)                 | 免费     |
| APIG（API Gateway）API网关        | [huaweicloud_apig_instance](https://registry.terraform.io/providers/huaweicloud/huaweicloud/1.78.4/docs/resources/apig_instance)                                   | 按需     |
| IEC（Intelligent EdgeCloud）智能边缘云        | [huaweicloud_iec_security_group](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/iec_security_group)                         | 免费     |
| CBH（Cloud Bastion Host）云堡垒机               | [huaweicloud_cbh_instance](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/cbh_instance)                                     | 包周期    |
| CBH（Cloud Bastion Host）云堡垒机               | [huaweicloud_cbh_ha_instance](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/cbh_ha_instance)                               | 包周期    |
| WAF（Web Application Firewall）Web应用防火墙                                                          | [huaweicloud_waf_cloud_instance](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/waf_cloud_instance)                         | 包周期    |
| CBR（Cloud Backup and Recovery）云备份                                                              | [huaweicloud_cbr_vault](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/cbr_vault)                                           | 包周期和按需 |
| ADD（Anti-DDoS）流量清洗服务          | [huaweicloud_antiddos_basic](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/antiddos_basic)                                 | 免费     |
| ADD（Anti-DDoS）流量清洗服务          | [huaweicloud_cnad_advanced_black_white_list](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/cnad_advanced_black_white_list) | 免费     |
| ADD（Anti-DDoS）流量清洗服务          | [huaweicloud_cnad_advanced_policy](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/cnad_advanced_policy)                     | 免费     |
| ADD（Anti-DDoS）流量清洗服务          | [huaweicloud_cnad_advanced_protected_object](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/cnad_advanced_protected_object) | 免费     |
| HSS（Host Security Service）企业主机安全         | [huaweicloud_hss_host_protection](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/hss_host_protection)                       | 按需     |
| HSS（Host Security Service）企业主机安全         | [huaweicloud_hss_quota](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/hss_quota)                                           | 包周期    |
| ModelArts AI开发平台        | [huaweicloud_modelarts_resource_pool](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/modelarts_resource_pool)               | 包周期和按需 |
| Workspace 云桌面        | [huaweicloud_workspace_desktop](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/workspace_desktop)                           | 按需     |
| DWS（Data Warehouse Service）数据仓库服务   | [huaweicloud_dws_cluster](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/dws_cluster)                                       | 按需     |
| DWS（Data Warehouse Service）数据仓库服务   | [huaweicloud_dws_ext_data_source](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/dws_ext_data_source)                       | 免费     |
| DWS（Data Warehouse Service）数据仓库服务   | [huaweicloud_dws_snapshot](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/dws_snapshot)                                     | 免费     |
| DNS（Domain Name Service）云解析服务        | [huaweicloud_dns_zone](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/dns_zone)                                             | 免费     |
| EPS（Enterprise Project Management Service）企业项目管理                                               | [huaweicloud_enterprise_project](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/enterprise_project)                         | 免费     |
| ER（Enterprise Router）企业路由器        | [huaweicloud_er_instance](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/er_instance)                                       | 免费     |
| LTS（Log Tank Service）云日志服务        | [huaweicloud_lts_group](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/lts_group)                                           | 免费     |
| SMN（Simple Message Notification）消息通知服务    | [huaweicloud_smn_topic](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/smn_topic)                                           | 免费     |
| SMN（Simple Message Notification）消息通知服务    | [huaweicloud_smn_subscription](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/smn_subscription)                             | 免费     |
| CC（Cloud Connect）云连接                     | [huaweicloud_cc_connection](https://registry.terraform.io/providers/huaweicloud/huaweicloud/1.78.4/docs/resources/cc_connection)                                   | 免费     |
| CC（Cloud Connect）云连接                     | [huaweicloud_cc_network_instance](https://registry.terraform.io/providers/huaweicloud/huaweicloud/1.78.4/docs/resources/cc_network_instance)                       | 免费     |
| DDS（Document Database Service）文档数据库服务                                                          | [huaweicloud_dds_instance](https://registry.terraform.io/providers/huaweicloud/huaweicloud/1.78.4/docs/resources/dds_instance)                                     | 包周期和按需 |
| DEW（Data Encryption Workshop）密码安全中心                                                            | [huaweicloud_kms_key](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/kms_key)                                               | 按需     |
| VPCEP（VPC Endpoint）VPC终端节点        | [huaweicloud_vpcep_endpoint](https://registry.terraform.io/providers/huaweicloud/huaweicloud/latest/docs/resources/vpcep_endpoint)                                 | 按需     |
![](https://support.huaweicloud.com/usermanual-aos/public_sys-resources/caution_3.0-zh-cn.png)
用于预估价格的模板中没有填入预估价格服务必须的字段或填入不合法字段时会导致价格预估失败。
服务在完成询价后，执行计划详情也会在基本信息中展示出费用预估情况，如[图6]
图6执行计划详情
![](https://support.huaweicloud.com/usermanual-aos/figure/zh-cn_image_0000001515276073.png)
