Enabling WAF IPv6 Protection
You can enable IPv6 protection if needed. If IPv6 protection is enabled, WAF assigns an IPv6 access address to your domain name. WAF adds IPv6 address resolution to CNAME record sets by default. All IPv6 access requests are first forwarded to WAF. WAF detects and filters out malicious traffic and returns legitimate traffic to the origin server. This can keep origin servers secure, stable, and available.
- If the origin server address of the protected website is an IPv6 address, IPv6 protection is enabled by default. WAF uses the IPv6 back-to-source address to establish a connection to the origin server.
Figure 1 Only IPv6 addresses set for origin server addresses
- If the origin server address of the protected website is set to an IPv4 address, after you manually enable IPv6 protection, WAF uses the NAT64 mechanism to translate the external IPv6 traffic to internal IPv4 traffic. NAT64 is a network address translation (NAT) mechanism that enables communications between IPv6 and IPv4 servers. WAF uses the IPv4 back-to-source address to establish a connection to the origin server.
Figure 2 Only IPv4 addresses set for origin server addresses
- The Cloud Mode - CNAME mode is used when you connect the website to WAF. Only professional and enterprise editions support IPv6 protection.
- You can check the regions where IPv6 protection is supported on the console.
- If the origin server uses IPv6 addresses, IPv6 protection is enabled by default. To prevent IPv6 service from interruption, keep the IPv6 protection enabled. If IPv6 protection is not needed, edit the server configuration and delete IPv6 configuration from the origin server first. For details, see Editing Server Information.
- Log in to the WAF console.
- Click
in the upper left corner and select a region or project. - (Optional) If you have enabled the enterprise project function, in the upper part of the navigation pane on the left, select your enterprise project from the Filter by enterprise project drop-down list. Then, WAF will display the related security data in the enterprise project on the page.
- In the navigation pane on the left, click Website Settings.
- On the Website Settings page, click the target website domain name.
- In the IPv6 Protection row, click Modify. In the dialog box displayed, select Enable and click OK.
If the above configuration works, the website is accessible using an IPv6 address.
