When Are Advanced Scan Settings Required?
Advanced scan settings can be performed for special website pages that:
- Require port scan or weak password scan.
- Can only be accessed after authentication (username and password).
- Do not need to scan.
- Can only be accessed after a verification code is entered.
Figure 1 shows the advanced settings page. Table 1 describes the parameters.
Parameter |
Description |
Configuration |
More Scan Settings |
Scan Strength |
The higher the scan strength, the stronger the detection capability, but the longer the time required. |
N/A |
Port Scan |
You can enable or disable port scan. |
Weak Password Scan |
You can enable or disable weak password scan. |
Website Login Settings NOTE: Some pages cannot be accessed unless you have logged in. If you want to scan these pages, provide the following information. |
Login Page |
Address of the website login page |
N/A |
Username |
Username for logging in to the website |
N/A |
Password |
Password for logging in to the website |
N/A |
Confirm Password |
Crawler |
Simulate Browser |
Web browser used by crawlers |
Select a browser from the drop-down list box. Currently, only Firefox and Chrome are supported. |
Exclude Link |
Links to pages that you do not want to include in the scan |
A maximum of five links can be added. Click to add links and |
Self-Define HTTP Request Header NOTE: Some pages have further authentication requirements (such as requiring the user to enter a verification code). If you want to scan these pages, enter HTTP request headers. You can add a maximum of five request headers. Click |
Name |
Name of an HTTP request header |
Example: Cookie |
Value |
Value of an HTTP request header |
Example: phpsessionid=asdfsadfsadfsadfsadf; sdfs=asdfasdfasdf; uid=1 |
