Help Center/
SoftWare Repository for Container/
User Guide (Enterprise Edition)/
Repository Management/
Tag Management/
Modifying a Repository Tag
Updated on 2025-11-25 GMT+08:00
You can modify tags on the SWR or TMS console.
Modifying a Tag on the SWR Console
Modifying Tags in a Batch on the TMS Console
- Log in to the SWR Enterprise Edition console and switch to the target region in the upper left corner of the page.
- On the repository management page, locate the repository you want to modify a tag for and click Manage Tag.
- In the displayed dialog box, locate the tag to be modified and enter a new key and value.
- Log in to the TMS console.
- Choose Resource Tags > Tag Management, select the target region, set Resource Type to SWR, and click Search. All SWR resources in this region will be returned.
- Locate the repositories whose tags need to be modified. Click Manage Tag above the list.
- In the New Value column, set new values for the tags. Click OK.
Parent topic: Tag Management
