Configuring a Known Attack Source Rule to Block Specific Visitors for a Specified Duration
If WAF blocks a malicious request by IP address, Cookie, Header, or Params, you can configure a known attack source rule to let WAF automatically block all requests from the attack source for a blocking duration set in the known attack source rule. For example, if a blocked malicious request originates from a client IP address (192.168.1.1) and you set the blocking duration to 500 seconds, WAF will block the IP address for 500 seconds after the known attack source rule takes effect.
Known attack source rules can be used by basic web protection, CC attack protection, precise protection, blacklist, whitelist, and other rules. You can use known attack source rules in basic web protection, CC attack protection, precise protection, and blacklist or whitelist rules as long as you set Protective Action to Block for these rules.
- For a known attack source rule to take effect, it must be enabled when you configure basic web protection, CC attack protection, precise protection, or blacklist/whitelist protection rules.
- For blacklist and whitelist rules, a known attack source with Long-term IP address blocking or Short-term IP address blocking configured cannot be selected.
- Before adding a known attack source rule for malicious requests blocked based on Cookie, Header, or Params, a traffic identifier must be configured for the corresponding domain name. For more details, see Configuring a Traffic Identifier for a Known Attack Source.
- It takes several minutes for a new rule to take effect. After a rule takes effect, protection events triggered by the rule will be displayed on the Events page. For details, see Querying a Protection Event.
Specification Limitations
- You can configure up to six blocking types. Each type can have one known attack source rule configured.
- Maximum blocking duration:
- Long-term blocking: 3 months
- Short-term blocking: 1,800 seconds
- Log in to the WAF console.
- Click
in the upper left corner and select a region or project. - (Optional) If you have enabled the enterprise project function, in the upper part of the navigation pane on the left, select your enterprise project from the Filter by enterprise project drop-down list. Then, WAF will display the related security data in the enterprise project on the page.
- In the navigation pane on the left, choose .
- In the policy list, click the name of the target policy to go to the protection rule configuration page.
You can also go to the page, locate the target domain name, and click the number next to the protection policy in the Policy column to go to the protection rule configuration page.
- In the policy area, click Configure Known Attack Source Rule if needed. Figure 1 Enabling known attack source protection
- If you add a known attack source for the first time, click Add Known Attack Source Rule. Configure the parameters by referring to Table 1.
You can click Add Rule and add more known attack source rules.
Figure 2 Configure Known Attack Source Rule
Table 1 Known attack source parameters Parameter
Example Value
Blocking Type/Rule ID
The blocking type for the rule. The options are:
- Long-term IP address blocking
- Short-term IP address blocking
- Long-term Cookie blocking
- Short-term Cookie blocking
- Long-term Params blocking
- Short-term Params blocking
- Long-term Header blocking
- Short-term Header blocking
Blocking Duration (s)
The blocking duration must be an integer and range from:
- Short-term blocking: Blocking Type can be set to Short-term IP address blocking, Short-term Cookie blocking, Short-term Params blocking, or Short-term Header blocking. The blocking duration can be set to a value ranging from 1 to 300 seconds.
- Long-term blocking: Blocking Type can be set to Long-term IP address blocking, Long-term Cookie blocking, Long-term Params blocking, or Long-term Header blocking. You can set the blocking duration by Second, Minute, Hour, Day, and Month. The value range is as follows:
- Second: 301 to 7,776,000
- Minute: 6 to 129,600
- Hour: 1 to 2,160
- Day: 1 to 90
- Month: 1 to 3
3 months
Rule Description
A brief description of the rule. This parameter is optional.
- Click Save. You can then view the added known attack source rule in the list.
After completing the preceding configurations, you can:
- Check the rule status: In the protection rule list, check the rule you added. Rule Status is Enabled by default.
- Disable the rule: If you do not want the rule to take effect, click Disable in the Operation column of the rule.
- Delete or modify the rule: Click Delete or Modify in the Operation column of the rule.
One-Click Unblocking a Known Attack Source Rule
- Click
- Click the CC Attack Protection or Precise Protection configuration box. In the upper right corner of the rule list, click One-Click Unblocking.
One-Click Unblocking unblocks all known attack source rules triggered in the current module. All IP addresses, cookies, header, and params previously blocked by these rules will be unblocked. If the protection rule is triggered again, the associated known attack source rule is triggered as well. The IP addresses, cookies, header, or params will be blocked for a time range you configure in the rule.
- Click One-Click Unblocking in the displayed dialog box and click OK to unblock all known attack source rules triggered by the current protection module.
Then, the IP addresses, cookies, header, or params that have been blocked are unblocked until the protection rule associated with the known attack sources is triggered again.
Configuration Example: Blocking Known Attack Source Identified by Cookie
Assume that domain name www.example.com has been connected to WAF and a visitor has sent one or more malicious requests through IP address XXX.XXX.248.195. You want to block access requests from this IP address and whose cookie is jsessionid for 10 minutes.
- Choose and click domain name www.example.com. The basic information page of the domain name is displayed.
- In the Traffic Identifier area, configure the cookie in the Session Tag field.
- Enable known attack source and add a known attack source rule. You can select Long-term Cookie blocking for Blocking Type and set block duration to 600 seconds. Figure 3 Adding a Cookie-based known attack source rule
- Add a blacklist and whitelist rule to block XXX.XXX.248.195. Select Long-term Cookie blocking for Known Attack Source. Figure 4 Specifying a known attack source rule
- Clear the browser cache and access http://www.example.com.
When a request from client IP address XXX.XXX.248.195, WAF blocks the access. If WAF detects that the cookie of the access request from the client IP address is jsessionid, WAF blocks the access request for 10 minutes.
Figure 5 Block page
- Go to the WAF console. In the navigation pane on the left, choose Events. View the event on the Events page.
