# java.sql.Statement
java.sql.Statement是SQL语句接口。
表1对java.sql.Statement的支持情况
| 方法名 | 返回值类型 | 支持JDBC 4 |
| executeQuery(String)                                 | ResultSet                                            | Yes                                                     |
| executeUpdate(String)                               | int                                                   | Yes                                                      |
| execute(String)                                      | boolean                                               | Yes                                                      |
| close()                                            | void                                                    | Yes                                                      |
| getMaxFieldSize()                                   | int                                                   | Yes                                                       |
| setMaxFieldSize(int)                                | void                                                 | Yes                                                     |
| getMaxRows()                                         | int                                                   | Yes                                                      |
| setMaxRows(int)                                       | void                                                 | Yes                                                       |
| setEscapeProcessing(boolean)                         | void                                                   | Yes                                                      |
| getQueryTimeout()                                  | int                                                    | Yes                                                       |
| setQueryTimeout(int)                                 | void                                                    | Yes                                                      |
| cancel()                                           | void                                                   | Yes                                                     |
| getWarnings()                                       | SQLWarning                                            | Yes                                                      |
| clearWarnings()                                    | void                                                | Yes                                                       |
| setCursorName(String)                              | void                                                  | No                                                      |
| getResultSet()                                        | ResultSet                                             | Yes                                                      |
| getUpdateCount()                                    | int                                                   | Yes                                                      |
| getLargeUpdateCount()                               | long                                                   | Yes                                                     |
| getMoreResults()                                     | boolean                                              | Yes                                                      |
| getMoreResults(int)                                | boolean                                                | Yes                                                     |
| getFetchDirection()                                | int                                                   | Yes                                                      |
| setFetchDirection(int)                               | void                                                 | No                                                         |
| getFetchSize()                                      | int                                                    | Yes                                                      |
| setFetchSize(int)                                    | void                                                   | Yes                                                      |
| getResultSetConcurrency()                            | int                                                  | Yes                                                     |
| getResultSetType()                                   | int                                                  | Yes                                                      |
| addBatch(String)                                    | void                                                  | Yes                                                      |
| clearBatch()                                          | void                                                 | Yes                                                     |
| executeBatch()                                     | int\[\]                                                | Yes                                                      |
| getConnection()                                     | Connection                                             | Yes                                                     |
| getGeneratedKeys()                                  | ResultSet                                             | No                                                     |
| getResultSetHoldability()                           | int                                                  | Yes                                                    |
| isClosed()                                          | boolean                                               | Yes                                                     |
| setPoolable(boolean)                               | void                                                  | Yes                                                      |
| isPoolable()                                        | boolean                                                | Yes                                                      |
| closeOnCompletion()                                  | void                                                  | Yes                                                     |
| isCloseOnCompletion()                              | boolean                                              | Yes                                                       |
| unwrap(Class)                                       | T                                                     | Yes                                                        |
| isWrapperFor(Class)                                  | boolean                                              | Yes                                                      |
![](https://support.huaweicloud.com/usermanual-aidatalake/public_sys-resources/note_3.0-zh-cn.png)
通过setFetchSize可以减少结果集在客户端的内存占用情况。它的原理是通过将结果集打包成游标，然后分段处理，所以会加大数据库与客户端的通信量，会有性能损耗。
由于数据库游标是事务内有效，所以，在设置setFetchSize的同时，需要将连接设置为非自动提交模式，setAutoCommit(false)。同时在业务数据需要持久化到数据库中时，在连接上执行提交操作。
