# 如何理解Content-Type（MIME）？
Content-Type（MIME）用于标识请求或响应中所携带数据的媒体类型，浏览器根据该参数来决定数据的打开方式。Content-Type多用于指定一些客户端自定义的文件，以及一些媒体文件的打开方式。
![](https://support.huaweicloud.com/sdk-go-devg-obs/public_sys-resources/note_3.0-zh-cn.png)
如果您在上传Object时未指定Content-Type，SDK会根据指定Object名称的后缀名来判定文件类型并自动填充Content-Type。
#### 什么是Content-Type
Content-Type用于指定Object的文件类型。内容类型决定浏览器将以什么形式、什么编码读取文件。如果没有指定文件类型，则根据文件的扩展名生成。如果文件没有扩展名，则文件类型的默认值application/octet-stream。
#### 常见的Content-Type
常见的Content-Type（MIME）列表如下：
| 文件扩展名               | Content-Type                            | 文件扩展名    | Content-Type                                                      |
| .\*（二进制流，不知道下载文件类型） | application/octet-stream                | .7z      | application/x-7z-compressed                                       |
| .001                | application/x-001                       | .301     | application/x-301                                                 |
| .323                | text/h323                               | .906     | application/x-906                                                 |
| .907                | drawing/907                             | .a11     | application/x-a11                                                 |
| .acp                | audio/x-mei-aac                         | .ai      | application/postscript                                            |
| .aif                | audio/aiff                              | .aifc    | audio/aiff                                                        |
| .aiff               | audio/aiff                              | .anv     | application/x-anv                                                 |
| .asa                | text/asa                                | .asf     | video/x-ms-asf                                                    |
| .asp                | text/asp                                | .asx     | video/x-ms-asf                                                    |
| .au                 | audio/basic                             | .avi     | video/avi                                                         |
| .awf                | application/vnd.adobe.workflow          | .biz     | text/xml                                                          |
| .bmp                | image/bmp                               | .bot     | application/x-bot                                                 |
| .c4t                | application/x-c4t                       | .c90     | application/x-c90                                                 |
| .cal                | application/x-cals                      | .cat     | application/vnd.ms-pki.seccat                                     |
| .cdf                | application/x-netcdf                    | .cdr     | application/x-cdr                                                 |
| .cel                | application/x-cel                       | .cer     | application/x-x509-ca-cert                                        |
| .cg4                | application/x-g4                        | .cgm     | application/x-cgm                                                 |
| .cit                | application/x-cit                       | .class   | java/\*                                                           |
| .cml                | text/xml                                | .cmp     | application/x-cmp                                                 |
| .cmx                | application/x-cmx                       | .cot     | application/x-cot                                                 |
| .crl                | application/pkix-crl                    | .crt     | application/x-x509-ca-cert                                        |
| .csi                | application/x-csi                       | .css     | text/css                                                          |
| .cut                | application/x-cut                       | .dbf     | application/x-dbf                                                 |
| .dbm                | application/x-dbm                       | .dbx     | application/x-dbx                                                 |
| .dcd                | text/xml                                | .dcx     | application/x-dcx                                                 |
| .der                | application/x-x509-ca-cert              | .dgn     | application/x-dgn                                                 |
| .dib                | application/x-dib                       | .dll     | application/x-msdownload                                          |
| .doc                | application/msword                      | .dot     | application/msword                                                |
| .drw                | application/x-drw                       | .dtd     | text/xml                                                          |
| .dwf                | Model/vnd.dwf                           | .dwf     | application/x-dwf                                                 |
| .dwg                | application/x-dwg                       | .dxb     | application/x-dxb                                                 |
| .dxf                | application/x-dxf                       | .edn     | application/vnd.adobe.edn                                         |
| .emf                | application/x-emf                       | .eml     | message/rfc822                                                    |
| .ent                | text/xml                                | .epi     | application/x-epi                                                 |
| .eps                | application/x-ps                        | .eps     | application/postscript                                            |
| .etd                | application/x-ebx                       | .exe     | application/x-msdownload                                          |
| .fax                | image/fax                               | .fdf     | application/vnd.fdf                                               |
| .fif                | application/fractals                    | .fo      | text/xml                                                          |
| .frm                | application/x-frm                       | .g4      | application/x-g4                                                  |
| .gbr                | application/x-gbr                       | .        | application/x-                                                    |
| .gif                | image/gif                               | .gl2     | application/x-gl2                                                 |
| .gp4                | application/x-gp4                       | .hgl     | application/x-hgl                                                 |
| .hmr                | application/x-hmr                       | .hpg     | application/x-hpgl                                                |
| .hpl                | application/x-hpl                       | .hqx     | application/mac-binhex40                                          |
| .hrf                | application/x-hrf                       | .hta     | application/hta                                                   |
| .htc                | text/x-component                        | .htm     | text/html                                                         |
| .html               | text/html                               | .htt     | text/webviewhtml                                                  |
| .htx                | text/html                               | .icb     | application/x-icb                                                 |
| .ico                | image/x-icon                            | .ico     | image/x-icon                                                      |
| .iff                | application/x-iff                       | .ig4     | application/x-g4                                                  |
| .igs                | application/x-igs                       | .iii     | application/x-iphone                                              |
| .img                | application/x-img                       | .ins     | application/x-internet-signup                                     |
| .isp                | application/x-internet-signup           | .IVF     | video/x-ivf                                                       |
| .java               | java/\*                                 | .jfif    | image/jpeg                                                        |
| .jpe                | image/jpeg                              | .jpe     | application/x-jpe                                                 |
| .jpeg               | image/jpeg                              | .jpg     | image/jpeg                                                        |
| .jpg                | application/x-jpg                       | .js      | application/javascript                                            |
| .jsp                | text/html                               | .la1     | audio/x-liquid-file                                               |
| .lar                | application/x-laplayer-reg              | .latex   | application/x-latex                                               |
| .lavs               | audio/x-liquid-secure                   | .lbm     | application/x-lbm                                                 |
| .lmsff              | audio/x-la-lms                          | .ls      | application/javascript                                            |
| .ltr                | application/x-ltr                       | .m1v     | video/x-mpeg                                                      |
| .m2v                | video/x-mpeg                            | .m3u     | audio/mpegurl                                                     |
| .m4e                | video/mpeg4                             | .mac     | application/x-mac                                                 |
| .man                | application/x-troff-man                 | .math    | text/xml                                                          |
| .mdb                | application/msaccess                    | .mdb     | application/x-mdb                                                 |
| .mfp                | application/x-shockwave-flash           | .mht     | message/rfc822                                                    |
| .mhtml              | message/rfc822                          | .mi      | application/x-mi                                                  |
| .mid                | audio/mid                               | .midi    | audio/mid                                                         |
| .mil                | application/x-mil                       | .mml     | text/xml                                                          |
| .mnd                | audio/x-musicnet-download               | .mns     | audio/x-musicnet-stream                                           |
| .mocha              | application/javascript                  | .movie   | video/x-sgi-movie                                                 |
| .mp1                | audio/mp1                               | .mp2     | audio/mp2                                                         |
| .mp2v               | video/mpeg                              | .mp3     | audio/mp3                                                         |
| .mp4                | video/mp4                               | .mpa     | video/x-mpg                                                       |
| .mpd                | application/vnd.ms-project              | .mpe     | video/x-mpeg                                                      |
| .mpeg               | video/mpg                               | .mpg     | video/mpg                                                         |
| .mpga               | audio/rn-mpeg                           | .mpp     | application/vnd.ms-project                                        |
| .mps                | video/x-mpeg                            | .mpt     | application/vnd.ms-project                                        |
| .mpv                | video/mpg                               | .mpv2    | video/mpeg                                                        |
| .mpw                | application/vnd.ms-project              | .mpx     | application/vnd.ms-project                                        |
| .mtx                | text/xml                                | .mxp     | application/x-mmxp                                                |
| .net                | image/pnetvue                           | .nrf     | application/x-nrf                                                 |
| .nws                | message/rfc822                          | .odc     | text/x-ms-odc                                                     |
| .out                | application/x-out                       | .p10     | application/pkcs10                                                |
| .p12                | application/x-pkcs12                    | .p7b     | application/x-pkcs7-certificates                                  |
| .p7c                | application/pkcs7-mime                  | .p7m     | application/pkcs7-mime                                            |
| .p7r                | application/x-pkcs7-certreqresp         | .p7s     | application/pkcs7-signature                                       |
| .pc5                | application/x-pc5                       | .pci     | application/x-pci                                                 |
| .pcl                | application/x-pcl                       | .pcx     | application/x-pcx                                                 |
| .pdf                | application/pdf                         | .pdf     | application/pdf                                                   |
| .pdx                | application/vnd.adobe.pdx               | .pfx     | application/x-pkcs12                                              |
| .pgl                | application/x-pgl                       | .pic     | application/x-pic                                                 |
| .pko                | application/vnd.ms-pki.pko              | .pl      | application/x-perl                                                |
| .plg                | text/html                               | .pls     | audio/scpls                                                       |
| .plt                | application/x-plt                       | .png     | image/png                                                         |
| .png                | application/x-png                       | .pot     | application/vnd.ms-powerpoint                                     |
| .ppa                | application/vnd.ms-powerpoint           | .ppm     | application/x-ppm                                                 |
| .pps                | application/vnd.ms-powerpoint           | .ppt     | application/vnd.ms-powerpoint                                     |
| .ppt                | application/x-ppt                       | .pr      | application/x-pr                                                  |
| .prf                | application/pics-rules                  | .prn     | application/x-prn                                                 |
| .prt                | application/x-prt                       | .ps      | application/x-ps                                                  |
| .ps                 | application/postscript                  | .ptn     | application/x-ptn                                                 |
| .pwz                | application/vnd.ms-powerpoint           | .r3t     | text/vnd.rn-realtext3d                                            |
| .ra                 | audio/vnd.rn-realaudio                  | .ram     | audio/x-pn-realaudio                                              |
| .ras                | application/x-ras                       | .rat     | application/rat-file                                              |
| .rdf                | text/xml                                | .rec     | application/vnd.rn-recording                                      |
| .red                | application/x-red                       | .rgb     | application/x-rgb                                                 |
| .rjs                | application/vnd.rn-realsystem-rjs       | .rjt     | application/vnd.rn-realsystem-rjt                                 |
| .rlc                | application/x-rlc                       | .rle     | application/x-rle                                                 |
| .rm                 | application/vnd.rn-realmedia            | .rmf     | application/vnd.adobe.rmf                                         |
| .rmi                | audio/mid                               | .rmj     | application/vnd.rn-realsystem-rmj                                 |
| .rmm                | audio/x-pn-realaudio                    | .rmp     | application/vnd.rn-rn_music_package                               |
| .rms                | application/vnd.rn-realmedia-secure     | .rmvb    | application/vnd.rn-realmedia-vbr                                  |
| .rmx                | application/vnd.rn-realsystem-rmx       | .rnx     | application/vnd.rn-realplayer                                     |
| .rp                 | image/vnd.rn-realpix                    | .rpm     | audio/x-pn-realaudio-plugin                                       |
| .rsml               | application/vnd.rn-rsml                 | .rt      | text/vnd.rn-realtext                                              |
| .rtf                | application/msword                      | .rtf     | application/x-rtf                                                 |
| .rv                 | video/vnd.rn-realvideo                  | .sam     | application/x-sam                                                 |
| .sat                | application/x-sat                       | .sdp     | application/sdp                                                   |
| .sdw                | application/x-sdw                       | .sit     | application/x-stuffit                                             |
| .slb                | application/x-slb                       | .sld     | application/x-sld                                                 |
| .slk                | drawing/x-slk                           | .smi     | application/smil                                                  |
| .smil               | application/smil                        | .smk     | application/x-smk                                                 |
| .snd                | audio/basic                             | .sol     | text/plain                                                        |
| .sor                | text/plain                              | .spc     | application/x-pkcs7-certificates                                  |
| .spl                | application/futuresplash                | .spp     | text/xml                                                          |
| .ssm                | application/streamingmedia              | .sst     | application/vnd.ms-pki.certstore                                  |
| .stl                | application/vnd.ms-pki.stl              | .stm     | text/html                                                         |
| .sty                | application/x-sty                       | .svg     | text/xml                                                          |
| .swf                | application/x-shockwave-flash           | .tdf     | application/x-tdf                                                 |
| .tg4                | application/x-tg4                       | .tga     | application/x-tga                                                 |
| .tif                | image/tiff                              | .tiff    | image/tiff                                                        |
| .ttf                | font/otf                                | .tld     | text/xml                                                          |
| .top                | drawing/x-top                           | .torrent | application/x-bittorrent                                          |
| .tsd                | text/xml                                | .txt     | text/plain                                                        |
| .uin                | application/x-icq                       | .uls     | text/iuls                                                         |
| .vcf                | text/x-vcard                            | .vda     | application/x-vda                                                 |
| .vdx                | application/vnd.visio                   | .vml     | text/xml                                                          |
| .vpg                | application/x-vpeg005                   | .vsd     | application/vnd.visio                                             |
| .vsd                | application/x-vsd                       | .vss     | application/vnd.visio                                             |
| .vst                | application/vnd.visio                   | .vst     | application/x-vst                                                 |
| .vsw                | application/vnd.visio                   | .vsx     | application/vnd.visio                                             |
| .vtx                | application/vnd.visio                   | .vxml    | text/xml                                                          |
| .wav                | audio/wav                               | .wax     | audio/x-ms-wax                                                    |
| .wb1                | application/x-wb1                       | .wb2     | application/x-wb2                                                 |
| .wb3                | application/x-wb3                       | .wbmp    | image/vnd.wap.wbmp                                                |
| .wiz                | application/msword                      | .wk3     | application/x-wk3                                                 |
| .wk4                | application/x-wk4                       | .wkq     | application/x-wkq                                                 |
| .wks                | application/x-wks                       | .wm      | video/x-ms-wm                                                     |
| .wma                | audio/x-ms-wma                          | .wmd     | application/x-ms-wmd                                              |
| .wmf                | application/x-wmf                       | .wml     | text/vnd.wap.wml                                                  |
| .wmv                | video/x-ms-wmv                          | .wmx     | video/x-ms-wmx                                                    |
| .wmz                | application/x-ms-wmz                    | .wp6     | application/x-wp6                                                 |
| .wpd                | application/x-wpd                       | .wpg     | application/x-wpg                                                 |
| .wpl                | application/vnd.ms-wpl                  | .wq1     | application/x-wq1                                                 |
| .wr1                | application/x-wr1                       | .wri     | application/x-wri                                                 |
| .wrk                | application/x-wrk                       | .ws      | application/x-ws                                                  |
| .ws2                | application/x-ws                        | .wsc     | text/scriptlet                                                    |
| .wsdl               | text/xml                                | .wvx     | video/x-ms-wvx                                                    |
| .xdp                | application/vnd.adobe.xdp               | .xdr     | text/xml                                                          |
| .xfd                | application/vnd.adobe.xfd               | .xfdf    | application/vnd.adobe.xfdf                                        |
| .xhtml              | text/html                               | .xlsx    | application/vnd.openxmlformats-officedocument.spreadsheetml.sheet |
| .xls                | application/x-xls                       | .xlw     | application/x-xlw                                                 |
| .xml                | text/xml                                | .xpl     | audio/scpls                                                       |
| .xq                 | text/xml                                | .xql     | text/xml                                                          |
| .xquery             | text/xml                                | .xsd     | text/xml                                                          |
| .xsl                | text/xml                                | .xslt    | text/xml                                                          |
| .xwd                | application/x-xwd                       | .x_b     | application/x-x_b                                                 |
| .sis                | application/vnd.symbian.install         | .sisx    | application/vnd.symbian.install                                   |
| .x_t                | application/x-x_t                       | .ipa     | application/vnd.iphone                                            |
| .apk                | application/vnd.android.package-archive | .xap     | application/x-silverlight-app                                     |
| .zip                | application/zip                         | .rar     | application/x-rar-compressed                                      |
| .wasm               | application/wasm                        | -        | -        |
