SWR Custom Policies
Custom policies can be created to supplement system-defined policies of SWR.
You can create custom policies in either of the following ways:
- Visual editor: Select cloud services, actions, resources, and request conditions. This does not require knowledge of policy syntax.
- JSON: Create a JSON policy or edit an existing one.
For details, see Creating a Custom Policy. This section illustrates common custom policies.
Example SWR custom policies
- Example 1: Allowing a user to upload and download images in the test-swr SWR Enterprise Edition instance in the test-namespace namespace
{ "Version": "5.0", "Statement": [ { "Effect": "Allow", "Action": [ "swr:repository:downloadArtifact", "swr:repository:uploadArtifact" ], "Resource": [ "swr:*:*:repository:test-swr/test-namespace/*" ] }, { "Effect": "Allow", "Action": [ "swr:instance:createTempCredential" ], "Resource": [ "*" ] } ] }
- Example 3: Denying image replication from region A to region B
{ "Version": "5.0", "Statement": [ { "Effect": "Deny", "Action": [ "swr:instance:createReplicationPolicy" ], "Resource": [ "swr:*:*:instance:*" ], "Condition": { "StringEquals": { "swr:TargetRegion": [ "${region-b}" ], "swr:SourceRegion": [ "${region-a}" ] } } }, { "Effect": "Deny", "Action": [ "swr:instance:createReplicationPolicy" ], "Resource": [ "swr:*:*:instance:*" ], "Condition": { "ForAnyValue:StringEquals": { "swr:SourceUrls": [ "All repository addresses in region a" ], "swr:TargetUrls": [ "All repository addresses in region b" ] } } } ] }
