# 快速入门
#### 初始化EMS客户端
本示例用于初始化EMS客户端配置并启动EMS服务。
# 引入模块
import os, torch, torch_npu
from ems import Ems, EmsConfig, EmsException, CcConfig, CcKvOption
# 初始化Ems
config = EmsConfig(cc_config=cc_config)
try:
    Ems.init(config)
except EmsException as e:
    print(f"exception: {e}.")
    exit(1)
更多关于EMS客户端初始化的内容请参考[初始化](https://support.huaweicloud.com/sdk-python-devg-ems/obs_22_0006.html)章节。
#### 读写Context Caching
本示例通过初始化并获取Context Caching配置，保存和加载显存数据。
1. 初始化Ems,并向context cache注册一个KVCache结构。
   from ems import Ems, EmsConfig, EmsException, CcConfig_v1, CcKvOption
   # 初始化cc配置
   cc_config = CcConfig_v1(rank_id=8, device_id=0, model_id="llama2-13b")
   # 初始化Ems
   try:
       Ems.init(config)
       exit(1)
   # 获取context caching对象
   cc = Ems.get_cc()
   if cc is None:
       print("cc is None.")
       exit(1)
   # 注册到Context Caching
   try:
        context_caching.register_kvcache(kvcache)
        # 期望kvcache形状: [layers, k_v_index, GPU_blocks, Block_size, heads, head_size]
        print("register_kvcache: success")
        print(f"register_kvcache failed: {e}")
2. slot_mapping语义下的保存和加载显存数据，参数：slot_mapping + hashes + offsets。
   # 设置save请求的超时时间
   option = CcKvOption(timeout=5000)
   block_size = 4
   # 保存
   slot_mapping = [0,1,2,3,4,5,6,7]
   hashes = [0xABCD, 0x1234]
   offsets = [4, 4]
   try:
       cc_result = cc.save(slot_mapping = slot_mapping, hashes = hashes, offsets = offsets, option = option)
       print(f"failed to save, {e}.")
       exit(1)
   # 读取保存的数据
   try:
       cc_result = cc.load(slot_mapping = slot_mapping, hashes = hashes, offsets = offsets, option = option)
       print(f"failed to load, {e}.")
       exit(1)
3. chunk_descs 语义下的保存和加载显存数据，参数：hashes + chunk_descs。
   # 设置save请求的超时时间
   block_size = 4
   # 保存
   chunk_descs = [[(0, 4),(4, 4)]]
   try:
       cc_result = cc.save(hashes = hashes, chunk_descs = chunk_descs, option = option)
       exit(1)
   # 读取保存的数据
   try:
       cc_result = cc.load(hashes = hashes, chunk_descs = chunk_descs, option = option)
       exit(1)
