Updated on 2025-11-25 GMT+08:00
SWR Enterprise Edition Resources
A resource is an object that exists within a service. In SWR Enterprise Edition, resources include repository, instance, chart. When creating a policy, you can select a resource by specifying its path.
Table 1 SWR resources and their paths
Resource
Resource Name
Path
repository
Image repository
[Format]
SWR:*:*:repository:image repository name
The first * is regionid, and the second * is domainid.
[Note]
For image repository resources, IAM automatically generates the resource path prefix (SWR:*:*:repository:).
For the path of a specific image repository, add the image repository name to the end. You can also use a wildcard character (*) to indicate any image repository. Example:
SWR:*:*:repository/* indicates any image repository.
swr:*:*:repository:test/nginx*: image repository whose name starts with nginx in the test namespace
swr:*:*:repository:test/nginx: image repository whose name starts with nginx in the test namespace
instance
SWR Enterprise Edition instance
[Format]
SWR:*:*:instance: SWR Enterprise Edition instance
[Note]
For SWR Enterprise Edition instances, IAM automatically generates the resource path prefix (SWR:*:*:instance:).
For the path of a specific SWR Enterprise Edition instance, add the instance name to the end. You can also use a wildcard character (*) to indicate any instance. Example:
SWR:*:*:instance:example-instance indicates the SWR Enterprise Edition instance named example-instance.
chart
Chart repository
[Format]
SWR:*:*:chart:chart repository name
[Note]
For chart repository resources, IAM automatically generates the resource path prefix (SWR:*:*:chart:).
For the path of a specific chart repository, add the chart repository name to the end. You can also use a wildcard character (*) to indicate any chart repository. Example:
SWR:*:*:chart:* indicates any chart repository.
For example, to allow users to perform operations only on the instance named example-instance, you can define the YAML file as follows:
    "Version": "1.1",
    "Statement": [
            "Effect": "Allow",
            "Action": [
                "swr:instance:*"
            "Resource": [
                "SWR:*:*:instance:example-instance"
