Help Center/ Web Application Firewall/ User Guide/ Object Management/ Certificate Management/ Sharing a Certificate with Other Enterprise Projects
Updated on 2025-01-17 GMT+08:00
This topic walks you through how to share a certificate with other enterprise projects.
If you have enabled enterprise projects, you can select your enterprise project from the Enterprise Project drop-down list and view certificates in the project.
You have uploaded a certificate on the WAF console.
SSL certificates pushed by CCM to WAF cannot be shared within an enterprise project.
  2. Click in the upper left corner of the management console and select a region or project.
  3. Click in the upper left corner and choose Web Application Firewall under Security & Compliance.
  4. In the navigation pane, choose Objects > Certificates.
  5. In the row containing the certificate you want to share, click More > Share in the Operation column.
  6. In the displayed dialog box, select a handling method, and click OK.
Related Operations
  • To change the certificate name, move the cursor over the name of the certificate, click , and enter a certificate name.
    NOTICE:
    If the certificate is in use, unbind the certificate from the domain name first. Otherwise, the certificate name cannot be changed.
  • To view details about a certificate, click View in the Operation column of the certificate.
  • In the row containing the certificate you want, click Use in the Operation column to use the certificate to the corresponding domain name.
  • To delete a certificate, locate the row of the certificate and click More > Delete in the Operation column.
  • To update a certificate, locate the row of the certificate and click More > Update in the Operation column.
  • To stop sharing a certificate with other enterprise projects, locate the row containing the certificate and click More > Stop Sharing in the Operation column.
