# 表相关
 #### 创建DLI表
DLI提供创建DLI表的接口。您可以使用该接口创建数据存储在DLI内部的表。示例代码如下：
private static Table createDLITable(Database database) throws DLIException {
    //构造表列集合，通过实例化Column对象构建列
    List<Column> columns = new ArrayList<Column>();
    Column c1 = new Column("c1", DataType.STRING, "desc for c1");
    Column c2 = new Column("c2", DataType.INT, "desc for c2");
    Column c3 = new Column("c3", DataType.DOUBLE, "desc for c3");
    Column c4 = new Column("c4", DataType.BIGINT, "desc for c4");
    Column c5 = new Column("c5", DataType.SHORT, "desc for c5");
    Column c6 = new Column("c6", DataType.LONG, "desc for c6");
    Column c7 = new Column("c7", DataType.SMALLINT, "desc for c7");
    Column c8 = new Column("c8", DataType.BOOLEAN, "desc for c8");
    Column c9 = new Column("c9", DataType.DATE, "desc for c9");
    Column c10 = new Column("c10", DataType.TIMESTAMP, "desc for c10");
    Column c11 = new Column("c11", DataType.DECIMAL, "desc for c11");
    columns.add(c1);
    columns.add(c2);
    columns.add(c3);
    columns.add(c4);
    columns.add(c5);
    columns.add(c6);
    columns.add(c7);
    columns.add(c8);
    columns.add(c9);
    columns.add(c10);
    columns.add(c11);
    List<String> sortColumns = new ArrayList<String>();
    sortColumns.add("c1");
    String DLITblName = "tablename";
    String desc = "desc for table";
    //通过调用Database对象的createDLITable方法创建DLI表
    Table table = database.createDLITable(DLITblName, desc, columns, sortColumns);
    System.out.println(table);
    return table;
![](https://support.huaweicloud.com/sdkreference-dli/public_sys-resources/note_3.0-zh-cn.png)
DataType.DECIMAL的默认精度为(10,0)，设置Decimal类型精度的方法如下：
Column c11 = new Column("c11", new DecimalTypeInfo(25,5), "test for c11");
 #### 创建OBS表
DLI提供创建OBS表的接口。您可以使用该接口创建数据存储在OBS的表。示例代码如下：
private static Table createObsTable(Database database) throws DLIException {
    List < Column > columns = new ArrayList < Column > ();
    columns.add(c1);
    columns.add(c2);
    columns.add(c3);
    columns.add(c4);
    columns.add(c5);
    columns.add(c6);
    columns.add(c7);
    columns.add(c8);
    columns.add(c9);
    columns.add(c10);
    columns.add(c11);
    CsvFormatInfo formatInfo = new CsvFormatInfo();
    formatInfo.setWithColumnHeader(true);
    formatInfo.setDelimiter(",");
    formatInfo.setQuoteChar("\"");
    formatInfo.setEscapeChar("\\");
    formatInfo.setDateFormat("yyyy/MM/dd");
    formatInfo.setTimestampFormat("yyyy-MM-dd HH:mm:ss");
    String obsTblName = "tablename";
    String dataPath = "OBS path";
    //通过调用Database对象的createObsTable方法创建OBS表
    Table table = database.createObsTable(obsTblName, desc, columns,StorageType.CSV , dataPath, formatInfo);
    return table;
 #### 删除表
DLI提供删除表的接口。您可以使用该接口删除数据库下的所有表。示例代码如下：
private static void deleteTables(Database database) throws DLIException {
    //调用Database对象的listAllTables接口查询所有表
    List<Table> tables = database.listAllTables();
    for (Table table : tables) {
      //遍历表，调用Table对象的deleteTable接口删除表
      table.deleteTable();
      System.out.println("delete table " + table.getTableName());
表删除后，将不可恢复，请谨慎操作。
#### 查询所有表
DLI提供创建查询表的接口。您可以使用该接口查询数据库下的所有表。示例代码如下：
private static void listTables(Database database) throws DLIException {
    //调用Database对象的listAllTables方法查询数据库下的所有表
    List<Table> tables = database.listAllTables(true);
#### 查询表的分区信息（包含分区的创建和修改时间）
DLI提供查询表分区信息的接口。您可以使用该接口查询数据库下表的分区信息（包括分区的创建和修改时间）。示例代码如下：
private static void showPartitionsInfo(DLIClient client) throws DLIException {
    String databaseName = "databasename";
    String tableName = "tablename";
    //调用DLIClient对象的showPartitions方法查询数据库下表的分区信息（包括分区的创建和修改时间）
    PartitionResult partitionResult = client.showPartitions(databaseName, tableName);
    PartitionListInfo partitonInfos = partitionResult.getPartitions();
    //获取分区的创建和修改时间
    Long createTime = partitonInfos.getPartitionInfos().get(0).getCreateTime().longValue();
    Long lastAccessTime = partitonInfos.getPartitionInfos().get(0).getLastAccessTime().longValue();
    System.out.println("createTime:"+createTime+"\nlastAccessTime:"+lastAccessTime);
 #### 描述表信息
您可以使用该接口获取表的元数据描述信息。示例代码如下：
private static void getTableDetail(Table table) throws DLIException {
  // 调用Table对象的getTableDetail方法获取描述表信息
  //  TableSchema tableSchema=table.getTableDetail();
  //输出信息
  System.out.println(List<Column> columns = tableSchema.getColumns());
  System.out.println(List<String> sortColumns = tableSchema.getSortColumns());
  System.out.println(String createTableSql = tableSchema.getCreateTableSql());
  System.out.println(String tableComment = tableSchema.getTableComment());
