# 设置托管配置
您可以通过setBucketWebsite设置桶的托管配置。
#### 配置默认主页和错误页面
以下代码展示了如何配置默认主页和错误页面：
static OBSClient *client;
NSString *endPoint = @"https://your-endpoint";
// 认证用的ak和sk硬编码到代码中或者明文存储都有很大的安全风险，建议在配置文件或者环境变量中密文存放，使用时解密，确保安全；本示例以ak和sk保存在环境变量中为例，运行本示例前请先在本地环境中设置环境变量AccessKeyID和SecretAccessKey。
char* ak_env = getenv("AccessKeyID");
char* sk_env = getenv("SecretAccessKey");
if (ak_env == NULL || sk_env == NULL) {
    NSLog(@"Error: AccessKeyID or SecretAccessKey environment variable not set");
    return;
NSString *AK = [NSString stringWithUTF8String:ak_env];
NSString *SK = [NSString stringWithUTF8String:sk_env];
// 初始化身份验证
OBSStaticCredentialProvider *credentialProvider = [[OBSStaticCredentialProvider alloc] initWithAccessKey:AK secretKey:SK];
//初始化服务配置
OBSServiceConfiguration *conf = [[OBSServiceConfiguration alloc] initWithURLString:endPoint credentialProvider:credentialProvider];
// 初始化client
client = [[OBSClient alloc] initWithConfiguration:conf];
OBSWebsiteConfCustom* redirectCustom = [OBSWebsiteConfCustom new];
// 配置默认主页
OBSWebsiteConfCustomIndexDocument* indexDocument = [[OBSWebsiteConfCustomIndexDocument alloc]initWithSuffix:@"index.html"];
// 配置默认错误界面
OBSWebsiteConfCustomErrorDocument* errorDocument = [[OBSWebsiteConfCustomErrorDocument alloc]initWithKey:@"Error.html"];
OBSWebsiteConfCustomRoutingRule* redirectRule = [OBSWebsiteConfCustomRoutingRule new];
OBSWebsiteConfCustomCondition* condition = [OBSWebsiteConfCustomCondition new];
condition.keyPrefixEquals = @"docs/";
//    condition.httpErrorCodeReturnedEquals = @"404";
//  配置重定向规则
OBSWebsiteConfCustomRedirect* redirect = [OBSWebsiteConfCustomRedirect new];
redirect.replaceKeyPrefixWith = @"documents/";
redirect.protocol = @"http";
redirect.hostName = @"URL";
//    redirect.replaceKeyWith = @"error.html";
redirect.httpRedirectCode = @"301";
redirectRule.condition = condition;
redirectRule.redirect = redirect;
[redirectCustom.indexDocumentList addObject:indexDocument];
[redirectCustom.errorDocumentList addObject:errorDocument];
[redirectCustom.routingRulesList addObject:redirectRule];
OBSSetBucketWebsiteRequest *request = [[OBSSetBucketWebsiteRequest alloc]initWithBucketName:@"bucketname" configuration:redirectCustom];
[client setBucketWebsite:request completionHandler:^(OBSSetBucketWebsiteResponse *response, NSError *error){
    NSLog(@"%@",response);
#### 配置所有请求重定向
以下代码展示了如何配置所有请求重定向：
    return;
// 初始化身份验证
//初始化服务配置
// 初始化client
// 配置所有请求重定向
OBSWebsiteConfRedirectAll* redirectAll = [OBSWebsiteConfRedirectAll new];
redirectAll.hostName = @"URL";
OBSSetBucketWebsiteRequest *request = [[OBSSetBucketWebsiteRequest alloc]initWithBucketName:@"bucketname" configuration:redirectAll];
