# 修改表的自增AUTO_INCREMENT值
AUTO_INCREMENT修改时，遵循如下约束限制：
1. 当AUTO_INCREMENT大于表中数据的最大值时，可以在取值范围内任意修改为更大的值。
   show create table animals;
   | Table   | Create Table                                                     |
   | animals | CREATE TABLE `animals` (
   `id` mediumint NOT NULL AUTO_INCREMENT,   `name` char(30) NOT NULL,
   PRIMARY KEY (`id`) ) ENGINE=InnoDB AUTO_INCREMENT=101 DEFAULT CHARSET=utf8   |
   1 row in set (0.00 sec)
   mysql> select * from animals;
   | id  | name      |
   | -50 | -middle   |
   |   1 | dog       |
   |   2 | cat       |
   |  50 | middle    |
   | 100 | rabbit    |
   11 rows in set (0.00 sec)
   alter table animals AUTO_INCREMENT=200;
   Query OK, 0 rows affected (0.22 sec)
   Records: 0  Duplicates: 0  Warnings: 0
   PRIMARY KEY (`id`) ) ENGINE=InnoDB AUTO_INCREMENT=200 DEFAULT CHARSET=utf8 |
2. 当AUTO_INCREMENT大于表中数据的最大值时，如果修改后的指定值仍大于数据的最大值，则修改为指定值成功。否则，默认会修改为数据最大值+1。
   | id  | name      |
   | -50 | -middle   |
   |   1 | dog       |
   |   2 | cat       |
   |  50 | middle    |
   | 100 | rabbit    |
   mysql> show create table animals;
   mysql> alter table animals AUTO_INCREMENT=150;
   Query OK, 0 rows affected (0.05 sec)
   PRIMARY KEY (`id`) ) ENGINE=InnoDB AUTO_INCREMENT=150 DEFAULT CHARSET=utf8 |
   mysql> alter table animals AUTO_INCREMENT=50;
   Query OK, 0 rows affected (0.04 sec)
   mysql> delete from animals where id=100;
   Query OK, 1 row affected (0.00 sec)
   | id  | name      |
   | -50 | -middle   |
   |   1 | dog       |
   |   2 | cat       |
   |  50 | middle    |
   10 rows in set (0.00 sec)
   PRIMARY KEY (`id`) ) ENGINE=InnoDB AUTO_INCREMENT=51 DEFAULT CHARSET=utf8 |
3. AUTO_INCREMENT无法修改为负数。
   alter table animals AUTO_INCREMENT=-1;
   ERROR 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '-1' at line 1
