# 加密示例
#### 上传对象加密
以下代码展示了在上传对象时如何使用服务端加密功能：
- SSE-C加密
static OBSClient *client;
NSString *endPoint = @"https://your-endpoint";
// 认证用的ak和sk硬编码到代码中或者明文存储都有很大的安全风险，建议在配置文件或者环境变量中密文存放，使用时解密，确保安全；本示例以ak和sk保存在环境变量中为例，运行本示例前请先在本地环境中设置环境变量AccessKeyID和SecretAccessKey。
char* ak_env = getenv("AccessKeyID");
char* sk_env = getenv("SecretAccessKey");
if (ak_env == NULL || sk_env == NULL) {
    NSLog(@"Error: AccessKeyID or SecretAccessKey environment variable not set");
    return;
NSString *AK = [NSString stringWithUTF8String:ak_env];
NSString *SK = [NSString stringWithUTF8String:sk_env];
// 初始化身份验证
OBSStaticCredentialProvider *credentialProvider = [[OBSStaticCredentialProvider alloc] initWithAccessKey:AK secretKey:SK];
//初始化服务配置
OBSServiceConfiguration *conf = [[OBSServiceConfiguration alloc] initWithURLString:endPoint credentialProvider:credentialProvider];
// 初始化client
client = [[OBSClient alloc] initWithConfiguration:conf];
// SSE-C加密上传对象
NSString *_imagePath = [[NSBundle mainBundle] pathForResource:@"pic" ofType:@"jpg"];
NSData *uploadData = [NSData dataWithContentsOfFile:_imagePath];
OBSPutObjectWithDataRequest *request = [[OBSPutObjectWithDataRequest alloc]initWithBucketName:@"bucketname" objectKey:@"test/image1" uploadData:uploadData];
 // 加密
request.encryption = [[OBSEncryptionTypeCustomer alloc]initWithAlgorithm:@"AES256" key:@"K7QkYpBkM5+hcs27fsNkUnNVaobncnLht/rCB2o/9Cw=" keyMD5:@"4XvB3tbNTN+tIEVa0/fGaQ=="];
request.uploadProgressBlock = ^(int64_t bytesSent, int64_t totalBytesSent, int64_t totalBytesExpectedToSend) {
    NSLog(@"%0.1f%%", (totalBytesExpectedToSend > 0) ? (float)totalBytesSent*100/(float)totalBytesExpectedToSend : 0);
[client putObject:request completionHandler:^(OBSPutObjectResponse *response, NSError *error){
    NSLog(@"%@",response);
![](https://support.huaweicloud.com/sdk-ios-devg-obs/public_sys-resources/note_3.0-zh-cn.png)
- key：密钥通过AES256加密生成。
- keyMD5：密钥通过MD5生成值，再将此值通过base64加密。
- SSE-KMS加密
    return;
// 初始化身份验证
//初始化服务配置
// 初始化client
// SSE-KMS加密上传
OBSPutObjectWithFileRequest *request = [[OBSPutObjectWithFileRequest alloc]initWithBucketName:@"bucketname" objectKey:@"objectname" uploadFilePath:_imagePath];
// SSE-KMS加密
request.encryption = [[OBSEncryptionTypeKMS alloc]initWithKeyID:nil];
    NSLog(@"%0.1f%%",(float)floor((totalBytesExpectedToSend > 0) ? (totalBytesSent*10000/totalBytesExpectedToSend) : 0)/100);
    if(response.etag){NSLog(@"%@",response.etag);}
#### 下载对象解密
以下代码展示了在下载对象时使用服务端解密功能：
    return;
// 初始化身份验证
//初始化服务配置
// 初始化client
// 下载对象解密
NSString * outfilePath = [NSTemporaryDirectory() stringByAppendingString:@"test.png"];
OBSGetObjectToFileRequest *request = [[OBSGetObjectToFileRequest alloc]initWithBucketName:@"bucketname" objectKey:@"objectname" downloadFilePath:outfilePath];
// 与上传时的密钥一致
request.downloadProgressBlock = ^(int64_t bytesWritten, int64_t totalBytesWritten, int64_t totalBytesExpectedToWrite) {
    NSLog(@"%0.1f%%",(float)floor((totalBytesExpectedToWrite > 0) ? (totalBytesWritten*10000/totalBytesExpectedToWrite) : 0)/100);
[client getObject:request completionHandler:^(OBSGetObjectResponse *response, NSError *error){
![](https://support.huaweicloud.com/sdk-ios-devg-obs/public_sys-resources/notice_3.0-zh-cn.png)
当前SDK的文件上传接口（OBSPutObjectWithFileRequest、OBSUploadFileRequest）的uploadFilePath参数仅接受NSString类型的文件路径，不支持直接传入\[NSURL fileURLWithPath:@"xxx"\]构造的NSURL对象。如需使用NSURL，请先通过\[fileURL path\]获取文件路径字符串，再传入uploadFilePath参数。
