Updated on 2026-09-01 GMT+08:00
Viewing Monitored Metrics
You can view WAF metrics on the Cloud Eye console. You will learn about the WAF protection status in a timely manner and set protection policies based on the metrics.
WAF alarm rules have been configured in Cloud Eye. For more details, see Configuring Alarm Monitoring Rules.
  1. Log in to the Cloud Eye console.
  2. Click in the upper left corner and select a region or project.
  3. In the navigation pane on the left, choose Cloud Service Monitoring.
  4. Search for Web Application Firewall WAF by Dashboard in the search box. In the Dashboard column, click Web Application Firewall WAF to go to the Details page.
  5. On the Overview tab, you can view metrics related to resource overview and alarm statistics.
  6. Click the Resources tab. In the Operation column of the instance list, click View Metric.
    To view the monitoring information about a specific website, you can go to the Assets > Protected Objects page, locate the row containing the target domain name, and click Cloud Eye in the Operation column.
