Enabling Break Protection to Protect Origin Servers
If your website returns too many 502 Bad Gateway or 504 Gateway Timeout errors or responds slowly after it has been connected to WAF, you can enable the break protection and connection protection in WAF to protect origin servers of the website. If the 502/504 error requests and pending URL requests reach the thresholds you configure, WAF enables corresponding protection for your website.
- You have added the website to WAF.
- You have upgraded the dedicated WAF instance to the latest version. For details, see Upgrading a Dedicated WAF Instance.
- This function is only supported by dedicated mode access.
- Before enabling Break Protection, make sure you have upgraded dedicated WAF instances to the latest version, or your services might be affected.
- You can check the regions where website connection protection is available on the console.
- Log in to the WAF console.
- Click
in the upper left corner and select a region or project. - (Optional) If you have enabled the enterprise project function, in the upper part of the navigation pane on the left, select your enterprise project from the Filter by enterprise project drop-down list. Then, WAF will display the related security data in the enterprise project on the page.
- In the navigation pane on the left, click Website Settings.
- On the Website Settings page, click the target website domain name.
- In the Break Protection area, click the status icon
to toggle it on.
- Click
next to each parameter, edit Breakdown Protection and Connection Protection parameters to meet your requirements, and click OK to save settings. Table 1 describes these parameters.
Table 1 Connection Protection parameters Parameter
Example Value
502/504 Error Threshold
30s 502/504 Error Threshold
1000
502/504 Error Percentage (%)
A breakdown is triggered when the 502/504 error threshold and percentage threshold have been reached.
90
Initial Downtime (s)
Protection period upon the first breakdown. During this period, WAF stops forwarding client requests.
180
Multiplier for Consecutive Breakdowns
The maximum multiplier you can use for consecutive breakdowns. The number of breakdowns is counted from 0 every time the accumulated breakdown protection duration reaches 3,600s.
For example, assume that Initial Downtime (s) is set to 180s and Multiplier for Consecutive Breakdowns is set to 3.- If the breakdown is triggered for the second time, that is, less than 3, the protection duration is 360s (180s x 2).
- If the breakdown is triggered for the third or fourth time, that is, greater than or equal to 3, the protection duration is 540s (180s x 3).
- The breakdowns are counted from 0 when the total downtime duration exceeds one hour (3,600s).
3
Pending URL Request Threshold
Connection Protection is triggered when the number of read URL requests reaches the threshold you configure.
6,000
Duration (s)
Protection duration. During this period, WAF stops forwarding client requests.
60
Use Figure 1 as an example:
- Breakdown Protection: When the number of 502/504 errors returned by the protected website exceeds 1,000 and accounts for 90% or more of the total access requests of the website for the first time, the first breakdown protection is triggered. During the first breakdown protection, WAF stops forwarding client requests for 180s (that is, blocks visitors access to the website for 180s). If a second consecutive breakdown protection is triggered, WAF stops forwarding client requests for 360s (180 x 2). If a third or more consecutive breakdowns are triggered, WAF stops forwarding client requests for 540s (180s x 3). The breakdowns are counted from 0 when the total downtime duration exceeds one hour (3,600s).
- Connection Protection: When the number of read URL requests in the waiting queue exceeds 6,000, WAF stops forwarding client requests for 60s and returns the maintenance page of the website to visitors.
