# 标准输出配置
通过添加指定采集容器标准输出标签，用户可以指定采集pod下的对应容器名的标准输出日志。用户在pod的yaml中spec:template:metadata:annotations:字段增加以下字段来实现指定要采集的容器名称。
kubernetes.AOM.log.stdout: '\["container_name0", "container_name1"\]'
规则如下:
1. 如果没有kubernetes.AOM.log.stdout:字段，默认采集该pod下全部容器的标准输出日志，兼容原有场景。
2. 如果存在该字段，值为空，即kubernetes.AOM.log.stdout: '\[\]'则不采集该pod下容器的标准输出日志。
示例：
  replicas: 1
  selector:
    matchLabels:
      app: als729
      version: v1
  template:
      creationTimestamp: null
      labels:
        app: als729
        version: v1
      annotations:
        kubernetes.AOM.log.relabel: '{"key1":"value1","key2":"value2","key3":"value3","key4":"value4","key5":"value5","key6":"value6","key7":"value7","key8":"value8","key9":"value9","key10":"value10","key11":"value11","key12":"value12","key13":"value13","key14":"value14","key15":"value16"}'
        kubernetes.AOM.log.stdout: '["container-0","container_name1"]'
