Updated on 2025-10-27 GMT+08:00
Exporting Website Settings
You can export settings of all websites protected by WAF in your account on the Website Settings page.
  1. Log in to the WAF console.
  2. Click in the upper left corner and select a region or project.
  3. (Optional) If you have enabled the enterprise project function, in the upper part of the navigation pane on the left, select your enterprise project from the Filter by enterprise project drop-down list. Then, WAF will display the related security data in the enterprise project on the page.
  4. In the navigation pane on the left, click Website Settings.
  5. In the upper right corner above the website list, click Export to export the website information list.
