Replication Policies
Creating a Replication Policy
- Log in to the SWR Enterprise Edition console. On the Repositories page, click the name of the target repository to go to the repository details page.
- In the navigation pane, choose Image Replication > Replication Policies.
- Click Add Replication Policy in the upper right corner.
- In the displayed dialog box, configure the parameters.
Table 1 Parameter description Parameter
Example
Name
Replication policy name.
SyncRule
Replication Direction
- Push to target registry: Push images to the target registry.
- Pull from target registry: Pull images from the target registry.
Target Registry
Select the target registry added in Adding a Target Registry.
Destination Namespace (for push to target registry)
Namespace that images will be pushed to. A namespace may be called a project on other clouds. If you omit it here, images will be pushed to the same namespace as in the source registry by default. If no such a namespace exists at the destination, replication may fail.
library1
Destination Namespace (for pull from target registry)
Namespace that images will be pulled to. A namespace may be called a project on other clouds. If you omit it here, images will be pulled to the same namespace as in the source registry by default. If no such a namespace exists at the destination, replication may fail.
library1
Source Resource Filter (for push to target registry)
Namespace: Select a namespace.
Image: Image name. By default, a regular expression is used to match images. Alternatively, you can click
to select images.The regular expression can be nginx-* or {repo1, repo2}.
- *: matches any field that does not contain the path separator /.
- **: matches any field that contains the path separator /.
- ?: matches any single character except /.
- {option 1, option 2, ...}: matches any of the options.
Tag: Image tag. You can use a regular expression to specify tags. The matching rules are the same as those for images.
NOTE:This parameter is available only when the replication direction is Push to target registry.
library2
nginx-*
Source Resource Filter (for pull from target registry)
Namespace: You can use a regular expression to specify namespaces.
NOTE:This parameter is available only when the replication direction is Pull from target registry.
library2
nginx-*
Trigger Mode
- Manual: You need to manually trigger image replication.
- Event + manual: Image replication is triggered when a new image is pushed or pulled and the image meets the regular expression.
- Scheduled + manual: Scheduled means image replication is triggered periodically.
Scheduled + manual
Scheduled
This parameter is available only when Trigger Mode is set to Scheduled + manual.
Overwrite
Whether to overwrite images at the destination with the same name.
Enter a description for the policy.
Figure 1 Creating a replication policy
- Click OK.
Replication Policy Examples
Push all images starting with nginx-in from the library namespace of the local repository to the lib1 namespace of the target repository test-edit-fail. The replication needs to be triggered manually and images with the same name will be overwritten.
Pull all images starting with nginx-in from the lib1 namespace of the target repository test-edit-fail to the library1 namespace of the local repository. The replication needs to be triggered manually and images with the same name will be overwritten.
Managing Replication Policies
You can manage your replication policies as follows:
- Enable or disable a replication policy.
indicates a policy is enabled and
indicates the policy is disabled. A new policy is enabled by default. - Manually execute a replication policy.
- Modify a replication policy.
- Delete a replication policy.
- View a replication task. When a replication policy is triggered, the images that meet the policy will be replicated. The following table describes details about a replication task.
Table 2 Replication task parameters Parameter
Task ID
Unique ID of a replication task for a repository.
Status
Task status.
Trigger Mode
The value is Manual or Automatic.
If you click Execute, the trigger mode is Manual. If the replication is executed periodically based on a schedule, the trigger mode is Automatic.
Success Rate
The percentage of images that are successfully replicated to the total number of images that need to be replicated.
Total
Total number of images to be replicated in the current task.
Duration
Time required to complete a task.
Created
Time when a replication task was triggered.
Operation
View Details: You can check the replicated images in the right pane after clicking this button.
