Help Center/
SoftWare Repository for Container/
User Guide (Enterprise Edition)/
Repository Management/
Tag Management/
Querying Repositories by Tag
Updated on 2025-11-25 GMT+08:00
You can quickly query repositories by tag on the SWR or TMS console.
Querying Repositories on the SWR Console
Querying Repositories on the TMS Console
- Log in to the SWR Enterprise Edition console and switch to the target region in the upper left corner of the page.
- On the Repositories page, select one or more tags from the drop-down list on the right to search for the repositories associated with any of these tags.
- Log in to the TMS console and switch to the target region in the upper left corner of the page.
- Choose Resource Tags > Tag Management, select the target region, set Resource Type to SWR, and click Search. All SWR resources in this region will be returned.
Parent topic: Tag Management
