Viewing Basic Information of a Website
After a website is connected to WAF, you can view details about the connected website on the Protected Objects page.
- Log in to the WAF console.
- Click
in the upper left corner and select a region or project. - (Optional) If you have enabled the enterprise project function, in the upper part of the navigation pane on the left, select your enterprise project from the Filter by enterprise project drop-down list. Then, WAF will display the related security data in the enterprise project on the page.
- In the navigation pane on the left, choose .
- Check the protected website in the domain name list. For details about parameters, see Table 1.
Table 1 Parameter descriptions Parameter
Protected Domain Name
Protected domain name or IP address.
Protection
WAF protection configured for your website. You can select Cloud CNAME, Cloud Load balancer, or Dedicated.
If you select Cloud Mode - CNAME, you can view the prefix (① in Figure 1) and suffix (② in Figure 1) of the CNAME record corresponding to the domain name in the Access Mode column.
Protection Status
WAF protection status and security situation of the domain name for the past three days.
WAF supports the following protection modes:
- Protected: The WAF protection is enabled.
- Unprotected: The WAF protection is disabled. If a large number of normal requests are blocked, for example, status code 418 is frequently returned, then you can switch the protection status to Unprotected. In this mode, your website is not protected because WAF only forwards requests. It does not scan for attacks. This mode is risky. You are advised to use the global protection whitelist rules to reduce false alarms.
- Bypassed: In this mode, requests are directly sent to the backend servers without passing through WAF. The protection mode can be switched to Bypassed only when cloud CNAME access is used and the following conditions are met:
- You need to restore website services to the status before the domain name is not connected to WAF.
- You need to investigate website errors, such as 502, 504, or other incompatibility issues.
- No proxies are configured between the client and WAF.
Certificate/Cipher Suite
Certificate and cipher suite used for the domain name. You can click the certificate name to go to the Certificates page.
Policy
Number of types of WAF protection enabled for the domain name. Policy applied to the domain name. You can click the number to go to the rule configuration page and configure specific protection rules. For details, see Protection Configuration.
Server IP/Port
Public IP address of the website server accessed by the client and the service port used by WAF to forward client requests to the server.
Enterprise Project
Enterprise project the domain name belongs to.
- Click the target domain name to go to the details page.
- View the basic information about the protected website. To modify a parameter, locate the row that contains the target parameter and click the edit icon. For more details, see Advanced Settings.Figure 2 Basic Information
