WAF Monitored Metrics
Function Description
This topic describes metrics reported by WAF to Cloud Eye as well as their namespaces and dimensions. You can use APIs provided by Cloud Eye to query the metrics of the monitored object and alarms generated for WAF. You can also query them on the Cloud Eye console.
namespaces
SYS.WAF
A namespace is an abstract collection of resources and objects. Multiple namespaces can be created in a single cluster with the data isolated from each other. This enables namespaces to share the same cluster services without affecting each other.
Monitored Metrics for Protected Domain Names
Metric ID |
Metric Name |
Description |
Value Range |
Unit |
Number System |
Monitored Object (Dimension) |
Monitoring Interval (Minute) |
requests |
Number of Requests |
Number of requests returned by WAF in the last 5 minutes Collection method: The total number of requests for the domain name are collected. |
≥ 0 Value type: Float |
Count |
N/A |
Protected domain name |
5 minutes |
waf_http_2xx |
WAF Status Code (2XX) |
Number of 2XX status codes returned by WAF in the last 5 minutes Collection method: Number of 2XX status codes returned |
Count |
N/A |
5 |
waf_http_3xx |
WAF Status Code (3XX) |
Number of 3XX status codes returned by WAF in the last 5 minutes Collection method: Number of 3XX status codes returned |
Count |
N/A |
5 |
waf_http_4xx |
WAF Status Code (4XX) |
Number of 4XX status codes returned by WAF in the last 5 minutes Collection method: Number of 4XX status codes returned |
Count |
N/A |
5 |
waf_http_5xx |
WAF Status Code (5XX) |
Number of 5XX status codes returned by WAF in the last 5 minutes Collection method: Number of 5XX status codes returned |
Count |
N/A |
5 |
waf_fused_counts |
WAF Traffic Threshold |
Number of requests destined for the website in the last 5 minutes during breakdown protection duration Collection method: Number of requests to the protected domain name while the website was down |
Count |
N/A |
5 |
inbound_traffic |
Total Inbound Traffic |
Total inbound traffic in the last 5 minutes Collection method: Total inbound traffic in the last 5 minutes |
≥0 Mbit Value type: Float |
Mbit |
1000 |
5 |
outbound_traffic |
Total Outbound Traffic |
Total outbound traffic in the last 5 minutes Collection method: Total outbound traffic in the last 5 minutes |
Mbit |
1000 |
5 |
waf_process_time_0 |
WAF Latency [0-10) ms |
This metric is used to collect how many requests are processed by WAF at latencies from 0 ms (included) to 10 ms (excluded) in the last 5 minutes. Collection method: The number of requests processed by WAF at latencies from 0 ms (included) to 10 ms (excluded) in the last 5 minutes are collected. |
Count |
N/A |
5 minutes |
waf_process_time_10 |
WAF Latency [10-20) ms |
This metric is used to collect how many requests are processed by WAF at latencies in the 10 ms to less than 20 ms range in the last 5 minutes. Collection method: The number of requests processed by WAF at latencies in the 10 ms to less than 20 ms range in the last 5 minutes are collected. |
Count |
N/A |
5 minutes |
waf_process_time_20 |
WAF Latency [20-50) ms |
This metric is used to collect how many requests are processed by WAF at latencies from 20 ms (included) to 50 ms (excluded) in the last 5 minutes. Collection method: The number of requests processed by WAF at latencies from 20 ms (included) to 50 ms (excluded) in the last 5 minutes are collected. |
Count |
N/A |
5 minutes |
waf_process_time_50 |
WAF Latency [50-100) ms |
This metric is used to collect how many requests are processed by WAF at latencies from 50 ms (included) to 100 ms (excluded) in the last 5 minutes. Collection method: The number of requests processed by WAF at latencies from 50 ms (included) to 100 ms (excluded) in the last 5 minutes are collected. |
Count |
N/A |
5 minutes |
waf_process_time_100 |
WAF Latency [100, 1,000) ms |
This metric is used to collect how many requests are processed by WAF at latencies from 100 ms (included) to 1,000 ms (excluded) in the last 5 minutes. Collection method: Collect the number of requests processed by WAF at latencies from 100 ms (included) to 1,000 ms (excluded) in the last 5 minutes. |
Count |
N/A |
5 minutes |
waf_process_time_1000 |
WAF Latency [1,000, above) ms |
This metric is used to collect how many requests are processed by WAF at latencies above 1000 ms in the last 5 minutes. Collection method: The number of requests processed by WAF at latencies above 1000 ms in the last 5 minutes are collected. |
Count |
N/A |
5 minutes |
qps_peak |
Peak QPS |
This metric is used to collect the peak QPS of the domain name in the last 5 minutes. Collection method: The peak QPS of the domain name in the last 5 minutes is collected. |
Count |
N/A |
5 minutes |
qps_mean |
Average QPS |
This metric is used to collect the average QPS of the domain name in the last 5 minutes. Collection method: The average QPS of the domain name in the last 5 minutes is collected. |
Count |
N/A |
5 minutes |
waf_http_0 |
No WAF Status Code |
This metric is used to collect how many requests with no status code returned by WAF in the last 5 minutes. Collection method: The number of requests with no WAF status code returned in the last 5 minutes is collected. |
Count |
N/A |
5 minutes |
upstream_code_2xx |
Status Code Returned to the Client (2XX) |
This metric is used to collect how many requests with 2XX status code are returned by the origin server in the last 5 minutes. Collection method: The number of requests with 2XX status code returned by the origin server in the last 5 minutes is collected. |
Count |
N/A |
5 minutes |
upstream_code_3xx |
Status Code Returned by the Origin Server (3XX) |
This metric is used to collect how many requests with 3XX status code are returned by the origin server in the last 5 minutes. Collection method: The number of requests with 3XX status code returned by the origin server in the last 5 minutes is collected. |
Count |
N/A |
5 minutes |
upstream_code_4xx |
Status Code Returned by the Origin Server (4XX) |
This metric is used to collect how many requests with 4XX status code are returned by the origin server in the last 5 minutes. Collection method: The number of requests with 4XX status code returned by the origin server in the last 5 minutes is collected. |
Count |
N/A |
5 minutes |
upstream_code_5xx |
Status Code Returned by the Origin Server (5XX) |
This metric is used to collect how many requests with 5XX status code are returned by the origin server in the last 5 minutes. Collection method: The number of requests with 5XX status code returned by the origin server in the last 5 minutes is collected. |
Count |
N/A |
5 minutes |
upstream_code_0 |
No Origin Server Status Code |
This metric is used to collect how many requests with no status code returned by the origin server in the last 5 minutes. Collection method: The number of requests with no status code returned by the origin server in the last 5 minutes is collected. |
Count |
N/A |
5 minutes |
inbound_traffic_peak |
Peak Inbound Bandwidth |
This metric is used to collect the peak inbound bandwidth to the domain name in the last 5 minutes. Collection method: The peak inbound bandwidth to the domain name in the last 5 minutes is collected. |
Mbit/s |
1000 |
5 minutes |
inbound_traffic_mean |
Average Inbound Bandwidth |
This metric is used to collect the average inbound bandwidth to the domain name in the last 5 minutes. Collection method: The average inbound bandwidth to the domain name in the last 5 minutes is collected. |
Mbit/s |
1000 |
5 minutes |
outbound_traffic_peak |
Peak Outbound Bandwidth |
This metric is used to collect the peak outbound bandwidth from the domain name in the last 5 minutes. Collection method: The peak outbound bandwidth from the domain name in the last 5 minutes is collected. |
Mbit/s |
1000 |
5 minutes |
outbound_traffic_mean |
Average Outbound Bandwidth |
This metric is used to collect the average outbound bandwidth from the domain name in the last 5 minutes. Collection method: The average outbound bandwidth from the domain name in the last 5 minutes is collected. |
Mbit/s |
1000 |
5 |
attacks |
Number of Attack Requests |
This metric is used to collect the total number of attacks against the domain name in the last 5 minutes. Collection method: The system collects the number of attacks against the domain name in the last 5 minutes. |
Count |
N/A |
5 minutes |
crawlers |
Crawler Requests |
This metric is used to collect the crawler attacks against the domain name in the last 5 minutes. Collection method: The system collects the number of crawler attacks against the domain name in the last 5 minutes. |
Count |
N/A |
5 minutes |
base_protection_counts |
Basic Web Protection Actions |
This metric is used to collect the number of attacks defended by basic web protection rules over the last 5 minutes. Collection method: The system collects the number of attacks hit basic web protection rules over the last 5 minutes. |
Count |
N/A |
5 minutes |
precise_protection_counts |
Precise Protection Actions |
This metric is used to collect the number of attacks defended by precise protection rules over the last 5 minutes. Collection method: The system collects the number of attacks hit precise protection rules over the last 5 minutes. |
Count |
N/A |
5 minutes |
cc_protection_counts |
CC Attacks Blocked |
This metric is used to collect the number of attacks blocked by CC attack protection rules over the last 5 minutes. Collection method: The system collects the number of attacks hit CC attack protection rules over the last 5 minutes. |
Count |
N/A |
5 minutes |
white_black_ip_protection_counts |
Blacklist and Whitelist IP Protection Count |
This metric is used to collect the number of attacks defended by IP address blacklist and whitelist rules over the last 5 minutes. Collection method: The system collects the number of attacks hit blacklist and whitelist rules over the last 5 minutes. |
Count |
N/A |
5 minutes |
Metrics for Dedicated WAF Instances
Metric ID |
Metric Name |
Description |
Value Range |
Unit |
Number System |
Monitoring Interval (Raw Data) |
cpu_util |
CPU Usage |
CPU consumed by the monitored object Collection method: 100% minus idle CPU usage percentage |
0–100 Value type: Float |
N/A |
Dedicated WAF instances |
1 |
mem_util |
Memory Usage |
Memory usage of the monitored object Collection method: 100% minus idle memory percentage |
N/A |
1 |
disk_util |
Disk Usage |
Disk usage of the monitored object Collection method: 100% minus idle disk space percentage |
N/A |
1 |
disk_avail_size |
Available Disk Space |
Available disk space of the monitored object Collection mode: size of free disk space |
Byte, KB, MB, GB, TB, and PB |
1024 |
1 |
disk_read_bytes_rate |
Disk Read Rate |
Number of bytes the monitored object reads from the disk per second Collection mode: number of bytes read from the disk per second |
Byte/s, KB/s, MB/s, and GB/s |
1024 |
1 |
disk_write_bytes_rate |
Disk Write Rate |
Number of bytes the monitored object writes into the disk per second Collection mode: number of bytes written into the disk per second |
1024 |
1 |
disk_read_requests_rate |
Disk Read Requests |
Number of requests the monitored object reads from the disk per second Collection mode: number of read requests processed by the disk per second |
request/s |
N/A |
1 |
disk_write_requests_rate |
Disk Write Requests |
Number of requests the monitored object writes into the disk per second Collection method: Number of write requests processed by the disk per second |
request/s |
N/A |
1 |
network_incoming_bytes_rate |
Incoming Traffic |
Incoming traffic per second on the monitored object Collection method: Incoming traffic over the NIC per second |
1024 |
1 |
network_outgoing_bytes_rate |
Outgoing Traffic |
Outgoing traffic per second on the monitored object Collection method: Outgoing traffic over the NIC per second |
1024 |
1 |
network_incoming_packets_rate |
Incoming Packet Rate |
Incoming packets per second on the monitored object Collection method: Incoming packets over the NIC per second |
≥ 0 Value type: Int |
Packet/s |
N/A |
1 |
network_outgoing_packets_rate |
Outgoing Packet Rate |
Outgoing packets per second on the monitored object Collection method: Outgoing packets over the NIC per second |
Packet/s |
N/A |
1 |
concurrent_connections |
Concurrent Connections |
Number of concurrent connections being processed Collection method: Number of concurrent connections in the system |
Count |
N/A |
1 |
active_connections |
Active Connections |
Number of active connections Collection method: Number of active connections in the system |
Count |
N/A |
1 |
latest_policy_sync_time |
Latest Rule Synchronization |
Time elapsed for the WAF to synchronize the latest custom rules Collection method: Time elapsed for synchronizing to the last policies |
ms |
N/A |
1 |
Dimensions
Key |
Value |
instance_id |
ID of the dedicated WAF instance |
waf_instance_id |
ID of the website protected with WAF |
Example of Raw Data Format of Monitored Metrics
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 |
[ { "metric": { // Namespace "namespace": "SYS.WAF", "dimensions": [ { // Dimension name, for example, protected website "name": "waf_instance_id", // ID of the monitored object in this dimension, for example, ID of the protected website "value": "082db2f542e0438aa520035b3e99cd99" } ], //Metric ID "metric_name": "waf_http_2xx" }, // Time to live, which is predefined for the metric "ttl": 172800, // Metric value "value": 0.0, // Metric unit "unit": "Count", // Metric value type "type": "float", // Collection time for the metric "collect_time": 1637677359778 } ] |
