Custom Policies for SWR Enterprise Edition
Custom policies can be created to supplement system-defined policies. You can add actions in custom policies as needed. For details about supported actions, see Table 1.
To create a custom policy, choose either visual editor or JSON.
- Visual editor: Select cloud services, actions, resources, and request conditions. This does not require knowledge of policy syntax.
- JSON: Create a policy in the JSON format from scratch or based on an existing policy.
For details, see Creating a Custom Policy.
Example Custom Policies
- Example 1: Create a policy to allow users to create, update, view, or delete a namespace.
{ "Version": "1.1", "Statement": [ { "Effect": "Allow", "Action": [ "swr:repository:getNamespace", "swr:repository:listNamespaces", "swr:repository:createNamespace", "swr:repository:updateNamespace", "swr:repository:deleteNamespace" ] } ] } - Example 2:
A policy with only Deny permissions must be used in conjunction with other policies to take effect. If the policies assigned to a user contain both Allow and Deny actions, the Deny actions take precedence.
If you want to assign the SWR FullAccess policy to a user but do not want this user to have permission to delete repositories, create a custom policy that denies repository deletion. Then, attach both the policies to the group that the user belongs to. In this way, the user can perform all operations on repositories except deleting the repositories. The following is an example of a deny policy:
{ "Version": "1.1", "Statement": [ { "Effect": "Deny", "Action": [ "swr:instance:delete" ] } ] }
Common SWR Operations Supported by Each System-defined Policy
Operation |
Action |
SWR FullAccess |
SWR OperateAccess |
SWR ReadOnlyAccess |
Listing artifacts |
swr:repository:listArtifacts |
Querying artifact details |
swr:repository:getArtifact |
Deleting artifacts |
swr:repository:deleteArtifact |
Listing artifact accessories |
swr:repository:listAccessories |
Querying additional information about an artifact |
swr:repository:getArtifactAddition |
Querying policies of an Enterprise Edition instance |
swr:instance:getPolicy |
Updating policies of an Enterprise Edition instance |
swr:instance:updatePolicy |
Querying configurations of an Enterprise Edition instance |
swr:instance:getConfigurations |
Updating configurations of an Enterprise Edition instance |
swr:instance:updateConfigurations |
Listing the instances that use a resource |
swr:instance:listResourceInstances |
Querying the number of instances that use a resource |
swr:instance:getResourceInstancesCount |
Creating resource tags in batches |
swr:instance:createResourceTags |
Deleting resource tags in batches |
swr:instance:deleteResourceTags |
Querying project tags |
swr:instance:getProjectTags |
Querying tags of a resource |
swr:instance:getResourceTags |
Creating an Enterprise Edition instance |
swr:instance:create |
Listing Enterprise Edition instances |
swr:instance:list |
Querying details about an Enterprise Edition instance |
swr:instance:get |
Deleting Enterprise Edition instances |
swr:instance:delete |
Querying audit logs of an Enterprise Edition instance |
swr:instance:getAuditLogs |
Querying statistics on Enterprise Edition instances |
swr:instance:getStatistics |
Listing tasks |
swr:instance:listJobs |
Querying task details |
swr:instance:getJobs |
Deleting tasks |
swr:instance:deleteJob |
Creating a namespace |
swr:repository:createNamespace |
Listing namespaces |
swr:repository:listNamespaces |
Querying namespace details |
swr:repository:getNamespace |
Modifying a namespace |
swr:repository:updateNamespace |
Deleting namespaces |
swr:repository:deleteNamespace |
Listing artifact repositories |
swr:repository:listRepositories |
Querying details about an artifact repository |
swr:repository:getRepository |
Modifying an artifact repository |
swr:repository:updateRepository |
Deleting artifact repositories |
swr:repository:deleteRepository |
Listing artifact tags |
swr:repository:listTags |
Querying details about an artifact tag |
swr:repository:getTag |
Deleting artifact tags |
swr:repository:deleteTag |
Querying additional information about an artifact tag |
swr:repository:getTagAddition |
Creating a tag retention policy |
swr:repository:createRetentionPolicy |
Listing tag retention policies |
swr:repository:listRetentionPolicies |
Querying details about a tag retention policy |
swr:repository:getRetentionPolicy |
Modifying a tag retention policy |
swr:repository:updateRetentionPolicy |
Deleting tag retention policies |
swr:repository:deleteRetentionPolicy |
Executing tag retention policies |
swr:repository:executeRetentionPolicy |
Listing tag retention records |
swr:repository:listRetentionPolicyExecutions |
Listing tag retention tasks |
swr:repository:listRetentionPolicyExecTasks |
Listing tag retention subtasks |
swr:repository:listRetentionPolicyExecSubTasks |
Creating a trigger |
swr:repository:createWebhook |
Listing triggers |
swr:repository:listWebhooks |
Querying trigger details |
swr:repository:getWebhook |
Modifying a trigger |
swr:repository:updateWebhook |
Deleting triggers |
swr:repository:deleteWebhook |
Listing triggering records |
swr:repository:listWebhookJobs |
Creating a destination registry |
swr:instance:createRegistry |
Listing destination registries |
swr:instance:listRegistries |
Querying details about a destination registry |
swr:instance:getRegistry |
Modifying a destination registry |
swr:instance:updateRegistry |
Deleting destination registries |
swr:instance:deleteRegistry |
Creating a replication policy |
swr:instance:createReplicationPolicy |
Listing replication policies |
swr:instance:listReplicationPolicies |
Querying details about a replication policy |
swr:instance:getReplicationPolicy |
Modifying a replication policy |
swr:instance:updateReplicationPolicy |
Deleting replication policies |
swr:instance:deleteReplicationPolicy |
Executing replication policies |
swr:instance:executeReplicationPolicy |
Stopping replication tasks |
swr:instance:stopReplicationPolicyExecution |
Listing replication records |
swr:instance:listReplicationPolicyExecutions |
Listing replication tasks |
swr:instance:listReplicationPolicyExecTasks |
Listing replication subtasks |
swr:instance:listReplicationPolicyExecSubTasks |
Creating a sign policy |
swr:repository:createSignPolicy |
Listing sign policies |
swr:repository:listSignPolicies |
Querying details about a sign policy |
swr:repository:getSignPolicy |
Modifying a sign policy |
swr:repository:updateSignPolicy |
Deleting sign policies |
swr:repository:deleteSignPolicy |
Executing sign policies |
swr:repository:executeSignPolicy |
Listing signing records |
swr:repository:listSignPolicyExecutions |
Listing signing tasks |
swr:repository:listSignPolicyExecTasks |
Listing signing subtasks |
swr:repository:listSignPolicyExecSubTasks |
Creating a scan policy |
swr:repository:createScanPolicy |
Listing scan policies |
swr:repository:listScanPolicies |
Querying details about a scan policy |
swr:repository:getScanPolicy |
Modifying a scan policy |
swr:repository:updateScanPolicy |
Deleting scan policies |
swr:repository:deleteScanPolicy |
Executing scan policies |
swr:repository:executeScanPolicy |
Listing scanning records |
swr:repository:listScanPolicyExecutions |
Listing scanning tasks |
swr:repository:listScanPolicyExecTasks |
Creating a block policy |
swr:repository:createBlockPolicy |
Listing block policies |
swr:repository:listBlockPolicies |
Querying details about a block policy |
swr:repository:getBlockPolicy |
Modifying a block policy |
swr:repository:updateBlockPolicy |
Listing blocking records |
swr:repository:listBlockPolicyRecords |
Updating the whitelist for public network access |
swr:instance:updateEndpointPolicy |
Updating the whitelist status for public network access |
swr:instance:updateEndpointPolicyStatus |
Querying the whitelist for public network access |
swr:instance:getEndpointPolicy |
Allowing a connection from the intranet |
swr:instance:createInternalEndpoint |
Querying details about an allowed connection from the intranet |
swr:instance:getInternalEndpoint |
Denying a connection from the intranet |
swr:instance:deleteInternalEndpoint |
Listing allowed connections from the intranet |
swr:instance:listInternalEndpoints |
Uploading artifacts |
swr:repository:uploadArtifact |
Downloading artifacts |
swr:repository:downloadArtifact |
Creating a temporary access credential |
swr:instance:createTempCredential |
Creating a long-term access credential |
swr:instance:createLTCredential |
Enabling or disabling long-term access credentials |
swr:instance:updateLTCredential |
Listing long-term access credentials |
swr:instance:listLTCredentials |
Deleting long-term access credentials |
swr:instance:deleteLTCredential |
