# 使用MD5校验文件一致性
您可以通过以下接口在上传对象时使用md5校验文件一致性：
- [文本上传](https://support.huaweicloud.com/sdk-browserjs-devg-obs/obs_24_0502.html)
- [文件上传](https://support.huaweicloud.com/sdk-browserjs-devg-obs/obs_24_0503.html)
- [追加上传](https://support.huaweicloud.com/sdk-browserjs-devg-obs/obs_24_0509.html)
- [上传段](https://support.huaweicloud.com/sdk-browserjs-devg-obs/obs_24_1902.html)
- [断点续传上传](https://support.huaweicloud.com/sdk-browserjs-devg-obs/obs_24_0511.html)
#### 代码样例一：文本上传
本示例用于上传文本时使用md5校验数据一致性。
// 认证用的ak和sk硬编码到代码中或者明文存储都有很大的安全风险，建议在配置文件或者环境变量中密文存放，使用时解密，确保安全；本示例以ak和sk保存在环境变量中为例，运行本示例前请先在本地环境中设置环境变量AccessKeyID和SecretAccessKey。
// 前端本身没有process对象，可以使用webpack类打包工具定义环境变量，就可以在代码中运行了。
const AK = process.env.AccessKeyID
const SK = process.env.SecretAccessKey
// 【可选】如果使用临时AKSK和SecurityToken访问OBS，则同样推荐通过环境变量获取
const security_token= process.env.SecurityToken
//  server填写Bucket对应的Endpoint, 这里以华北-北京四为例，其他地区请按实际情况填写。
const server = "https://obs.cn-north-4.myhuaweicloud.com"
// 创建ObsClient实例
var obsClient = new ObsClient({
    access_key_id: AK,
    secret_access_key: SK,
    server: server
async function putContent() {
    try {
        var content = 'Hello OBS';
        const params = {
            Bucket: 'examplebucket',
            Key: 'objectname',
            Body: content,
            // 需要您自行计算并传入base64格式的MD5
            ContentMD5: "content_base64MD5"
        // 上传文本并校验一致性
        const result = await obsClient.putObject(params);
        if (result.CommonMsg.Status < 300) {
            console.log("Put object(%s)'s successful!", params.Key);
            console.log("RequestId: %s", result.CommonMsg.RequestId);
            return;
        console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response.");
        console.log("Status: %d", result.CommonMsg.Status);
        console.log("Code: %s", result.CommonMsg.Code);
        console.log("Message: %s", result.CommonMsg.Message);
    } catch (error) {
        console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.");
        console.log(error);
putContent()
#### 代码样例二：文件上传
本示例用于上传文件时使用md5校验数据一致性。
// 创建ObsClient实例
    access_key_id: AK,
    server: server
async function putFile() {
    try {
        const params = {
            Key: 'objectname',
            SourceFile: document.getElementById('file').files[0],
            ContentMD5:'file_base64MD5'
        // 上传本地文件并校验一致性
            return;
    } catch (error) {
        console.log(error);
putFile()
#### 代码样例三：追加上传
本示例用于追加上传时使用md5校验数据一致性。
// 创建ObsClient实例
    access_key_id: AK,
    server: server
async function appendObject() {
    try {
        const params = {
            Key: 'objectname',
            Position: 0,
            Body: 'Hello OBS',
            ContentMD5:'content_base64MD5'
        // 追加上传并校验一致性
        const result = await obsClient.appendObject(params);
            console.log("Append object(%s)'s successful!", params.Key);
            return;
    } catch (error) {
        console.log(error);
appendObject()
#### 代码样例四：上传段
本示例用于上传段时使用md5校验数据一致性。
// 创建ObsClient实例
    access_key_id: AK,
    server: server
const PartSize = 5 * 1024 * 1024;
const lastPartSize = file.size % PartSize;
// 段数量
const count = Math.ceil(file.size / PartSize);
async function uploadPart(n) {
    try {
        const params = {
            Key: 'exampleobject',
            // 设置分段号，范围是1~10000
            PartNumber: n,
            // 设置Upload ID，可通过初始化上传段任务接口获取
            UploadId: 'upload id from initiateMultipartUpload',
            // 设置将要上传的大文件
            SourceFile: document.getElementById('input-file').files[0],
            // 设置分段大小
            PartSize: count === n ? lastPartSize : PartSize,
            // 设置分段的起始偏移大小
            Offset: (n-1) * PartSize,
            ContentMD5:'part_base64MD5'
        // 断点续传上传文件并校验一致性
        const result = await obsClient.uploadPart(params);
            console.log("Upload part(%s)'s successful!", n);
            return;
    } catch (error) {
        console.log(error);
uploadPart(1)
#### 代码样例五：断点续传上传
本示例用于断点续传上传时使用md5校验每个段数据的一致性。
// 创建ObsClient实例
    access_key_id: AK,
    server: server
async function uploadFile() {
    try {
        const params = {
            Key: 'objectname',
            PartSize: 9 * 1024 * 1024,
            // 是否开启每个分段的一致性校验, 开启该功能后会对上传整体性能造成一定的负面影响，且会使得浏览器消耗更多的CPU和内存资源。
            VerifyMd5: true,
            TaskNum: 6
        // 断点续传上传文件并校验一致性
        const result = await obsClient.uploadFile(params);
            console.log("Upload file(%s)'s successful!", params.Key);
            return;
    } catch (error) {
        console.log(error);
uploadFile()
