Updated on 2026-09-01 GMT+08:00
Condition Field Description
When setting a precise access, CC attack protection, or global protection whitelist rule, configure some fields in the condition list area. These fields together are used to define the request attributes to trigger the rule. This topic describes the fields that you can specify in conditions to trigger a rule.
What Is a Condition Field?
A condition field specifies the request attribute WAF checks based on protection rules. When configuring a CC attack protection rule, precise access protection rule, or global protection whitelist, you can define condition fields to specify request attributes to trigger the rule.
If a request meets the conditions set in a rule, the request hits the rule. WAF will then handle the request based on the action (Allow, Block, or Log only) configured for the rule.
Figure 1 Condition field
A condition field consists of Field, Subfield, Logic, and Content. Example:
  • Example 1: If Field is set to Path, logic to Include, and Content to /admin, a request matches the rule when the requested path contains /admin.
  • Example 2: If Field is set to IPv4, Subfield to Client IP Address, Logic to Equal to, and Content to 192.XX.XX.3. When the client IP address is 192.XX.XX.3, the request hits the rule.
Supported Condition Fields
Table 1 Condition list configurations
Field
Subfield
Logic
Content (Example)
Path
The path of a resource requested by the client. A path is part of a URL.
Configuration description:
  • The path does not contain a domain name and supports only exact match. So, the path to be protected must be the same as the path you configure. If the path to be protected is /admin, set Path to /admin.
  • If Path is set to /, all paths of the website are protected.
  • The path content cannot contain the following special characters: (<>*)
The following logical relationships are supported:
/buy/phone/
User Agent
The client type, for example, browser, crawler, and mobile app.
Mozilla/5.0 (Windows NT 6.1)
Referer
The source from which the request is sent. If you do not want visitors to access the page from www.test.com, set Content corresponding to Referer to http://www.test.com.
/admin/xxx
IPv4
The IPv4 address of the client.
  • Client IP Address
  • X-Forwarded-For
  • TCP connection IP address
  • Layer 3 source IP address
  • Equal to or Not equal to
  • Equal to any value or Not equal to any value
192.168.1.1
IPv6
The IPv6 address of the client.
fe80:0000:0000:0000:0000:0000:0000:0000
Params
The query parameter in the URL. The query parameter is the content following the question mark (?).
  • All fields
  • Any subfield
  • Custom
201901150929
Cookie
The cookie in the request.
  • All fields
  • Any subfield
  • Custom
jsessionid
Header
The request header content.
  • All fields
  • Any subfield
  • Custom
text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8
Method
The request method.
  • Equal to
  • Not equal to
GET, POST, PUT, DELETE, and PATCH
Protocol
The request protocol.
HTTP and HTTPS
Request Line
The request line length. The value must be an integer ranging from 0 to 65,535.
  • Subfield length equal to
  • Subfield length not equal to
  • Subfield length greater than
  • Subfield length less than
50
Request
The request length. The value must be an integer ranging from 0 to 2,147,483,647.
The maximum value for cloud load balancer access mode is 4,000 bytes. If the value exceeds the maximum, the configuration does not take effect.
50
Response Length
The response length. The value must be an integer ranging from 0 to 2,147,483,647.
  • Response detection occurs after the response header is returned. The response header cannot be modified when it is blocked.
  • A response body returned from the origin server may be included in protection events. As the response body is streamed, WAF cannot change it once it has been sent.
50
Response Time
The response time. The value must be an integer ranging from 0 to 60,000, in ms.
100
Geolocation
The geolocation of the visitor (client).
To enable this, submit a service ticket.
  • IPv4
  • IPv6
  • Any (IPv4 or IPv6 address)
  • Included
  • Excluded
Shanghai
Known feature crawler
Common web crawlers.
  • Search Engine
  • Scanner
  • Script Tool
  • Other
  • Match
  • Mismatch
Search Engine
Response Code
The status code returned to the request.
For requests sent after this rule is triggered, WAF stops checking their HTTP response code until the current traffic limit duration you configure in the rule ends.
404
Response Header
The response header.
WAF checks responses after response headers are returned. If WAF needs to block responses, response headers cannot be changed.
  • All fields
  • Any subfield
  • Custom
  • Include, Exclude, Equal to, Not equal to, Prefix is, Prefix is not, Suffix is, or Suffix is not
  • Include any value, Exclude any value, Equal to any value, Not equal to any value, Prefix is any value, Prefix is not any value, or Suffix is any value
  • Regex match, Regex does not match
Response Body
The response message body.
  • Include or Exclude
  • Include any value or Exclude any value
Request Body
The request message body.
  • Include or Not Include
TLS fingerprint (JA3)
The JA3 fingerprint generated during TLS handshake. It is used to identify device types and malicious tools.
X-Forwarded-Tls-Ja3
TLS fingerprint (JA4)
The JA4 fingerprint generated during TLS handshake. It is used to identify device types and malicious tools.
X-Forwarded-Tls-Ja4
Header Content Length
The request header content length. The value must be an integer ranging from 0 to 2,147,483,647.
  • Greater than
  • Equal to
  • Less than
123
  • If you set Logic to Include any value, Exclude any value, Equal to any value, Not equal to any value, Prefix is any value, Prefix is not any of them, Suffix is any value, or Suffix is not any of them, you can select a reference table for Content. For details about how to add a reference table and manage reference tables, see Creating a Reference Table to Configure Protection Metrics in Batches.
  • The following describes the matching positions for condition logic Include, Exclude, Equal to, Not equal to, Prefix is, Prefix is not, Suffix is, and Suffix is not (abc is used as the matched content):
    • Include or Exclude: matches any position of a field. If the rule is set to Include abc, requests containing abc, for example, xabc123, will match the rule.
    • Equal to or Not equal to: matches the exact fields. If the rule is set to Equal to abc, requests that are exactly the same as abc will match the rule. Requests that are not exactly the same, for example, abc123, will not match the rule.
    • Prefix is or Prefix is not: matches the beginning of a field. If the rule is set to Prefix is /abc, requests starting with /abc, such as /abc and /abc/login, will match the rule.
    • Suffix is or Suffix is not : matches the end of a field. If the rule is set to Suffix is abc123, requests ending with abc123 will match the rule.
