# 编程实例
#### 实例描述
本实例实现如下功能：
1. 创建一个测试CPUP的任务。
2. 获取系统最近1s内所有任务或中断的CPUP。
3. 获取系统（除idel任务外）最近10s内的总CPU占用率。
4. 获取CPUP测试任务的CPUP。
#### 编程示例
前提条件：通过make menuconfig配置好CPU占用率模块。
代码实现如下：
#include <unistd.h >
#include "los_task.h"
#include "los_cpup.h"
#define MAXTASKNUM  32
UINT32 cpupUse;
UINT32 g_cpuTestTaskId;
VOID Example_CPUP(VOID)
    printf("entry cpup test example\n");
    while(1) {
        usleep(100);
UINT32 Example_CPUP_Test(VOID)
    UINT32 ret;
    TSK_INIT_PARAM_S cpupTestTask;
    CPUP_INFO_S cpupInfo;
    /* 创建测试CPUP的任务 */
    memset(&cpupTestTask, 0, sizeof(TSK_INIT_PARAM_S));
    cpupTestTask.pfnTaskEntry = (TSK_ENTRY_FUNC)Example_CPUP;
    cpupTestTask.pcName       = "TestCpupTsk";                           /* 测试任务名称 */
    cpupTestTask.uwStackSize  = LOSCFG_BASE_CORE_TSK_DEFAULT_STACK_SIZE;
    cpupTestTask.usTaskPrio   = 5;
    cpupTestTask.uwResved   = LOS_TASK_STATUS_DETACHED;
    ret = LOS_TaskCreate(&g_cpuTestTaskId, &cpupTestTask);
    if(ret != LOS_OK) {
        printf("cpupTestTask create failed.\n");
        return LOS_NOK;
    usleep(100);
    /* 系统中运行的任务或者中断数量 */
    UINT16 maxNum = MAXTASKNUM;
    /* 获取系统所有任务或中断最近1s的CPU占用率 */
    cpupUse = LOS_AllCpuUsage(maxNum, &cpupInfo, CPUP_LAST_ONE_SECONDS, 0);
    printf("the system cpu usage in last 1s: %d\n", cpupUse);
    /* 获取最近10s内系统（除idel任务外）总CPU占用率 */
    cpupUse = LOS_HistorySysCpuUsage(CPUP_LAST_TEN_SECONDS);
    printf("the history system cpu usage in last 10s: %d\n", cpupUse);
    /* 获取指定任务在最近1s的CPU占用率，该测试例程中指定的任务为上面创建的CPUP测试任务 */
    cpupUse = LOS_HistoryTaskCpuUsage(g_cpuTestTaskId, CPUP_LAST_ONE_SECONDS);
    printf("cpu usage of the cpupTestTask in last 1s:\n TaskID: %d\n usage: %d\n", g_cpuTestTaskId, cpupUse);
    return LOS_OK;
#### 结果验证
编译运行得到的结果为：
the system cpu usage in last 1s: 15
the history system cpu usage in last 10s: 3
TaskID: 10
usage: 0
#### 完整实例代码
[sample_cpup.c](https://support.huaweicloud.com/maintenance-LiteOS/resource/sample_cpup.c)
