Image Replication
You can replicate images between registries. In this way, images in one registry can be used in other registries for quick container deployment and updates globally. You can replicate artifacts between SWR Enterprise Edition and:
- SWR Shared Edition
- An SWR Enterprise Edition registry in another region or a private registry built based on open-source Harbor
You can create a policy to customize a replication. For example, you can customize the artifact type (images, Helm charts, or all), source images and tags (using a regular expression), and whether to overwrite existing artifacts.
