# DML语法定义
#### DML语句
**语法定义**
INSERT INTO table_name [PARTITION part_spec] query
part_spec:  (part_col_name1=val1 [, part_col_name2=val2, ...])
query:
  values
      select
      | selectWithoutFrom
      | query UNION [ ALL ] query
      | query EXCEPT query
      | query INTERSECT query
    [ ORDER BY orderItem [, orderItem ]* ]
    [ LIMIT { count | ALL } ]
    [ OFFSET start { ROW | ROWS } ]
    [ FETCH { FIRST | NEXT } [ count ] { ROW | ROWS } ONLY]
orderItem:
  expression [ ASC | DESC ]
select:
  SELECT [ ALL | DISTINCT ]
  { * | projectItem [, projectItem ]* }
  FROM tableExpression
  [ WHERE booleanExpression ]
  [ GROUP BY { groupItem [, groupItem ]* } ]
  [ HAVING booleanExpression ]
  [ WINDOW windowName AS windowSpec [, windowName AS windowSpec ]* ]
selectWithoutFrom:
projectItem:
  expression [ [ AS ] columnAlias ]
  | tableAlias . *
tableExpression:
  tableReference [, tableReference ]*
  | tableExpression [ NATURAL ] [ LEFT | RIGHT | FULL ] JOIN tableExpression [ joinCondition ]
joinCondition:
  ON booleanExpression
  | USING '(' column [, column ]* ')'
tableReference:
  tablePrimary
  [ matchRecognize ]
  [ [ AS ] alias [ '(' columnAlias [, columnAlias ]* ')' ] ]
tablePrimary:
  [ TABLE ] [ [ catalogName . ] schemaName . ] tableName
  | LATERAL TABLE '(' functionName '(' expression [, expression ]* ')' ')'
  | UNNEST '(' expression ')'
values:
  VALUES expression [, expression ]*
groupItem:
  expression
  | CUBE '(' expression [, expression ]* ')'
  | ROLLUP '(' expression [, expression ]* ')'
  | GROUPING SETS '(' groupItem [, groupItem ]* ')'
windowRef:
    windowName
  | windowSpec
windowSpec:
    [ windowName ]
    [ PARTITION BY expression [, expression ]* ]
        RANGE numericOrIntervalExpression {PRECEDING}
      | ROWS numericExpression {PRECEDING}
matchRecognize:
      MATCH_RECOGNIZE '('
      [ MEASURES measureColumn [, measureColumn ]* ]
      [ ONE ROW PER MATCH ]
      [ AFTER MATCH
            ( SKIP TO NEXT ROW
            | SKIP PAST LAST ROW
            | SKIP TO FIRST variable
            | SKIP TO LAST variable
            | SKIP TO variable )
      PATTERN '(' pattern ')'
      [ WITHIN intervalLiteral ]
      DEFINE variable AS condition [, variable AS condition ]*
measureColumn:
      expression AS alias
pattern:
      patternTerm [ '|' patternTerm ]*
patternTerm:
      patternFactor [ patternFactor ]*
patternFactor:
      variable [ patternQuantifier ]
patternQuantifier:
  |   '{' { [ minRepeat ], [ maxRepeat ] } '}' ['?']
  |   '{' repeat '}'
**注意事项**
Flink SQL 对于标识符（表、属性、函数名）有类似于 Java 的词法约定:
- 不管是否引用标识符，都保留标识符的大小写。
- 且标识符需区分大小写。
- 与 Java 不一样的地方在于，通过反引号，可以允许标识符带有非字母的字符（如："SELECT a AS \`my field\` FROM t"）。
字符串文本常量需要被单引号包起来（如 SELECT 'Hello World' ）。两个单引号表示转义（如 SELECT 'It''s me.'）。字符串文本常量支持 Unicode 字符，如需明确使用 Unicode 编码，请使用以下语法：
- 使用反斜杠（\\）作为转义字符（默认）：SELECT U\&'\\263A'
- 使用自定义的转义字符： SELECT U\&'#263A' UESCAPE '#'
