# 自增字段值跳变的原因
数据表中的自增字段取值不是连续的，自增值跳变。
出现表中的自增字段取值不连续的情况，可能原因有以下几种：
- 初值与步长问题，步长不为1会导致自增字段取值不连续。
  mysql> show variables like 'auto_inc%';
  | Variable_name            | Value |
  | auto_increment_increment | 2     |
  | auto_increment_offset    | 1     |
  mysql> select * from auto_test1;
  | id |
  |  2 |
  |  4 |
  |  6 |
  |  8 |
- 直接修改表的AUTO_INCREMENT，会导致自增字段取值跳变。
  mysql> select * from animals;
  | id | name      |
  |  1 | dog       |
  |  2 | cat       |
  |  3 | penguin   |
  mysql> show create table animals;
  | Table   | Create Table                                                   |
  | animals | CREATE TABLE `animals` (
  `id` mediumint NOT NULL AUTO_INCREMENT,
  `name` char(30) NOT NULL,
  PRIMARY KEY (`id`) )
  ENGINE=InnoDB AUTO_INCREMENT=4 DEFAULT CHARSET=utf8 |
  mysql> alter table animals AUTO_INCREMENT=100;
  Query OK, 0 rows affected (0.04 sec)
  Records: 0  Duplicates: 0  Warnings: 0
  PRIMARY KEY (`id`)
  ) ENGINE=InnoDB AUTO_INCREMENT=100 DEFAULT CHARSET=utf8         |
  mysql> INSERT INTO animals (id,name) VALUES(0,'rabbit');
  Query OK, 1 row affected (0.00 sec)
  | id  | name      |
  |   1 | dog       |
  |   2 | cat       |
  |   3 | penguin   |
  | 100 | rabbit    |
  9 rows in set (0.00 sec)
- 插入数据时直接指定自增字段的取值，会导致自增字段取值跳变。
  | id | name      |
  |  1 | dog       |
  |  2 | cat       |
  |  3 | penguin   |
  mysql> INSERT INTO animals (id,name) VALUES(100,'rabbit');
  | id  | name      |
  |   1 | dog       |
  |   2 | cat       |
  |   3 | penguin   |
  | 100 | rabbit    |
- 未提交的事务或回滚的事务，会导致AUTO_INCREMENT增长，但回滚后不会下降。后续如果再次插入数据就会导致数据中的自增字段发生跳变。
  mysql> show create table auto_test1;
  | auto_test1 | CREATE TABLE `auto_test1` (
  `id` int NOT NULL AUTO_INCREMENT,
  PRIMARY KEY (`id`)
  ) ENGINE=InnoDB AUTO_INCREMENT=4 DEFAULT CHARSET=utf8 |
  1 row in set (0.00 sec)
  | id |
  |  1 |
  |  2 |
  |  3 |
  mysql> begin;
  Query OK, 0 rows affected (0.02 sec)
  mysql> insert into auto_test1 values (0),(0),(0);
  Query OK, 3 rows affected (0.00 sec)
  Records: 3  Duplicates: 0  Warnings: 0
  | id |
  |  1 |
  |  2 |
  |  3 |
  |  4 |
  |  5 |
  |  6 |
  6 rows in set (0.00 sec)
  | auto_test1 |
  PRIMARY KEY (`id`)
  ) ENGINE=InnoDB AUTO_INCREMENT=7 DEFAULT CHARSET=utf8 |
  mysql> rollback;
  Query OK, 0 rows affected (0.05 sec)
  | id |
  |  1 |
  |  2 |
  |  3 |
  3 rows in set (0.00 sec)
  PRIMARY KEY (`id`)
  Query OK, 3 rows affected (0.01 sec)
  | id |
  |  1 |
  |  2 |
  |  3 |
  |  7 |
  |  8 |
  |  9 |
  PRIMARY KEY (`id`)
  ) ENGINE=InnoDB AUTO_INCREMENT=10 DEFAULT CHARSET=utf8 |
- 数据插入后，AUTO_INCREMENT变化，然后删除对应的数据行，AUTO_INCREMENT不会下降，后续如果再次插入数据就会导致数据中的自增字段发生跳变。
  PRIMARY KEY (`id`)
  | id |
  |  1 |
  |  2 |
  |  3 |
  | id |
  |  1 |
  |  2 |
  |  3 |
  |  4 |
  |  5 |
  |  6 |
  PRIMARY KEY (`id`)
  mysql> delete from auto_test1 where id>3;
  | id |
  |  1 |
  |  2 |
  |  3 |
  PRIMARY KEY (`id`)
  | id |
  |  1 |
  |  2 |
  |  3 |
  |  7 |
  |  8 |
  |  9 |
  PRIMARY KEY (`id`)
- 因为一些原因（比如唯一键冲突），使得插入数据最终未成功的，有可能导致AUTO_INCREMENT跳变。
  mysql> create table auto_test7(`id` int NOT NULL AUTO_INCREMENT, cred_id int UNIQUE, PRIMARY KEY (`id`));
  Query OK, 0 rows affected (0.64 sec)
  mysql> insert into auto_test7 values(null, 1);
  Query OK, 1 row affected (0.03 sec)
  mysql> show create table auto_test7;
  | auto_test7 | CREATE TABLE `auto_test7` (  `id` int NOT NULL AUTO_INCREMENT,  `cred_id` int DEFAULT NULL,  PRIMARY KEY (`id`),  UNIQUE KEY `cred_id` (`cred_id`)) ENGINE=InnoDB AUTO_INCREMENT=2 DEFAULT CHARSET=utf8 |
  ERROR 1062 (23000): Duplicate entry '1' for key 'auto_test7.cred_id'
  | auto_test7 | CREATE TABLE `auto_test7` (  `id` int NOT NULL AUTO_INCREMENT,  `cred_id` int DEFAULT NULL,  PRIMARY KEY (`id`),  UNIQUE KEY `cred_id` (`cred_id`)) ENGINE=InnoDB AUTO_INCREMENT=3 DEFAULT CHARSET=utf8 |
- 批量插入数据时（如insert...select、load file等），自增键的申请是分批申请的，每批申请2的n次方个序号，用完继续申请，没用完也不会退回，所以可能会导致AUTO_INCREMENT跳变。
  mysql> create table auto_test5_tmp(id tinyint not null AUTO_INCREMENT, name varchar(8), PRIMARY KEY (`id`));
  Query OK, 0 rows affected (0.08 sec)
  mysql> select * from auto_test5;
  | id | name |
  |  1 | A    |
  |  2 | B    |
  |  3 | C    |
  |  4 | X    |
  |  5 | Y    |
  |  6 | Z    |
  |  8 | A    |
  |  9 | B    |
  | 10 | C    |
  | 11 | X    |
  | 12 | Y    |
  | 13 | Z    |
  12 rows in set (0.00 sec)
  mysql> insert into auto_test5_tmp select 0,name from auto_test5;
  Query OK, 12 rows affected (0.01 sec)
  Records: 12  Duplicates: 0  Warnings: 0
  mysql> select * from auto_test5_tmp;
  | id | name |
  |  1 | A    |
  |  2 | B    |
  |  3 | C    |
  |  4 | X    |
  |  5 | Y    |
  |  6 | Z    |
  |  7 | A    |
  |  8 | B    |
  |  9 | C    |
  | 10 | X    |
  | 11 | Y    |
  | 12 | Z    |
  mysql> show create table auto_test5_tmp;
  | auto_test5_tmp | CREATE TABLE `auto_test5_tmp` (  `id` tinyint NOT NULL AUTO_INCREMENT,  `name` varchar(8) DEFAULT NULL,  PRIMARY KEY (`id`)) ENGINE=InnoDB AUTO_INCREMENT=16 DEFAULT CHARSET=utf8 |
