此内容的本地化语言页面暂未提供。我们将不断努力以提供本地化语言版本。感谢您的关注。
- What's New
- Getting Started
- User Guide
Best Practices
- Using a Custom Script to Implement Consistent Backup for MySQL
- Using a Custom Script to Implement Consistent Backup for SAP HANA
- Using a Custom Script to Implement Consistent Backup for Other Linux Applications
- Troubleshooting a Custom Script Error
- Verifying the Application-Consistent Backup Result (Linux)
- Verifying the Application-Consistent Backup Result (Windows)
- Protecting SQL Server in Failover Cluster Mode
- Protecting SQL Server in Always on Availability Groups Mode
- Change History
- API Reference
About Concepts
- What Is CSBS?
- What Are Full Backup and Incremental Backup?
- What Is Consistent Backup?
- What Are the Differences Between CSBS and VBS?
- What Is a Backup Policy?
- What Are the Differences Between Backup and Disaster Recovery?
- What Are the Differences Between Backup and Snapshot?
- Why Is the Disk Space Usage Displayed in the File System Different from the Backup Size?
About Pricing
- How Is CSBS Billed?
- How Do Yearly/Monthly Resource Packages Function When I Have Bought More Than One?
- Are CSBS and VBS Resource Packages Interoperable Between CSBS and VBS?
- Why Am I Charged in Pay-per-use Mode Although I Have Purchased Resource Package?
- What Exactly Are the Function Package and the Storage Package?
- Will the CSBS Backups Displayed on the VBS Page Be Charged Repeatedly?
- How Do I Query CSBS Pay-Per-Use Billing Details?
- Why Is the Fee Deducted After a Backup Is Deleted?
- How Do I Disable CSBS?
- How Do I Stop CSBS from Charging?
About Backup
- Does CSBS Support Backing Up All EVS Disks on an ECS?
- Do I Need to Stop the ECS Before Backing It Up?
- Can an ECS with Application Systems Be Backed Up?
- What Are the Minimum Backup Frequency and Maximum Number of Retained Backups Supported by CSBS?
- How Can I Distinguish Automatic Backups From Manual Backups?
- How Can I Configure a Backup Policy?
- Can I Choose to Back Up Only Some Partitions of a Disk?
- Does CSBS Support Cross-Region Backup for ECSs?
- Which Types of Databases Can Be Backed Up Using Database Server Backup?
- How Do I Select Among Database Server Backup, Cloud Server Backup, and Disk Backup?
- How Do I Migrate ECS Data Across Regions Using CSBS?
- Which Time Zone Is the Automatic Backup Time Based On?
- What Can I Do If a Backup Cannot Be Deleted?
- About Restoration
- Others
About Concepts
- Troubleshooting
- Videos
- Glossary
More Documents
User Guide (Paris and Amsterdam Regions)
- Getting Started
- Management Operations
- About Concepts
About Backup
- About Restoration
- Others
- Troubleshooting Cases
- Change History
- API Reference (Paris and Amsterdam Regions)
On this page
Show all
Deleting a Backup Policy
You can delete backup policies if required.
You have created at least one backup policy.
- Log in to the CSBS management console.
- Under Storage > Cloud Server Backup Service.
- Click the Policies tab.
- In the row of the backup policy you want to modify, choose More > Delete.
Deleting a backup policy will not delete backups generated based on the policy. You can manually delete unwanted backups.
- Click OK.
Parent topic: Backup Policies
