# 清除托管配置
您可以通过deleteBucketWebsite清除桶的托管配置。以下代码展示了如何清除托管配置：
static OBSClient *client;
NSString *endPoint = @"https://your-endpoint";
// 认证用的ak和sk硬编码到代码中或者明文存储都有很大的安全风险，建议在配置文件或者环境变量中密文存放，使用时解密，确保安全；本示例以ak和sk保存在环境变量中为例，运行本示例前请先在本地环境中设置环境变量AccessKeyID和SecretAccessKey。
char* ak_env = getenv("AccessKeyID");
char* sk_env = getenv("SecretAccessKey");
if (ak_env == NULL || sk_env == NULL) {
    NSLog(@"Error: AccessKeyID or SecretAccessKey environment variable not set");
    return;
NSString *AK = [NSString stringWithUTF8String:ak_env];
NSString *SK = [NSString stringWithUTF8String:sk_env];
// 初始化身份验证
OBSStaticCredentialProvider *credentialProvider = [[OBSStaticCredentialProvider alloc] initWithAccessKey:AK secretKey:SK];
//初始化服务配置
OBSServiceConfiguration *conf = [[OBSServiceConfiguration alloc] initWithURLString:endPoint credentialProvider:credentialProvider];
// 初始化client
client = [[OBSClient alloc] initWithConfiguration:conf];
// 清除托管配置
OBSDeleteBucketWebsiteRequest *request = [[OBSDeleteBucketWebsiteRequest alloc] initWithBucketName:@"bucketname"];
[client deleteBucketWebsite:request completionHandler:^(OBSDeleteBucketWebsiteResponse *response, NSError *error){
    NSLog(@"%@",response);
![](https://support.huaweicloud.com/sdk-ios-devg-obs/public_sys-resources/note_3.0-zh-cn.png)
- 清除托管配置过程中返回的错误码含义、问题原因及处理措施可参考[OBS错误码](https://support.huaweicloud.com/sdk-ios-devg-obs/obs_27_1601.html)、[sdk自定义异常](https://support.huaweicloud.com/sdk-ios-devg-obs/obs_27_1604.html)、[sdk公共响应头](https://support.huaweicloud.com/sdk-ios-devg-obs/obs_27_1602.html)。
