# 开启桶日志
您可以通过setBucketLogging开启桶日志功能。
![](https://support.huaweicloud.com/sdk-ios-devg-obs/public_sys-resources/note_3.0-zh-cn.png)
日志目标桶与源桶必须在同一个区域（region）。
已支持日志目标桶的存储类型：低频访问存储或归档存储或标准存储。
#### 开启桶日志
以下代码展示了如何开启桶日志：
static OBSClient *client;
NSString *endPoint = @"https://your-endpoint";
// 认证用的ak和sk硬编码到代码中或者明文存储都有很大的安全风险，建议在配置文件或者环境变量中密文存放，使用时解密，确保安全；本示例以ak和sk保存在环境变量中为例，运行本示例前请先在本地环境中设置环境变量AccessKeyID和SecretAccessKey。
char* ak_env = getenv("AccessKeyID");
char* sk_env = getenv("SecretAccessKey");
if (ak_env == NULL || sk_env == NULL) {
    NSLog(@"Error: AccessKeyID or SecretAccessKey environment variable not set");
    return;
NSString *AK = [NSString stringWithUTF8String:ak_env];
NSString *SK = [NSString stringWithUTF8String:sk_env];
// 初始化身份验证
OBSStaticCredentialProvider *credentialProvider = [[OBSStaticCredentialProvider alloc] initWithAccessKey:AK secretKey:SK];
//初始化服务配置
OBSServiceConfiguration *conf = [[OBSServiceConfiguration alloc] initWithURLString:endPoint credentialProvider:credentialProvider];
// 初始化client
client = [[OBSClient alloc] initWithConfiguration:conf];
//设置桶访问日志
// 第一步 设置目标桶的日志投递组访问权限
OBSUser *owner = [[OBSUser alloc] initWithID:@"ownerID"];
OBSACLGranteeLogDelivery *grantee = [OBSACLGranteeLogDelivery new];
OBSACLGrant *grant = [[OBSACLGrant alloc]initWithGrantee:grantee permission:OBSACLFull_Control];
// 设置目标桶的日志投递组为完全控制权限
OBSACLGranteeUser *userGrantee = [[OBSACLGranteeUser alloc]initWithID:@"granteeID"];
OBSACLGrant *userGrant = [[OBSACLGrant alloc]initWithGrantee:userGrantee permission:OBSACLFull_Control];
OBSACLGranteeAllUsers *alluserGrantee = [OBSACLGranteeAllUsers new];
OBSACLGrant *alluserGrant = [[OBSACLGrant alloc]initWithGrantee:alluserGrantee permission:OBSACLFull_Control];
OBSAccessControlPolicy *policy = [OBSAccessControlPolicy new];
policy.owner = owner;
[policy.accessControlList addObject:grant];
[policy.accessControlList addObject:userGrant];
OBSSetBucketACLWithPolicyRequest *setACLRequest = [[OBSSetBucketACLWithPolicyRequest alloc]initWithBucketName:@"bucketname" accessControlPolicy:policy];
[client setBucketACL:setACLRequest completionHandler:^(OBSSetBucketACLResponse *response, NSError *error){
    NSLog(@"%@",response);
// 第二步 设置桶的日志管理配置
OBSSetBucketLoggingRequest *request = [[OBSSetBucketLoggingRequest alloc]initWithBucketName:@"bucketname"];
OBSLoggingEnabled* enabledItem = [[OBSLoggingEnabled alloc]initWithTargetBucket:@"bucketname" targetPrefix:@"access-log"];
[enabledItem.targetGrantsList addObject:userGrant];
[enabledItem.targetGrantsList addObject:alluserGrant];
[request.loggingEnabledList addObject:enabledItem];
[client setBucketLogging:request completionHandler:^(OBSSetBucketLoggingResponse *response, NSError *error){
