# java.sql.DatabaseMetaData
java.sql.DatabaseMetaData是数据库对象定义接口。
表1对java.sql.DatabaseMetaData的支持情况
| 方法名 | 返回值类型 | 支持JDBC 4 |
| getURL()                                            | String                                                 | Yes                                                     |
| getUserName()                                      | String                                                  | Yes                                                      |
| isReadOnly()                                         | boolean                                                | Yes                                                    |
| getDatabaseProductName()                           | String                                                  | Yes                                                     |
| getDatabaseProductVersion()                          | String                                                | Yes                                                      |
| getDriverName()                                     | String                                                | Yes                                                      |
| getDriverVersion()                                  | String                                                | Yes                                                      |
| getDriverMajorVersion()                               | int                                                     | Yes                                                        |
| getDriverMinorVersion()                              | int                                                  | Yes                                                      |
| usesLocalFiles()                                     | boolean                                              | Yes                                                     |
| usesLocalFilePerTable()                             | boolean                                                | Yes                                                       |
| storesLowerCaseIdentifiers()                       | boolean                                              | Yes                                                     |
| supportsMixedCaseQuotedIdentifiers()                  | boolean                                             | Yes                                                      |
| getIdentifierQuoteString()                            | String                                                | Yes                                                     |
| getSQLKeywords()                                    | String                                                | Yes                                                      |
| getNumericFunctions()                             | String                                              | Yes                                                      |
| getStringFunctions()                                | String                                                  | Yes                                                       |
| getSystemFunctions()                                | String                                               | Yes                                                      |
| getTimeDateFunctions()                             | String                                                 | Yes                                                      |
| getSearchStringEscape()                             | String                                              | Yes                                                       |
| getMaxColumnsInTable()                              | int                                                     | Yes                                                      |
| getMaxConnections()                                  | int                                                   | Yes                                                     |
| getMaxRowSize()                                     | int                                                  | Yes                                                     |
| getDefaultTransactionIsolation()                  | int                                                  | Yes                                                       |
| supportsTransactionIsolationLevel(int)             | boolean                                                | Yes                                                     |
| supportsBatchUpdates()                              | boolean                                               | Yes                                                       |
| getTables(...)                                     | ResultSet                                               | Yes                                                      |
| getCatalogs()                                     | ResultSet                                             | Yes                                                     |
| getTableTypes()                                     | ResultSet                                            | Yes                                                     |
| getColumns(...)                                    | ResultSet                                              | Yes                                                     |
| getSchemas()                                        | ResultSet                                             | Yes                                                       |
| getSchemas(String, String)                         | ResultSet                                            | Yes                                                       |
| getConnection()                                   | Connection                                            | Yes                                                      |
| supportsResultSetType(int)                         | boolean                                                 | Yes                                                      |
| supportsResultSetConcurrency(int, int)             | boolean                                              | Yes                                                     |
| getResultSetHoldability()                          | int                                                   | Yes                                                        |
| supportsResultSetHoldability(int)                    | boolean                                                 | Yes                                                        |
| getJDBCMajorVersion()                               | int                                                  | Yes                                                      |
| getJDBCMinorVersion()                              | int                                                  | Yes                                                      |
| unwrap(Class)                                        | T                                                    | Yes                                                     |
| isWrapperFor(Class)                                 | boolean                                                 | Yes                                                     |
| getProcedures(...)                                  | ResultSet                                            | No                                                       |
| getProcedureColumns(...)                           | ResultSet                                             | No                                                        |
| getColumnPrivileges(...)                             | ResultSet                                             | No                                                       |
| getTablePrivileges(...)                           | ResultSet                                              | No                                                       |
| getBestRowIdentifier(...)                           | ResultSet                                             | No                                                      |
| getVersionColumns(...)                               | ResultSet                                            | No                                                       |
| getPrimaryKeys(...)                                 | ResultSet                                               | No                                                      |
| getImportedKeys(...)                               | ResultSet                                               | No                                                       |
| getExportedKeys(...)                               | ResultSet                                           | No                                                       |
| getCrossReference(...)                             | ResultSet                                              | No                                                         |
| getTypeInfo()                                      | ResultSet                                             | No                                                       |
| getIndexInfo(...)                                 | ResultSet                                            | No                                                       |
| getUDTs(...)                                       | ResultSet                                              | No                                                        |
| getSuperTypes(...)                                   | ResultSet                                            | No                                                     |
| getSuperTables(...)                                  | ResultSet                                               | No                                                        |
| getAttributes(...)                                 | ResultSet                                            | No                                                       |
| getClientInfoProperties()                          | ResultSet                                            | No                                                       |
| getFunctions(...)                                   | ResultSet                                            | No                                                       |
| getFunctionColumns(...)                             | ResultSet                                             | No                                                       |
| getPseudoColumns(...)                              | ResultSet                                             | No                                                       |
