Viewing Protection Information About a Protected Website on Cloud Eye
You can go to Cloud Eye to view protection details about your websites protected with WAF.
If you have enabled enterprise projects, ensure that you have all operation permissions for the project where your WAF instance locates. Then, you can select the enterprise project from the Enterprise Project drop-down list and view details about protected websites on Cloud Eye.
Viewing Protection Details About a Protected Website on Cloud Eye
- Click in the upper left corner of the management console and select a region or project.
- Click in the upper left corner and choose Web Application Firewall under Security & Compliance.
- In the navigation pane on the left, choose Website Settings.
Figure 1 Website list
- In the row containing the protected domain name, click More > Cloud Eye in the Operation column to go to the Cloud Eye console and view the monitoring information.
