Deleting a Certificate from WAF
This topic describes how to delete an expired or invalid certificate.
If a certificate to be deleted is bound to a website, unbind it from the website before deletion.
Impact on the System
- Deleting certificates does not affect services.
- Deleted certificates cannot be recovered. Exercise caution when performing this operation.
The certificate you want to delete is not bound to a protected website.
- Log in to the WAF console.
- Click
in the upper left corner and select a region or project. - (Optional) If you have enabled the enterprise project function, in the upper part of the navigation pane on the left, select your enterprise project from the Filter by enterprise project drop-down list. Then, WAF will display the related security data in the enterprise project on the page.
- In the navigation pane on the left, choose .
- In the row of the certificate, click More > Delete in the Operation column.
Related Operations
To unbind a certificate from a website domain name, take the following steps:
- In the Domain Name column of the row containing the desired certificate, click the domain name to go to the basic information page.
- Click
next to the certificate name. In the displayed dialog box, upload a new certificate or select an existing certificate.
