# 批量上传对象(C SDK)
![](https://support.huaweicloud.com/sdk-c-devg-obs/public_sys-resources/notice_3.0-zh-cn.png)
开发过程中，您有任何问题可以在GitHub上[提交issue](https://github.com/huaweicloud/huaweicloud-sdk-c-obs/issues)，或者在[华为云对象存储服务论坛](https://bbs.huaweicloud.com/forum/forum-620-1.html)中发帖求助。
您可以通过以下接口在上传时使用批量操作：
- [流式上传(C SDK)](https://support.huaweicloud.com/sdk-c-devg-obs/obs_20_0401.html)
- [文件上传(C SDK)](https://support.huaweicloud.com/sdk-c-devg-obs/obs_20_0402.html)
#### 代码示例：文件上传
本示例用于批量上传本地目录中的文件到OBS指定桶。您可以通过递归扫描本地目录， 再以指定并发数并发上传，文件按相对路径生成OBS对象Key，适用于本地文件批量迁移、数据备份上传等场景。
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <pthread.h>
#include <sys/stat.h>
#include <errno.h>
#include <dirent.h>
#include "eSDKOBS.h"
#define MAX_KEY_LEN     1024
#define MAX_PATH_LEN    256
#define MAX_TASK        10000
typedef struct {
    char key[MAX_KEY_LEN];
    char local_path[MAX_PATH_LEN];
} upload_task;
typedef struct {
    upload_task *task;
    FILE *fp;
} upload_context;
typedef struct {
    int total;
    int success;
    int failed;
    char failed_keys[100][MAX_KEY_LEN];
    int failed_count;
    pthread_mutex_t mutex;
} batch_result;
static batch_result g_result = {0, 0, 0, {{0}}, 0, PTHREAD_MUTEX_INITIALIZER};
static upload_task *g_tasks = NULL;
static int g_task_count = 0;
static int g_task_index = 0;
static pthread_mutex_t g_task_mutex = PTHREAD_MUTEX_INITIALIZER;
static obs_status put_object_properties_callback(const obs_response_properties *properties, void *callback_data)
    (void)properties;
    (void)callback_data;
    return OBS_STATUS_OK;
static int put_object_data_callback(int buffer_size, char *buffer, void *callback_data)
    upload_context *ctx = (upload_context *)callback_data;
    if (!ctx || !ctx->fp) return -1;
    size_t read = fread(buffer, 1, buffer_size, ctx->fp);
    return (int)read;
static void put_object_complete_callback(obs_status status,
                                          const obs_error_details *error,
    (void)error;
    char *key = ctx && ctx->task ? ctx->task->key : "unknown";
    pthread_mutex_lock(&g_result.mutex);
    if (status == OBS_STATUS_OK) {
        g_result.success++;
        printf("[SUCCESS] upload %s\n", key);
    } else {
        g_result.failed++;
        if (g_result.failed_count < 100) {
            strncpy(g_result.failed_keys[g_result.failed_count], key, MAX_KEY_LEN - 1);
            g_result.failed_keys[g_result.failed_count][MAX_KEY_LEN - 1] = '\0';
            g_result.failed_count++;
        printf("[FAILED] upload %s: %s\n", key, obs_get_status_name(status));
    pthread_mutex_unlock(&g_result.mutex);
static int scan_directory(const char *base_dir, const char *prefix, upload_task *tasks, int max_count)
    int count = 0;
    DIR *dir;
    struct dirent *entry;
    char full_path[MAX_PATH_LEN];
    struct stat st;
    dir = opendir(base_dir);
    if (!dir) {
        printf("Failed to open directory: %s\n", base_dir);
        return 0;
    while ((entry = readdir(dir)) != NULL && count < max_count) {
        if (strcmp(entry->d_name, ".") == 0 || strcmp(entry->d_name, "..") == 0) {
            continue;
        snprintf(full_path, sizeof(full_path), "%s/%s", base_dir, entry->d_name);
        if (stat(full_path, &st) != 0) {
            continue;
        if (S_ISDIR(st.st_mode)) {
            int sub_count = scan_directory(full_path, prefix, tasks + count, max_count - count);
            count += sub_count;
        } else if (S_ISREG(st.st_mode)) {
            const char *relative_path = full_path + strlen(base_dir) + 1;
            snprintf(tasks[count].key, MAX_KEY_LEN, "%s%s", prefix, relative_path);
            strncpy(tasks[count].local_path, full_path, MAX_PATH_LEN - 1);
            tasks[count].local_path[MAX_PATH_LEN - 1] = '\0';
            count++;
    closedir(dir);
    return count;
static void *worker_thread(void *arg)
    (void)arg;
    obs_options *options_ptr = (obs_options *)arg;
    while (1) {
        pthread_mutex_lock(&g_task_mutex);
        if (g_task_index >= g_task_count) {
            pthread_mutex_unlock(&g_task_mutex);
            break;
        int idx = g_task_index++;
        upload_task *task = &g_tasks[idx];
        FILE *fp = fopen(task->local_path, "rb");
        if (!fp) {
            g_result.failed++;
                strncpy(g_result.failed_keys[g_result.failed_count], task->key, MAX_KEY_LEN - 1);
            printf("[FAILED] cannot open %s: %s\n", task->local_path, strerror(errno));
            continue;
        fseek(fp, 0, SEEK_END);
        long file_size = ftell(fp);
        fseek(fp, 0, SEEK_SET);
        upload_context ctx;
        ctx.task = task;
        ctx.fp = fp;
        obs_put_object_handler handler = {
            { put_object_properties_callback, put_object_complete_callback },
            put_object_data_callback,
            NULL
        obs_put_properties put_properties;
        init_put_properties(&put_properties);
        put_properties.canned_acl = OBS_CANNED_ACL_PRIVATE;
        put_object(options_ptr, task->key, (uint64_t)file_size,
                   &put_properties, 0, &handler, &ctx);
        fclose(fp);
    return NULL;
int main()
    const char *BUCKET_NAME = "example-bucket-name";
    const char *SOURCE_DIR = "/tmp/upload_files";
    const char *PREFIX = "archive/";
    int THREAD_NUM = 8;
    obs_status status = obs_initialize(OBS_INIT_ALL);
    if (status != OBS_STATUS_OK) {
        printf("obs_initialize failed: %s\n", obs_get_status_name(status));
        return 1;
    obs_options options;
    init_obs_options(&options);
   // host_name填写桶所在的endpoint, 此处以华北-北京四为例，其他地区请按实际情况填写。
    options.bucket_options.host_name = "obs.cn-north-4.myhuaweicloud.com";
    options.bucket_options.bucket_name = (char *)BUCKET_NAME;
    options.bucket_options.access_key = getenv("ACCESS_KEY_ID");
    options.bucket_options.secret_access_key = getenv("SECRET_ACCESS_KEY");
    printf("\nScanning local directory '%s' ...\n", SOURCE_DIR);
    g_tasks = (upload_task *)malloc(sizeof(upload_task) * MAX_TASK);
    if (!g_tasks) {
        printf("Failed to allocate memory\n");
        obs_deinitialize();
        return 1;
    g_task_count = scan_directory(SOURCE_DIR, PREFIX, g_tasks, MAX_TASK);
    if (g_task_count == 0) {
        printf("No files found in '%s'\n", SOURCE_DIR);
        free(g_tasks);
        obs_deinitialize();
        return 0;
    printf("Found %d files to upload\n", g_task_count);
    g_result.total = g_task_count;
    g_result.success = 0;
    g_result.failed = 0;
    g_result.failed_count = 0;
    g_task_index = 0;
    pthread_t threads[THREAD_NUM];
    for (int i = 0; i < THREAD_NUM; i++) {
        pthread_create(&threads[i], NULL, worker_thread, &options);
        pthread_join(threads[i], NULL);
    printf("\n========== Batch Upload Summary ==========\n");
    printf("Total: %d\n", g_result.total);
    printf("Success: %d\n", g_result.success);
    printf("Failed: %d\n", g_result.failed);
    if (g_result.failed_count > 0) {
        printf("\nFailed objects:\n");
        for (int i = 0; i < g_result.failed_count; i++) {
            printf("  - %s\n", g_result.failed_keys[i]);
    printf("==========================================\n");
    free(g_tasks);
    obs_deinitialize();
    return 0;
