此内容的本地化语言页面暂未提供。我们将不断努力以提供本地化语言版本。感谢您的关注。
- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
Adding or Deleting a Container Subnet
If the container subnet fails to meet your service requirements, you can add or delete container subnets as needed.
Container subnets can be deleted only when the cluster version is v1.27.8-r0, v1.28.6-r0, or later.
Adding Container Subnets
- Log in to the CCE console, locate the target CCE Autopilot cluster, and click its name.
- On the Overview page, locate the Networking Configuration area and click Add under Default Container Subnet.
Figure 1 Adding subnets
- Select one or more subnets in the same VPC. If no subnet is available, go to the VPC console and create one first.
Figure 2 Selecting subnets
- Click OK.
Deleting Container Subnets
Deleting a container subnet is a high-risk operation. Ensure that no network interfaces are using the subnet to be deleted.
Procedure: On the cluster overview page, view the cluster ID in the Basic Info area. In the Networking Configuration > Default Container Subnet area, copy the subnet ID of the container subnet to be deleted. Then, use this ID to filter the network interfaces and network interfaces associated with this subnet on the Network Interfaces tab. If the name or description of any of the filtered network interfaces contains a cluster ID, those network interfaces are being used by the cluster.
- In the navigation pane on the left, choose Cluster > Settings and switch to the Network tab.
- In the Container Network area, click Update in the Operation column of default-network (Default Container Subnet).
- In the Pod Subnet area, deselect the subnets and click OK.
Figure 3 Deselecting subnets
