更新时间:2025-01-09 GMT+08:00
DLI Delta常见问题
执行insert into/overwrite table_name partition(part_key='part_value') select ...报错DLI.0005: DeltaAnalysisException: Partition column `dt` not found in schema [id, name]
根因分析:不支持insert into/overwrite table_name partition(part_key='part_value')语法。
执行sql报错DLI.0005: There should be at least one partition pruning predicate on partitioned table `777dd`.`test_delta_parts1`
解决方案:在console页面设置中添加参数spark.sql.forcePartitionPredicatesOnPartitionedTable.enabled值为false。
show create table查看建表语句报错DLI.0005: Operation not allowed: `SHOW CREATE TABLE` is not supported for Delta tables
根因分析:不支持该语法,可通过Describe formatted查看表结构。
执行vacuum报错DLI.0001: IllegalArgumentException: requirement failed: Are you sure you would like to vacuum files with such a low retention period?
根因分析:RETAIN 保留期过短(少于168小时),需要确认是否能清理该时间前的数据,将无法再回头查看在指定数据保留期之前创建的版本。确认清理可在console页面设置中添加参数spark.databricks.delta.retentionDurationCheck.enabled值为false。
执行rename/drop column报错DLI.0005: DeltaAnalysisException: Column rename is not supported for your Delta table...
解决方案:先执行如下语句,再执行rename。
ALTER TABLE delta_perms1 SET TBLPROPERTIES (
'delta.columnMapping.mode' ='name',
'delta.minReaderVersion' ='2',
'delta.minWriterVersion' ='5');
