# 批量复制对象(C SDK)
![](https://support.huaweicloud.com/sdk-c-devg-obs/public_sys-resources/notice_3.0-zh-cn.png)
开发过程中，您有任何问题可以在GitHub上[提交issue](https://github.com/huaweicloud/huaweicloud-sdk-c-obs/issues)，或者在[华为云对象存储服务论坛](https://bbs.huaweicloud.com/forum/forum-620-1.html)中发帖求助。
#### 示例代码
本示例用于批量复制OBS桶中的对象到目标桶。您可以通过列举满足前缀条件的对象，再以指定并发数批量复制到目标桶，目标Key通过前缀替换生成，支持跨桶复制或同桶备份，适用于数据迁移、备份等场景。
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <pthread.h>
#include "eSDKOBS.h"
#define MAX_KEY_LEN     1024
#define MAX_TASK        10000
typedef struct {
    char source_key[MAX_KEY_LEN];
    char target_key[MAX_KEY_LEN];
} copy_task;
typedef struct {
    int total;
    int success;
    int failed;
    char failed_keys[100][MAX_KEY_LEN];
    int failed_count;
    pthread_mutex_t mutex;
} batch_result;
static batch_result g_result = {0, 0, 0, {{0}}, 0, PTHREAD_MUTEX_INITIALIZER};
static copy_task *g_tasks = NULL;
static int g_task_count = 0;
static int g_task_index = 0;
static pthread_mutex_t g_task_mutex = PTHREAD_MUTEX_INITIALIZER;
static obs_status copy_object_properties_callback(const obs_response_properties *properties, void *callback_data)
    (void)properties;
    (void)callback_data;
    return OBS_STATUS_OK;
static void copy_object_complete_callback(obs_status status,
                                          const obs_error_details *error,
    (void)error;
    copy_task *task = (copy_task *)callback_data;
    char *source_key = task ? task->source_key : "unknown";
    char *target_key = task ? task->target_key : "unknown";
    pthread_mutex_lock(&g_result.mutex);
    if (status == OBS_STATUS_OK) {
        g_result.success++;
        printf("[SUCCESS] copy %s -> %s\n", source_key, target_key);
    } else {
        g_result.failed++;
        if (g_result.failed_count < 100) {
            strncpy(g_result.failed_keys[g_result.failed_count], source_key, MAX_KEY_LEN - 1);
            g_result.failed_keys[g_result.failed_count][MAX_KEY_LEN - 1] = '\0';
            g_result.failed_count++;
        printf("[FAILED] copy %s: %s\n", source_key, obs_get_status_name(status));
    pthread_mutex_unlock(&g_result.mutex);
typedef struct {
    copy_task *tasks;
    int max_count;
    int current_count;
    size_t prefix_len;
    const char *target_prefix;
    obs_status ret_status;
} list_cb_data;
static obs_status list_objects_callback(int is_truncated, const char *next_marker,
                                         int contents_count,
                                         const obs_list_objects_content *contents,
                                         int common_prefixes_count,
                                         const char **common_prefixes,
    (void)is_truncated;
    (void)next_marker;
    (void)common_prefixes_count;
    (void)common_prefixes;
    list_cb_data *data = (list_cb_data *)callback_data;
    for (int i = 0; i < contents_count && data->current_count < data->max_count; i++) {
        memset(&data->tasks[data->current_count], 0, sizeof(copy_task));
        strncpy(data->tasks[data->current_count].source_key, contents[i].key, MAX_KEY_LEN - 1);
        snprintf(data->tasks[data->current_count].target_key, MAX_KEY_LEN, "%s%s",
                 data->target_prefix, contents[i].key + data->prefix_len);
        data->current_count++;
static void list_complete_callback(obs_status status,
    (void)error;
    data->ret_status = status;
static void *worker_thread(void *arg)
    obs_options *options_ptr = (obs_options *)arg;
    const char *bucket_name = (const char *)options_ptr->bucket_options.bucket_name;
    while (1) {
        pthread_mutex_lock(&g_task_mutex);
        if (g_task_index >= g_task_count) {
            pthread_mutex_unlock(&g_task_mutex);
            break;
        int idx = g_task_index++;
        copy_task *task = &g_tasks[idx];
        obs_copy_destination_object_info dest_info;
        memset(&dest_info, 0, sizeof(dest_info));
        dest_info.destination_bucket = bucket_name;
        dest_info.destination_key = task->target_key;
        obs_response_handler handler = {
            copy_object_properties_callback,
        copy_object(options_ptr, task->source_key, NULL, &dest_info,
                    1, NULL, 0, &handler, task);
    return NULL;
int main()
    const char *BUCKET_NAME = "example-bucket-name";
    const char *PREFIX = "test/source/";
    const char *TARGET_PREFIX = "backup/";
    int THREAD_NUM = 8;
    obs_status status = obs_initialize(OBS_INIT_ALL);
    if (status != OBS_STATUS_OK) {
        printf("obs_initialize failed: %s\n", obs_get_status_name(status));
        return 1;
    obs_options options;
    init_obs_options(&options);
    // host_name填写桶所在的endpoint, 此处以华北-北京四为例，其他地区请按实际情况填写。
    options.bucket_options.host_name = "obs.cn-north-4.myhuaweicloud.com";
    options.bucket_options.bucket_name = (char *)BUCKET_NAME;
    options.bucket_options.access_key = getenv("ACCESS_KEY_ID");
    options.bucket_options.secret_access_key = getenv("SECRET_ACCESS_KEY");
    printf("\nListing objects with prefix '%s'...\n", PREFIX);
    g_tasks = (copy_task *)malloc(sizeof(copy_task) * MAX_TASK);
    if (!g_tasks) {
        printf("Failed to allocate memory\n");
        obs_deinitialize();
        return 1;
    list_cb_data cb_data = {g_tasks, MAX_TASK, 0, strlen(PREFIX), TARGET_PREFIX, OBS_STATUS_BUTT};
    obs_list_objects_handler list_handler = {
        { NULL, list_complete_callback },
    list_bucket_objects(&options, PREFIX, NULL, NULL, 1000, &list_handler, &cb_data);
    if (cb_data.ret_status != OBS_STATUS_OK) {
        printf("list_bucket_objects failed: %s\n", obs_get_status_name(cb_data.ret_status));
        free(g_tasks);
        obs_deinitialize();
        return 1;
    g_task_count = cb_data.current_count;
    if (g_task_count == 0) {
        printf("No objects found with prefix '%s'\n", PREFIX);
        free(g_tasks);
        obs_deinitialize();
        return 0;
    printf("Found %d objects to copy\n", g_task_count);
    g_result.total = g_task_count;
    g_result.success = 0;
    g_result.failed = 0;
    g_result.failed_count = 0;
    g_task_index = 0;
    pthread_t threads[THREAD_NUM];
    for (int i = 0; i < THREAD_NUM; i++) {
        pthread_create(&threads[i], NULL, worker_thread, &options);
        pthread_join(threads[i], NULL);
    printf("\n========== Batch Copy Summary ==========\n");
    printf("Total: %d\n", g_result.total);
    printf("Success: %d\n", g_result.success);
    printf("Failed: %d\n", g_result.failed);
    if (g_result.failed_count > 0) {
        printf("\nFailed objects:\n");
        for (int i = 0; i < g_result.failed_count; i++) {
            printf("  - %s\n", g_result.failed_keys[i]);
    printf("==========================================\n");
    free(g_tasks);
    obs_deinitialize();
    return 0;
#### 相关链接
- 关于复制对象的API说明，请参见[复制对象](https://support.huaweicloud.com/api-obs/obs_04_0082.html)。
- 更多关于复制对象的代码示例，请参见[Github示例](https://github.com/huaweicloud/huaweicloud-sdk-c-obs/blob/master/source/eSDK_OBS_API/eSDK_OBS_API_C++_Demo/demo.c)。
- 复制对象过程中返回的错误码含义、问题原因及处理措施可参考[OBS错误码](https://support.huaweicloud.com/api-obs/obs_04_0115.html#section1)。
- 复制对象常见问题请参见[我可以在桶间进行文件复制吗？](https://support.huaweicloud.com/obs_faq/obs_faq_0056.html)。
