Updated on 2025-09-24 GMT+08:00
Image Retention
In modern software development, images are generated in pipelines and updated in each iteration. When images of earlier versions are no longer needed, you can delete them by using image retention policies, which can be, manually or periodically triggered. The rules in a policy can be used separately or in a combination.
There can only be one retention policy in a given namespace. Each policy has 1 to 15 rules.
Creating an Image Retention Policy
  1. Log in to the SWR console. In the upper left corner, switch to your region. On the displayed page, click the name of the target repository to go to the repository details page.
  2. In the navigation pane, choose O&M Center > Image Retention.
  3. Click Add Retention Policy in the upper right corner.
  4. In the displayed dialog box, configure the parameters.
    Table 1 Parameter description
    Example
    Name
    Retention policy name.
    AgingRule
    Namespace
    Namespace where the retention policy will be applied.
    library1
    Trigger Mode
    • Manual: You need to manually trigger image retention.
    • Scheduled + manual: Scheduled means image retention is triggered periodically.
    Scheduled + manual
    Scheduled
    This parameter is available only when Trigger Mode is set to Scheduled + manual.
    You can:
    • Enter a regular expression.
      Example: nginx-* or {repo1, repo2}.
      • *: matches any field that does not contain the path separator /.
      • **: matches any field that contains the path separator /.
      • ?: matches any single character except /.
      • { repo1, repo2, ...}: matches any of the options.
      Note: If this parameter is left blank or set to **, all images will be matched.
    • Select images from a list.
    nginx-*
    Tag
    Image tag. Enter a regular expression.
    Example: v1* or {v1, v2}.
    • {v1, v2}: matches any of the options.
    v1
    Condition
    Retention condition. The options are as follows:
    • Retain the # image tags pushed most recently
    • Retain the # image tags pulled most recently
    • Retain image tags pushed within the last # days
    • Retain image tags pulled within the last # days
    # indicates the number of tags or days.
    Retain the 10 image tags pushed most recently
    Enable
    Whether to enable or disable a retention rule.
    Operation
    You can delete a retention rule.
    Figure 1 Creating an image retention policy
  5. Click OK.
Retention Policy Examples
  • Example 1:
    In the library namespace, for all images, retain the 2 most recently pushed and the 5 most recently pulled tags. The policy needs to be manually triggered.
    For example, there are 10 image tags. Image tags 9 and 10 are most recently pushed. Image tags 1 to 5 are most recently pulled. Based on the policy, image tags 6 to 8 will be deleted.
  • Example 2:
    In the library namespace, retain the tags pushed in the last 3 days for the demo-image-v8 and demo-image-v7 images and the tags pulled in the last day for the demo-image-v6 and demo-image-v5 images. The policy is executed at 00:00 of the first day every month but can also be triggered manually.
Managing Retention Policies
You can:
  • Execute a retention policy. To prevent misoperations, you are advised to test a retention policy before executing it for the first time.
  • Test a retention policy. You can use it to check whether a policy is in effect but no image tags will be deleted in the test.
  • Modify a retention policy. All parameters except Namespace can be modified.
  • Delete a retention policy.
Figure 2 Managing retention policies
  • View a retention task. When a retention policy is triggered, only the images that meet the policy will be retained. The following table describes details about a retention task.
    Table 2 Retention task parameters
    Trigger Mode
    The value is Manual or Automatic.
    If you click Execute or Test, the trigger mode is Manual. If the replication is executed periodically based on a schedule, the trigger mode is Automatic.
    Status
    Task status.
    Test
    The value can be Yes or No.
    If you click Test, the value is Yes. If you click Execute, the value is No. You can use Test to check whether a policy is in effect but no image tags will be deleted in the test.
    Tags Deleted
    Number of image tags that are deleted based on the policy.
    Created
    Time when a retention task was triggered.
    Ended
    Time when a retention task was ended.
    Retention Records
    Retention records of each image tag, such as the namespace, tag name, and retention results.
    Figure 3 Task details
