Marking Vulnerabilities as Ignored
This section shows how to mark vulnerabilities as Ignored. Before the marking, make sure that the vulnerabilities are free of security risks.
After you mark a vulnerability as Ignored, you cannot change its status again and the system will no longer consider this vulnerability risky. You can click Unignore to bring back the vulnerability.
- An account and its password have been obtained for logging in to the management console.
- At least one vulnerability has been detected.
- Choose Security > Vulnerability Scan Service > Dashboard.
- On the right of the Vulnerability List area, click View to go to the Vulnerability List page.
- Select the vulnerabilities to be ignored and click Mark as Ignored.
Figure 1 Marking vulnerabilities as ignored
- Alternatively, in the row containing the desired vulnerability, click Ignore in the Operation column to mark a vulnerability separately.
- You can also click Ignore on the page displaying the details of the vulnerability to mark a vulnerability.
- In the displayed Ignore Vulnerability dialog box, specify the mandatory fields, and then click OK.
