此内容的本地化语言页面暂未提供。我们将不断努力以提供本地化语言版本。感谢您的关注。
- What's New
- Getting Started
- User Guide
Best Practices
- Using a Custom Script to Implement Consistent Backup for MySQL
- Using a Custom Script to Implement Consistent Backup for SAP HANA
- Using a Custom Script to Implement Consistent Backup for Other Linux Applications
- Troubleshooting a Custom Script Error
- Verifying the Application-Consistent Backup Result (Linux)
- Verifying the Application-Consistent Backup Result (Windows)
- Protecting SQL Server in Failover Cluster Mode
- Protecting SQL Server in Always on Availability Groups Mode
- Change History
- API Reference
About Concepts
- What Is CSBS?
- What Are Full Backup and Incremental Backup?
- What Is Consistent Backup?
- What Are the Differences Between CSBS and VBS?
- What Is a Backup Policy?
- What Are the Differences Between Backup and Disaster Recovery?
- What Are the Differences Between Backup and Snapshot?
- Why Is the Disk Space Usage Displayed in the File System Different from the Backup Size?
About Pricing
- How Is CSBS Billed?
- How Do Yearly/Monthly Resource Packages Function When I Have Bought More Than One?
- Are CSBS and VBS Resource Packages Interoperable Between CSBS and VBS?
- Why Am I Charged in Pay-per-use Mode Although I Have Purchased Resource Package?
- What Exactly Are the Function Package and the Storage Package?
- Will the CSBS Backups Displayed on the VBS Page Be Charged Repeatedly?
- How Do I Query CSBS Pay-Per-Use Billing Details?
- Why Is the Fee Deducted After a Backup Is Deleted?
- How Do I Disable CSBS?
- How Do I Stop CSBS from Charging?
About Backup
- Does CSBS Support Backing Up All EVS Disks on an ECS?
- Do I Need to Stop the ECS Before Backing It Up?
- Can an ECS with Application Systems Be Backed Up?
- What Are the Minimum Backup Frequency and Maximum Number of Retained Backups Supported by CSBS?
- How Can I Distinguish Automatic Backups From Manual Backups?
- How Can I Configure a Backup Policy?
- Can I Choose to Back Up Only Some Partitions of a Disk?
- Does CSBS Support Cross-Region Backup for ECSs?
- Which Types of Databases Can Be Backed Up Using Database Server Backup?
- How Do I Select Among Database Server Backup, Cloud Server Backup, and Disk Backup?
- How Do I Migrate ECS Data Across Regions Using CSBS?
- Which Time Zone Is the Automatic Backup Time Based On?
- What Can I Do If a Backup Cannot Be Deleted?
- About Restoration
- Others
About Concepts
- Troubleshooting
- Videos
- Glossary
More Documents
User Guide (Paris and Amsterdam Regions)
- Getting Started
- Management Operations
- About Concepts
About Backup
- About Restoration
- Others
- Troubleshooting Cases
- Change History
- API Reference (Paris and Amsterdam Regions)
Viewing a Backup
After a backup job is delivered or completed, you can set search criteria to filter backups from the backup list and view backup details.
A backup job has been created.
View Backup Details
- Log in to the CSBS management console.
- Under Storage > Cloud Server Backup Service.
- Click the Backups tab. Search for backups by filtering conditions.
- You can search for backups by selecting a state from the All statuses drop-down list in the upper right corner of the backup list.
Table 1 describes each state.
Table 1 State description State
State Attribute
All statuses
All statuses of backups.
Available
A stable state
A stable state of a backup after the backup is created
This state allows various operations.
Creating
An intermediate state
An intermediate state of a backup from the start of a backup job to the completion of the backup job.
In this state, a progress bar is displayed indicating the backup progress. If the progress bar remains unchanged for a long time, an exception has occurred. Contact customer service for support.
Restoring
An intermediate state when using the backup to restore data.
In this state, a progress bar is displayed indicating the restoration progress. If the progress bar remains unchanged for a long time, an exception has occurred. Contact customer service for support.
Deleting
An intermediate state from the start of deleting the backup to the completion of deleting the backup.
In this state, a progress bar is displayed indicating the deletion progress. If the progress bar remains unchanged for a long time, an exception has occurred. Contact customer service for support.
Error
A stable state
A backup enters the Error state when an exception occurs when the backup is being used.
A backup in this state cannot be used for backup or restoration, and must be deleted manually. If manual deletion fails, contact customer service for support.
- You can search for backups by selecting a time segment displayed in the upper right corner of the backup list.
- You can search for backups by server name, server ID, backup name, or backup ID. Click
to search for target backups.
For a backup created via a successful application-consistent backup job, its name in the Backups tab page is marked with
- Click
on the left of a backup name to view details about the backup.
View Backup Space Usage
- Click the Backups tab and then the number indicating the used storage space in the backup overview. Figure 1 provides an example.
- In the displayed dialog box, view the storage space usage.
Backups specifies the number of backups created for an ECS and Total Backup Capacity (GB) specifies the capacity used by the ECS's backups in total.
Figure 2 Storage space usage
