# 查看托管配置
![](https://support.huaweicloud.com/sdk-dotnet-devg-obs/public_sys-resources/notice_3.0-zh-cn.png)
开发过程中，您有任何问题可以在github上[提交issue](https://github.com/huaweicloud/huaweicloud-sdk-dotnet-obs/issues)，或者在[华为云对象存储服务论坛](https://bbs.huaweicloud.com/forum/forum-620-1.html)中发帖求助。[接口参考文档](https://obssdk.obs.cn-north-1.myhuaweicloud.com/apidoc/cn/dotnet/html/G_OBS.htm)详细介绍了每个接口的参数和使用方法。
您可以通过ObsClient.GetBucketWebsite查看桶的托管配置。
本示例用于查看桶名为"bucketname"的托管配置。
代码示例如下所示:
// 初始化配置参数
ObsConfig config = new ObsConfig();
config.Endpoint = "https://your-endpoint";
// 认证用的ak和sk硬编码到代码中或者明文存储都有很大的安全风险，建议在配置文件或者环境变量中密文存放，使用时解密，确保安全；本示例以ak和sk保存在环境变量中为例，运行本示例前请先在本地环境中设置环境变量AccessKeyID和SecretAccessKey。
string accessKey= Environment.GetEnvironmentVariable("AccessKeyID", EnvironmentVariableTarget.Machine);
string secretKey= Environment.GetEnvironmentVariable("SecretAccessKey", EnvironmentVariableTarget.Machine);
// 创建ObsClient实例
ObsClient client = new ObsClient(accessKey, secretKey, config);
// 查看托管配置
try
    GetBucketWebsiteRequest request = new GetBucketWebsiteRequest();
    request.BucketName = "bucketname";
    GetBucketWebsiteResponse response = client.GetBucketWebsite(request);
    Console.WriteLine("GetBucketWebsite website configuration error document: {0}", response.Configuration.ErrorDocument);
    Console.WriteLine("GetBucketWebsite website configuration index document: {0}", response.Configuration.IndexDocument);
    Console.WriteLine("Get bucket website response: {0}", response.StatusCode);
catch (ObsException ex)
    Console.WriteLine("ErrorCode: {0}", ex.ErrorCode);
    Console.WriteLine("ErrorMessage: {0}", ex.ErrorMessage);
![](https://support.huaweicloud.com/sdk-dotnet-devg-obs/public_sys-resources/note_3.0-zh-cn.png)
查看桶托管配置过程中返回的错误码含义、问题原因及处理措施可参考[SDK错误码](https://support.huaweicloud.com/sdk-dotnet-devg-obs/obs_25_1606.html)。
